Hardwiring Radar Detector
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Like Tree1Likes
2004-2007 Cadillac CTS-V General Discussion Discussion, Hardwiring Radar Detector in Cadillac CTS-V Series Forum - 2004 - 2007; attempting to hardwire my Escort 8500 x50 via the faq instructions (link below) and I'm not getting power to the ...
    Natedog's Avatar
    Natedog is offline Cadillac Owners Enthusiast
    Automobile(s): 2016 ATS-V (Blk, 6spd, Recaros), 2007 Cadillac CTS-V (sold)
    Oct 2004
    Vienna, VA
    32
    717
    ExclamationHardwiring Radar Detector
    attempting to hardwire my Escort 8500 x50 via the faq instructions (link below) and I'm not getting power to the unit... I tapped the pink wire in the rear view wiring harness and i've got the ground on the black wire with white stripe as noted... my connections look good, where am I going wrong?
    http://www.cadillacfaq.com/faq/answers/v1install.html
  2. #2
    MauiV's Avatar
    MauiV is offline Cadillac Owners Connoisseur
    Automobile(s): Tis Gone :(
    Nov 2007
    3,414
    Re: Hardwiring Radar Detector
    Keep us updated because I am tired of jamming my fingers into my power cord every time I go to 3rd or R. I dont even use 5th because its such a PITA. I love the X50 but that plug is ridiculous.
    BTW, isnt that thing illegal in Virginia?
    Tlorenzen likes this.
  3. #3
    randycsvt is offline Cadillac Owners Fanatic
    Automobile(s): 05 Black CTS-V
    Oct 2007
    Central FL
    233
    Those wire taps suck. Use electrical T Taps. These will give you a better connection. The ones you are using are difficult to get a solid connection, and once you have a solid connection it can easily go out on you when you hit a bump or something.
    http://www.discountcarstereo.com/detail.aspx?ID=530
    I would also check to see you have power and ground. Use a multimeter on the wires to check for power. Make sure you test with the ignition on and off, because switched power wires only have power when the key is on.
  4. #4
    keithsm2 is offline Cadillac Owners Fanatic
    Automobile(s): 05' Stealth Gray V, UUC STS, 11 V Coupe, W. Diamond, B&B Ex
    Dec 2007
    Texas
    53
    413
    i would get a Invisicord.....do a search on FAQ.....Its like 15 bucks....I just did mine for the escort....works pretty good with the pink and black/white.
  5. #5
    Natedog's Avatar
    Oct 2004
    Vienna, VA
    32
    717
    You guys are right, as always... pink (power) and black w/ white (ground) work perfectly... my connections were pretty terrible... i ended up just stripping the wires on the hardwiring kit, and pulled back as much raw wire as i could on the pink, black/white... wrapped them together as best i could and secured with the cheapo in line splices i had... cleaned it all up and now i don't have the huge wire hanging down and i don't smash my hand when going to 3, 5, or R... much thanks to all
  6. #6
    Natedog's Avatar
    Oct 2004
    Vienna, VA
    32
    717
    Quote Originally Posted by MauiV View Post
    SShhhhhh don't tell anyone
  7. #7
    SwampFox's Avatar
    SwampFox is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS-V
    Nov 2005
    Emmitsburg, Maryland
    170
    Virginia is the only state detectors are illegal. I put my Valentine in the trunk. BTW Canada too!
  8. #8
    CadiKing2006's Avatar
    CadiKing2006 is offline Cadillac Owners Fanatic
    Nov 2005
    Ontario, Canada
    383
    u put it in the trunk so how did it work then???
  9. #9
    tedcmiller is offline Cadillac Owners Connoisseur
    Apr 2004
    1,827
    I connected my RADAR dectector power to the fuse block under the rear seat. This avoids getting to, cutting, or altering any of the existing wiring.
  10. #10
    tomm's Avatar
    tomm is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Cadillac CTS VSport
    Feb 2005
    New Jersey
    67
    2,318
    Quote Originally Posted by SwampFox View Post
    Dont forget Washington DC... And if you drive a truck they are illegal in every state.
  11. #11
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,788
    Washington DC is not a state.
  12. #12
    onebadcad's Avatar
    onebadcad is offline Cadillac Owners Connoisseur
    Automobile(s): '09 V BR 4dr 6spd,'05 C6R 1400+HP, '05 V BEST EVA!!
    Aug 2004
    Mod Hell
    2,660
    I am lazy (and not too electronically inclined), so I had a Stereo Shop do it for $25.00. Of course the installer complained throughout the install so I hit him with a double sawbuck.
  13. #13
    ctsvett's Avatar
    ctsvett is offline FAQ is your Friend
    Automobile(s): CTS-V
    Feb 2003
    California
    3,987
    Quote Originally Posted by heavymetals View Post
    always the smart guy!
  14. #14
    CTS-V ChemE is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Aug 2009
    Bridgewater, NJ
    34
    31
    Quote Originally Posted by tedcmiller View Post
    Which fuse did you use and with what connectors?
  15. #15
    VforMe's Avatar
    VforMe is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V with 2 carseats in the back and a f'ing minivan
    Nov 2008
    Franklin, TN (Nashville)
    37
    607
    Quote Originally Posted by CTS-V ChemE View Post
    Use this....
    http://www.cadillacfaq.com/faq/answe...wer/index.html
    If you really want to go under the backseat to the fuse box(although I recommend using the instructions above) Use the "remote wire" directions in this one.....
    http://www.cadillacfaq.com/faq/answe...eep/index.html
  16. Remove Advertisements
