| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Rear axle pinion seal recall
12-24-07, 10:45 AM
|  | Cadillac Owners Connoisseur Cadillac(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo | | Join Date: Mar 2006 Location: NYC Age: 38 | | | Re: Rear axle pinion seal recall Quote:
Originally Posted by ewill3rd Not to cause undue stress here, but if this job is done wrong it will trash the rear end. Hopefully they will follow the instructions. | That helped me make my decision. All we have to worry about is a leak. As long as mine is dry, I wont mess with it.
__________________ '05 Platinum l LPE CAI l Magnaflow l V1 (hardwired), w/ custom mount l UUC shifter w/Lindsay bushings l UUC leather shift knob l K9 GEAR rear seat cover l CruiseCam l HID fogs l Falken RT-615s l Hotchkis sways W/Z06 end links l Billet A/C vent knobs l Hawk HP+/HPS l CG-Lock l Specter Werkes Bushings l Noah Custom cover l FG2s l Ground control 550/600 l MAGGIE 436RWHP/ 412RWTQ (Dynojet) l Heavys fire extinguisher bracket l Intercepter scan-gauge l Billet pedals l Meth l NO HEADERS |
12-25-07, 09:26 PM
|  | Cadillac Owners Fanatic | | Join Date: Jul 2004 Location: Ontario | | | Re: Rear axle pinion seal recall Do we know if this covers 2004s or not? One of the above posts said yes; others said no.
My 2004 once left a couple spots of oil on the garage floor, but then never really did it again. But AFAIK, this has been a problem since day 1 of the CTS so it's odd that it's only covering 2005+. Then again, pinion seal leaks have been a hallmark of GM engineering for decades. |
12-26-07, 08:20 AM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Rear axle pinion seal recall As I have mentioned, the letter from GM says 2005-2007. No mention of '04.
Not sure what the difference is, I think there is a difference in the vendor or part composition?
As I also mentioned, there is no way to know until the actual recall comes out. It was announced by GM on the 21st and due to be released in February. Until then, no guarantees about anything.
If there is a leaking one, the TSB will handle it in the meantime.
I am sure the recall will come with a reimbursement clause for you guys out of warranty.
That means if you pay to have it done with the new parts you should be able to submit papers for a refund.
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
02-01-08, 09:52 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Rear axle pinion seal recall Here is some info for this recall that has now been released to us. Quote:
Subject: Product Safety - Drive Axle Seal Leak-Replace Seal #07204 - (01/31/2008)
Models: 2005-2007 Cadillac CTS, CTS-V, SRX, STS
2006-2007 Cadillac STS-V
2007 Daewoo G2X
2007 Opel GT
2006-2007 Pontiac Solstice
2007 Saturn SKY
Condition
General Motors has decided that a defect, which relates to motor vehicle safety, exists in certain 2005-2007 model year Cadillac CTS, CTS-V, SRX, STS; 2006-2007 model year Cadillac STS-V; 2007 model year Daewoo G2X and Opel GT; 2006-2007 model year Pontiac Solstice; and 2007 model year Saturn SKY vehicles. The drive axle differential seal (two on all-wheel drive vehicles) may leak because it does not meet GM's specifications. If a seal is leaking, there will be fluid on the ground where the vehicle is parked. If enough fluid leaks, the differential will become noisier because of reduced lubrication. After about two-thirds of the differential fluid is lost, the bearings may no longer be lubricated and may start to overheat. Damage to the bearings and other differential components could then occur. Damaged bearings will create noise that may be heard by the vehicle occupants. If the vehicle is not repaired and damage progresses, three conditions can occur: (1) When the vehicle is stopped and shifted to reverse, the differential may jam and prevent vehicle movement; (2) the damage can cause drag that will feel like the brake is applied; or (3) the differential could jam and lock the drive wheels while the vehicle is in motion. If (3) occurs, the driver may not be able to control the vehicle and a crash could occur without warning.
Correction
Dealers/retailers are to install a new drive axle differential seal (two on all-wheel drive vehicles).
Vehicles Involved
Involved are certain 2005-2007 model year Cadillac CTS, CTS-V, SRX, STS; 2006-2007 model year Cadillac STS-V; 2007 model year Daewoo G2X and Opel GT; 2006-2007 model year Pontiac Solstice; and 2007 model year Saturn SKY vehicles built within these VIN breakpoints:
Year
Division
Model
From
Through
2005
CTS
50207119
50237751
2006
CTS
60100001
60213969
2007
CTS
70100002
70198445
2005
CTS-V
50207126
50234392
2006
CTS-V
60102809
60209495
2007
CTS-V
70100001
70197204
2005
SRX
50207077
50237338
2006
SRX
60100011
60222963
2007
SRX
70105009
70193999
2005
STS
50207130
50237744
2006
STS
60100019
60222184
2007
STS
70100056
70197027
2006
STS-V
60104156
60217940
2007
STS-V
70100060
70195959
2007
Daewoo
G2X
7Y136494
7Y140874
2007
Opel
GT
7Y111678
7Y142685
2006
Pontiac
Solstice
6Y000001
6Y120195
2007
Pontiac
Solstice
7Y103375
7Y142882
2007
Saturn
SKY
7Y100001
7Y142740
Important: Dealers/retailers are to confirm vehicle eligibility prior to beginning repairs by using the system(s) below. Not all vehicles within the above breakpoints may be involved.
