Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Left header clicking?
  #16 (permalink)
Old 12-30-07, 12:03 AM
Silver Dollar's Avatar
Das jus fo decorations
Cadillac(s): 2006 CTS-V
View Silver Dollar's Photo Album
Casino Cash: $5541
Re: Left header clicking?
Exhaust leaks are tough to pin down.
Take an old piece of garden hose a few feet long and use it like a stethoscope. Sometimes you can locate the "tick, tick, tick" that way.
  #17 (permalink)
Old 12-30-07, 09:12 AM
my name is Tiffany
Cadillac(s): 05 CTS-V
View urbanski's Photo Album
Casino Cash: $1133630
and if you cant hear it, the hot gas blasting into your eardrum outta do it
  #18 (permalink)
Old 12-30-07, 10:24 AM
dqw1's Avatar
Cadillac(s): 2004 CTS-V Black Raven
View dqw1's Photo Album
Casino Cash: $18919
My Tech found a bad weld on my exhaust after my headers were installed. You could barely see the small hole while the car was on the lift. I'm not an expert but sometimes it's the simple things.
  #19 (permalink)
Old 12-30-07, 01:46 PM
Casino Cash: $5541
That's only when I eat Mexican food.
  #20 (permalink)
Old 12-30-07, 04:44 PM
GUNRDY's Avatar
Cadillac(s): Cadillac CTS V
View GUNRDY's Photo Album
Casino Cash: $1490
If your throwing codes, you might want to check your O2 sensor. It might not have been torqued down or possibly leaking from the bung. Did you reuse the stock gaskets or did you use new ones? Double check all the header bolts. Hold a thin sheet of paper around the welds and connection points while the car is running you will hear the escaping gases hit the paper.
Other than that I would say LS motors usually sound "ticky" with headers.
Hope this helps, good luck
  #21 (permalink)
Old 12-30-07, 06:03 PM
Cadillac(s): LS6 CTS-V
View CBVLS6's Photo Album
Casino Cash: $4692
Used kooks gaskets. Bolts are all tight. I have checked the gasket by the header and I cannot see any leaking from the flange whatsoever. I cannot see the bottom side however so it is possible.
The sound is far more than just normal operation engine noises. The sound is originating towards the collector/ cat area.
The idiot at auto zone wouldnt give me the actually code and the place was slammed people in broken-down shitboxes so he wouldnt give me the time to argue.
All I know it is Bank 2, Sensor 1, which could be any of the following:
P1132 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 2 Sensor 1
P1153 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
P1154 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
P1155 - Heated Oxygen Sensor (HO2S) Lean Mean Bank 2 Sensor 1
P1156 - Heated Oxygen Sensor (HO2S) Rich Mean Bank 2 Sensor 1
Anyone.. Anyone... Ideas
  #22 (permalink)
Old 12-30-07, 06:37 PM
heavymetals's Avatar
Cadillac(s): 05 maggied CTS-V, 03 maggied Z06
View heavymetals's Photo Album
Casino Cash: $19172
You can clear the check engine light by disconnecting the battery.
Drive it around but stay off the power runs for a few miles and see if any codes.
You could have blown out the gasket doing WOT, which would not be unheard of.
Welcome to MOD HELL.
I am so expensive I can't even afford to hire me....
  #23 (permalink)
Old 12-30-07, 06:40 PM
Casino Cash: $5541
....or possibly leaking from the bung.
Again, only when I eat Mexican food.
  #24 (permalink)
Old 12-30-07, 08:31 PM
Casino Cash: $4692
The gaskets are fine, I double checked today. I havent taken the car WOT more than maybe twice in 2/3rd.
The car is bogging down in 1st gear pretty bad sometimes. I will hit the gas and its just falls on its face, boggs, backfires and then goes. It feels like I am either getting too much fuel, or not enough. I dont know that much about GM's and the LS series motors, this being my first, but is it possible that the car can be in "limp" mode, where the ECM is running the car real rich b/c it's identifying a unknown variable that could be a threat.???
I'm almost afraid to drive the car until I know WTF is going on, plus I dont want to foul the plugs.. etc.
  #25 (permalink)
Old 12-30-07, 09:10 PM
The Tony Show's Avatar
How YOU doin?
Cadillac(s): 2007 SRX (Previously 04 CTS-V)
View The Tony Show's Photo Album
Casino Cash: $18705
Hold both the clutch and throttle to the floor and crank the car- it'll turn over, lurch and then stop. Wait about 20 seconds and then start it normally.
This procedure resets the "home" position on the TB and turns off limp mode.
  #26 (permalink)
Old 12-30-07, 10:38 PM
Casino Cash: $4692
Thats good info to know.. I appreciate it.
By the way, wtf happened to +/-rep, where has it gone, or am I just plain stupid?
  #27 (permalink)
Old 12-31-07, 12:55 AM
CTSV_Rob's Avatar
<10 poasts, CF newbie
Cadillac(s): 2007 CTS-V Thunder Gray w/ Lt Gray interior
View CTSV_Rob's Photo Album
Casino Cash: $1121660
Not stupid, it's gone.
Friendship is like peeing your pants, everyone can see it, but only you can feel it's true warmth.
  #28 (permalink)
Old 12-31-07, 07:37 AM
my name is Tiffany
isnt sensor 1 pre-cat
could be a dead (fried) O2. buy new from Lindsay
  #29 (permalink)
Old 01-04-08, 08:59 PM
Casino Cash: $4692
Re: Left header clicking?(update)
UPDATE:
Well, its confirmed, I am offically dumping exhaust gasses from both of the header flanges, primarily from the passenger side flange( WHICH WAS F---ING REPLACED by kooks and still slightly untrue).
So now I just need to check the collectors and make sure that they are completely leak free and then its on to the car stuttering when engaging gears in the 1-2k rpms range
Tags: , ,
clicking, header, left
Censor is OFF
