| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: LS7 Clutch feedback
03-04-08, 08:30 AM
| | Cadillac Owners Connoisseur Cadillac(s): 2005 CTS-V, 2005 Escalade EXT, 2007 Escalade EXT | | Join Date: Apr 2007 Location: Sandbox, Kuwait | | LS7 Clutch feedback Ok, i got the clutch installed and i took her out for a spin....Got other good news for you guys as well...
1. i downshift much easier, before because of the rubbery movement of the original clutch and flywheel, i use to feel a back jerk forward then back...That me feelin the placement of the clutch and revvin up the engine to match. Now that awful jerk is gone...
2. The engine revs up much faster and there is no ruin to the traffic or drivability of the car...
3. if you use slave pn GM 24237634 you dont need a spacer, you just have to trim a little of the transmission to fit the new location for the hydraulic pressure line See attaced pic...
Now my only issue is when i rev the engine above 3000rpm i feel a slight shiver in gear and in neutral. And when i do a power shift at high rm i feel the clutch pedal shake a little...My mechanic said to drive it for a while and the shakin will go away...I will get back in this regard at a later time
I would like to thank you for your time in readin this and look forward to a follow up to my above mention vibration issue
03-04-08, 03:15 PM
| | Cadillac Owners Fanatic | | Join Date: Oct 2004 Location: Salem, OR Age: 69 | | | Re: LS7 Clutch feedback Did you do a weight comparison between the ZO6 and ZO7 clutch assemblies? |
03-05-08, 12:13 AM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: LS7 Clutch feedback thanks for the post. I probably get z07 in my car soon as well. |
03-05-08, 02:11 AM
| | Cadillac Owners Connoisseur Cadillac(s): 2005 CTS-V, 2005 Escalade EXT, 2007 Escalade EXT | | Join Date: Apr 2007 Location: Sandbox, Kuwait | | | Re: LS7 Clutch feedback I have the LS7 clutch...
Is there a Z07? Never heard of it... |
03-05-08, 10:15 AM
|  | <----- go ahead and stare Cadillac(s): Maggied '05 CTS-V | | Join Date: Jan 2008 Location: West Chester, PA Age: 26 | | | Re: LS7 Clutch feedback Quote:
Originally Posted by Naf I have the LS7 clutch...
Is there a Z07? Never heard of it... | I think the new ZR-1 was initially referred to as the Z07 by some. |
03-05-08, 10:43 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 2004 CTS-V | | Join Date: Dec 2004 Location: Leesburg, Florida | | | Re: LS7 Clutch feedback I've got the C5 Z06 clutch/PP/flywheel in my car and love it. It still vibrates a little if I hold the RPMs at 3k in neutral, but driving is perfect, so I'm not sure that the vibration in your will go away. Keep us posted.
__________________ Tony Pagano
Plaza Cadillac
Leesburg, FL
(352) 408-0391 www.cadillactony.com The views and opinions of this poster are solely his own and do not represent those of Plaza Cadillac |
03-05-08, 05:04 PM
|  | Cadillac Owners Fanatic | | | | | Re: LS7 Clutch feedback Sorry, Just to clarify. The new slave cylnder will allow for direct bolt up of the LS7 assembly, without the need for that spacer that the other setups suggest using. I assume the notching is to allow further travel on the shift fork than before? What was your install cost? |
03-06-08, 03:07 AM
| | Cadillac Owners Connoisseur Cadillac(s): 2005 CTS-V, 2005 Escalade EXT, 2007 Escalade EXT | | Join Date: Apr 2007 Location: Sandbox, Kuwait | | | Re: LS7 Clutch feedback The new slave does not need a spacer. I am currently runnin this slave with no spacer.
The notchin is for the hose to comfortably exit the housing...
Talk with Luke, he will hook you up with the parts...My installation cost was ridiculasly low due to TCN labor, (Third Country Nationals) |
03-06-08, 10:44 AM
| | Cadillac Owners Connoisseur | | | | | Re: LS7 Clutch feedback So, you're a sweatshop task master, eh? |
03-07-08, 03:22 AM
| | Cadillac Owners Connoisseur Cadillac(s): 2005 CTS-V, 2005 Escalade EXT, 2007 Escalade EXT | | Join Date: Apr 2007 Location: Sandbox, Kuwait | | | Re: LS7 Clutch feedback You can say that, and they meet all the min requirements...
By the way the vibration is gone, just needed to be pressed in place and run for a while... | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
