Coolant level warning
Results 1 to 4 of 4
2004-2007 Cadillac CTS-V General Discussion Discussion, Coolant level warning in Cadillac CTS-V Series Forum - 2004 - 2007; I've got 1600 miles on my V and twice I've had to top off the coolant. I've fed it about ...
    chet is offline Cadillac Owners Member
    Automobile(s): 2004 ctsv Black, 2013 CTS Performance Diamond Black
    May 2004
    NorCal
    48
    55
    I've fed it about a quart maybe a little more. No leaks, tail pipe seems OK.
    Is this just burping?
  2. #2
    Rich H's Avatar
    Rich H is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTSV
    Apr 2004
    Denver
    590
    Re: Coolant level warning
    Doesn't sound normal. Unless there was air in the system to begin with you should not be needing to add that much coolant. My V is at ~1000 miles and I haven't had to add any coolant since the level has stayed at the max fill level. Have the dealer do a pressure test which will also check for internal leaks.
    Rich H.
  3. #3
    GNSCOTT is offline Cadillac Owners Connoisseur
    Jan 2004
    Connecticut
    1,061
    check the oil and make sure its not leaking into the engine. Its problably air in the system if its not in the oil and not in a puddle on the ground.
  4. #4
    JLCortese's Avatar
    JLCortese is offline Cadillac Owners Member
    May 2004
    8
    Could be air in the system, may need to bleed it.
