Tire sensor issues - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
2004-2007 Cadillac CTS-V General Discussion Discussion, Tire sensor issues in Cadillac CTS-V Series Forum - 2004 - 2007; The tire pressure sensors are specific to the wheel position they are programmed for. That is why the programming sequence ...
  1. #31
    tedcmiller is offline Cadillac Owners Connoisseur
    Apr 2004
    1,827
    Re: Tire sensor issues
    The tire pressure sensors are specific to the wheel position they are programmed for. That is why the programming sequence requires that the wheels be programmed in a specific order beginning with the left-front wheel. The computer assumes that the wheels will communicate in that order and sets the TPS display accordingly. If you move the wheels without reprogramming, the display will continue to show the correct pressure, but in the location that the wheel was originally in. If you program in the wrong sequence, the display will show the correct pressure but in the wrong position.
    According to the factory service manual, you cannot use the magnet tool to initiate TPS communication on the CTS-V wheels. You must use the pressure change method (i.e., let enough air out to activate the signal transmission). Obviously, this is going to be a major inconvenience for anyone without a compressor.
    For what it is worth, if you are paying to have your tires rotated, the car care people say don't bother. Supposedly the cost savings due to increased tread life is less than the cost of the rotations. If your rotations are free and you have no compressor at home, be sure to reprogram the TPSs then and there while you have a source of compressed air. In the case of the V's Goodyear EMTs, with a typical treadlife of only 10-12K miles, it is questionable whether rotation is worth the effort in any case.
    If you are installing new tires, make sure the wheels go back on in the same location and you will not have to reprogram. This, of course, assumes that the tire changing gorillas don't damage any of your TPS sensors.
  2. #32
    sefa01's Avatar
    sefa01 is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V
    New Jersey
    931
    Quote Originally Posted by Harley Guy
    My thought was that this could help solve my winter tire problem. I would have rims for the winters with TPS in them and have a set of spare summers when I run through the current pair. If something like this does not come through, I will probably take the tirerack package for about $1,800.
    I have the TireRack rims (Mille Miglia MM-S) and I think they look better than the stock rims. TireRack, however, won't install the TPS. I bought the 4 TPS from www.gmotors.com for about $58 each (including shipping) and had the rims and tires shipped from TireRack to an approved installer. He then charged me $120 to mount and balance the tires and to install the TPS.
    And before anybody asks, I'm not selling the stock rims and tires. The Mille Miglia rims are for my race tires.
  3. Remove Advertisements
