Any Short Shift Kit Avail Yet???
Results 1 to 3 of 3
2004-2007 Cadillac CTS-V General Discussion Discussion, Any Short Shift Kit Avail Yet??? in Cadillac CTS-V Series Forum - 2004 - 2007; Any Kit For The Cts-v Yet? Thanks...
    EYEFORTHECTSVGUY is offline Cadillac Owners Member
    May 2004
    6
  2. #2
    Cal
    Cal is offline Cadillac Owners Enthusiast
    Apr 2004
    NJ Shore
    763
    Re: Any Short Shift Kit Avail Yet???
    None that I am aware of. They say the GTO kit may fit the V because of the way the trans is mounted. I am looking for one also, so here's hoping.
  3. #3
    Rob Ketcham is offline Cadillac Owners Member
    Mar 2004
    Eastern shore of MD
    81
    What I learned about the shifter is that is not like either the SS Camero I used to have, or like the Vette. If this is so, then nothing on the market that I am aware of would work.
    As explained to me, it is a more European type design with two rods going into the transmission. It was speculated, by a guy that had changed motors and played around with his V that the slop is due to the rubber bushings.
    The other problem is you can't get to the top of the transmission like you could with my SS Camero. On that car I put in a B&M ripper sifter and it was a big improvement, but all you had to do was get to the top of the transmission by taking off the tunnel cover.
    If you drop your transmission down a bit on the V from underneath you will be able to see the bushings. I am hoping that someone will duplicate them using polyurethane and that will firm things up.
    Rob
