Results 1 to 7 of 7
Thread: Normal Temp for Water and Oil?
    Apr 2004
    Pennsylvania
    113
    Question Normal Temp for Water and Oil?
    What is the normal operating temp for water and oil and trans fluid? Anybody know? My water temp rarely goes above 194 and oil temp about 244. Is this normal in a LS6 engine?
  2. #2
    Mar 2004
    27
    Re: Normal Temp for Water and Oil?
    That is about what mine runs with the outside temp. aroud 85 - 88 degrees. When you begin to push it a little things go up about 10 degrees. Like all of the current "V" owners I am waiting for the oil temp fix from Cady. I do not think that the oil temp is really that much higher than the water.
  3. #3
    May 2004
    51
    dont worry about it..if your running at 194 then your cooling system is working fine
  4. #4
    Cal is offline Cadillac Owners Enthusiast
    Apr 2004
    NJ Shore
    763
    It's hard to say what is normal when the oil temp gauge is known to read way too high.
  5. #5
    Feb 2004
    Kenner, suburb of New Orleans
    321
    Keep an eye on the temps. while the weather is hot and your in traffic. Turning on the AC helps.
    Joe
    New Orleans
  6. #6
    benjet's Avatar
    benjet is offline Cadillac Owners Connoisseur
    Dec 2003
    Bay Area, CA
    1,372
    I have seen water temps from 195-215 (in my CTS-V - seems normal). From my experience in other cars (non LS6) oil temps are 30-40 deg over water. So in *MY* opinoin oil should only very rarely (hard/track use) get over 260.
  7. #7
    May 2004
    51
    actually turning on a/c doesnt help..turning on heat does
  • You may not post replies