-- GM dealers and Canadian Saturn retailers should use GMVIS.
02-01-08, 10:34 PM
|  | Cadillac Owners Connoisseur Cadillac(s): Twin-Turbo Bimmer/C6Z06 Hunting... | | Join Date: May 2004 Location: MN>ND>MN>SD>IL>MN>IL Age: 41 | | | Re: Rear axle pinion seal recall My seal looks fine; should I take it in?
02-01-08, 10:44 PM
|  | No BS Zone Cadillac(s): 2005 Cadillac CTS-V | | Join Date: Nov 2006 Location: Moultrie, GA Age: 48 | | | Re: Rear axle pinion seal recall Quote:
Originally Posted by StealthV My seal looks fine; should I take it in?  | That's just wrong.
__________________ Gene Z. aka Boilermaker
05 CTS-V, Stealth Gray aka The Don V, Just an exhaust and a chip, man!!
Highest mileage V on the forum?
In service 12/1/06, >139,000 miles and counting....
96 Impala SS aka Black Sunshine, 383, Twin Turbo, 11's, ~245,000 miles |
02-02-08, 09:33 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Rear axle pinion seal recall That is messed up...
The rest of you, if you want to inspect the seals on the diff, I recommend AGAINST using that procedure!
Besides the vent might leak worse with the car upside down.  |
02-02-08, 11:29 PM
|  | Cadillac Owners Fanatic | | Join Date: Nov 2005 Location: Ontario, Canada | | | Re: Rear axle pinion seal recall Is this TSB for Canada too? |
02-03-08, 02:59 AM
|  | Commonsewer Cadillac(s): Black CTS-V, 1969 Yellow Vette w/ZZ383 | | Join Date: Jan 2005 Location: So. California Age: 45 | | | Re: Rear axle pinion seal recall Quote:
Originally Posted by StealthV My seal looks fine; should I take it in?  | Yeah,
Have it towed over from the scrap yard!
__________________ I wanted change, but all I got was a broke ass car company. |
02-03-08, 09:16 AM
|  | Mods on hold till diff gets fixed. Cadillac(s): 2005 CTS-V | | Join Date: Jan 2005 Location: South Lyon, MI Age: 60 | | | Re: Rear axle pinion seal recall Quote:
Originally Posted by StealthV My seal looks fine; should I take it in?  | Well lit pic ... did't even need a shop light.
__________________ '05 CTS-V, Stealth Gray, Sunroof, 3M Clear Bra, B&M Shifter w/UUC Bushings, Specter Werkes Bushings, V Headrests, Wheel To Wheel Powertrain Tune, Corsa, Kooks w/Hi-Flo Cats, Ultimate Grid Pedals, Hotchkis Anti-Sways, STS-V Fogs, Ground Control 650R/600F, WW Clear Sidemarkers, Full-Size Spare, Magnuson SC Polished, CTS Console, FG2, Aggressive Street Alignment, MOMO Shift Knob, DSS/Hendrix Engrg Axles, UUC Flywheel. Soon: UUC MMs. 472 RWHP/411 RWTQ (Mustang dyno). |
02-03-08, 10:23 AM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Rear axle pinion seal recall I think it does apply in Canada, although I can't tell you much about that. |
02-18-08, 06:20 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2005 Redline CTS-V, 1997 Catera | | Join Date: Mar 2007 Location: Purdue University | | | Re: Rear axle pinion seal recall I just brought the V in for service and had them check on the recall, they said it does not apply to my car...does that sound right?
Ted
__________________ R.I.P. Cadillacforums..... |
02-18-08, 06:53 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Rear axle pinion seal recall Could be, you can always PM me the last 8 of the VIN and I'll double check. |
02-19-08, 09:32 AM
| | Cadillac Owners Enthusiast | | | | | Re: Rear axle pinion seal recall SkullV,
The applicable VIN numbers are provided in post #34 by ewill3rd. |
02-19-08, 04:12 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2004 CTS-V Black Raven | | Join Date: Apr 2005 Location: Madison, AL | | | Re: Rear axle pinion seal recall My 04 pinion seal has been replaced twice in the last year for leaks, the last time in December 07. Strange that the 04's may not be included in this recall. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
