Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Ron Davis Racing radiators
  #16 (permalink)
Old 03-05-08, 12:56 PM
JMBCTSV's Avatar
Cadillac(s): Cadillac CTS-V 2004 street, Cadillac CTS-V 2004 Race
View JMBCTSV's Photo Album
Casino Cash: $2670
Re: Ron Davis Racing radiators
When thinking about an integrated oil cooler make sure you have enough excess cooling capacity to use the cooled water to cool the oil. If your water temp is marginal to begin with using it to cool the oil may not be the best idea.
Remember it's okay to have 300 degree oil, 300 degree water . . . . not so much.
John M Buttermore
http://www.nearbrookmotorsports.com
  #17 (permalink)
Old 03-09-08, 03:08 PM
Cadillac(s): 06 CTS-V
View C66 Racing's Photo Album
Casino Cash: $1235
I disagree with you on the 300 degree oil... keep in mind that at 300F, a typical 5w30 has a viscosity of about 3 cSt. Most 5w30's have a viscosity of about 10-11 cSt at a nominal 212F. So... at 300F, your oil's viscosity is about 30% of nominal. It is for this reason that I run a high performance 10w40 in my 02 Corvette Z06 on the track (where I see oil temps of about 250F with an oil cooler).
On the thread topic, I have a Ron Davis radiator in my 02 Z06 which is the only aftermarket radiator allowed per SCCA T1 rules. Nice unit and helped lower my coolant temps on the track to a constant 200F even in hot weather.
I've read probably hundreds of these posts on the Corvette forum and will say that most guys with dual use cars (track and street) go for the unit that has the oil cooler integrated (I have separate oil cooler per the T1 rules). Based on what I've read, the integrated unit has the capacity to keep the oil temp reasonable (270ish) while maintaining coolant temp below 220F for most guys at most tracks. Most dual use guys get the integrated unit so as to allow the oil to come up to temp in daily driving. With my separate oil cooler, I really can't get my oil over about 150F until I get on the track. For a daily driver, you really don't want to keep your oil that cold and with the integrated unit, oil temp will follow coolant temp which is just about right for a daily driver.
As for fitament, mine was advertised to be a direct fit... and it almost was, but I had to file down the slots in the top radiator shroud a little bit (was very easy) as the Rod Davis unit was much thicker than stock). Despite this, it was still an easy install and one I'd seriously consider if I tracked my CTS-V.
C66 Racing LLC - AMSOIL Direct Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program Members buy at Wholesale - a savings of about 25%
C66 Racing
2004 SCCA MidWest Division T1 Champion
  #18 (permalink)
Old 03-09-08, 03:49 PM
Naf Naf is offline
Cadillac(s): 2005 CTS-V, 2005 Escalade EXT, 2007 Escalade EXT
View Naf's Photo Album
Casino Cash: $12206
I cant wait to get mine...MMMMMM....It is startin to get hot already, it hit 100 today...
Question though, if i run an oil cooler and give it a cool stream of air will i be runnin into issues? I think my nominal temp will be around 130-160F depending on ambient temp and asphalt temp...Or should i follow the way of CadillacFaq? cover the face of it?
  #19 (permalink)
Old 03-10-08, 01:52 AM
v-sam's Avatar
View v-sam's Photo Album
Casino Cash: $9592
My Oil Temp on track gets to 310. The highest I have seen is 321 on the 3rd of July on track of course so and oil cooler would be great.
  #20 (permalink)
Old 03-10-08, 09:33 AM
ctsv154's Avatar
Cadillac(s): 04 CTS-V with a little hp persuasion device
View ctsv154's Photo Album
Casino Cash: $15537
Do you have a for sure price yet? I've had my radiator replaced under warranty already and it still leaks. Just having one that will run cooler and have an oil cooler in it would be great. Not to mention one that doesn't leak!
  #21 (permalink)
Old 03-10-08, 09:47 AM
Lindsay Cadillac Parts's Avatar
Cadillac(s): All of them
View Lindsay Cadillac Parts's Photo Album
Casino Cash: $14394
The intergrated oil cooler isnt somthing that we are really talking to RDR about, there would need to be some plumbing issues worked out to get the oil to the radiator. A seperate cooler is definately on my short list as far as having one of my suppliers look into however. PM me for a price on the radiator.
Luke Butler
lbutler@lindsaycadillac.com
GM Performance Division T-Shirts - $19.95 plus shipping
  #22 (permalink)
Old 03-10-08, 12:47 PM
lunarx's Avatar
Cadillac(s): 05 Mallett 427 CTS-V
View lunarx's Photo Album
Casino Cash: $6362
Just curious, can you see where your leak is?
(that leak is so hard to spot)
Nevertheless, the RDR is the final cure for leaking V radiators.
05 Mallett [M] CTS-V: 499WHP 497WTQ | 427 C5R Block | Ron Davis 2-Row Rad | [M] Oi1 Cooler | P&P LS6 Heads | FAST 78 IM | LPE CAI | SW 1-3/4" Headars | RT Hi Flow Cats | B&B 3" Exhaust | RPS Street-Twin Clutch | McLeod Billet Slave Cyl | [M] ST Shifter | RPM Trans Level-V Build | MN6 Geer Ratio Conv | Cryo Treated Diff | GM T2 Diff Cooler | [M] Anti Wheel Hop Kit | FG2 Shocks | SS Brake Limes | Slotted Cryo Rotars | [M] Modified Front Spindles | 275-35-19 PS2 F&R | [M] 19x9 Billet Whels F&R |
  #23 (permalink)
Old 04-28-08, 04:12 AM
lunarx's Avatar
Casino Cash: $6362
Got my Ron Davis Radiator from Luke.
1-1/8" thicker than stock, it's a monster.
  #24 (permalink)
Old 04-28-08, 04:45 AM
shadybx7's Avatar
Cadillac(s): 2005 Platinum CTS V with Black leather
View shadybx7's Photo Album
Casino Cash: $12756
calling it a monster is an understatement.. that thing looks more like a intercooler then a Radiator..
  #25 (permalink)
Old 04-28-08, 09:07 AM
StealthV's Avatar
Cadillac(s): Twin-Turbo Bimmer/C6Z06 Hunting...
View StealthV's Photo Album
Casino Cash: $3517
Good thing I don't have a V anymore or yet another mod would be draining my wallet. That thing is a work of art. Too pretty to be buried under the bonnet.
  #26 (permalink)
Old 04-28-08, 09:58 AM
Casino Cash: $14394
thanks for the pics, I have one left on the shelf...........
  #27 (permalink)
Old 04-28-08, 01:36 PM
Cadillac(s): 04 V Raven
View Civardi's Photo Album
Casino Cash: $5420
Cost?
  #28 (permalink)
Old 04-28-08, 01:49 PM
Cadillac(s): Silver 04V Kooks,Corsa,UUC S.Shifter/Bushings, Badass Driver
View Keys8541's Photo Album
Casino Cash: $2070
Luke, can you PM me the price, I might just have to pick one up after seeing the picture
  #29 (permalink)
Old 04-28-08, 01:58 PM
Cadillac Owners Enthusiast
View rangerrob's Photo Album
Casino Cash: $6685
that thing looks sweet!
  #30 (permalink)
Old 04-28-08, 02:31 PM
View atdeneve's Photo Album
Casino Cash: $9348
Yeah, curious as to the cost here, as well. Es purty.
Tags: , , ,
davis, racing, radiators, ron
Censor is OFF
