Leaking coolant and smell
Results 1 to 8 of 8
2004-2007 Cadillac CTS-V General Discussion Discussion, Leaking coolant and smell in Cadillac CTS-V Series Forum - 2004 - 2007; Has anyone experienced this: Small loss of coolant along with antifreeze smell inside cabin. Sounds like a bad heater core ...
    Tom Paine is offline Cadillac Owners Member
    Aug 2004
    58
    Sounds like a bad heater core is what i guess. How difficlut is it to replace the heater core? (not much confidence in my dealer)
  2. #2
    Rolex's Avatar
    Rolex is offline Super Moderator
    Automobile(s): 2008 Nissan Titan, 1996 Jeep Wrangler
    Arkansas
    41
    12,034
    Re: Leaking coolant and smell
    It is almost certainly a bad heater core. The last one I had to replace wa in a GM truck, and it was a complete PITA but I got it done. It's usually in an akward and tight space beneath the dash. I'm sure it would be easier to do with the dash off but that was too much for me to try.
    The above post is my 2 cents....nothing more.
  3. #3
    OldRoadDawg's Avatar
    OldRoadDawg is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    Aug 2004
    NV
    1,908
    Quote Originally Posted by Tom Paine View Post
    Piece of cake. Just ask Bill @ Lindsay Cadillac
    I use this photo as part of my Halloween decorations.
    I know it scares the schitt out of me
  4. #4
    Nutz's Avatar
    Nutz is offline Cadillac Owners Connoisseur
    Automobile(s): 09 CTS-V a tuxedo with a jetpack!
    Oct 2007
    Northeast Ohio hammer down
    49
    2,460
    Quote Originally Posted by OldRoadDawg View Post
    That car looks like it just left a roadside bomb in Tikrit... WOW
  5. #5
    NormV is offline Cadillac Owners Connoisseur
    Automobile(s): XTS VSport-550+ lb-ft of torque, ATS 2.0T AWD HPTuners tuned
    Jun 2007
    OH-IO!
    2,648
    Tom, hard to believe it has been 2 years since I talked to you at Grattan with Audi Club! Didn't make it to any Mich tracks this year but did get 20 track days in. I should be making the 3 track your in 08.
    Take a flash light and check the belly pan under the radiator as they been know to leak in early models, unless you have had your replaced.
    Keep in touch.
    Norm
  6. #6
    Aug 2004
    58
    Norm. I thought you defected to a GTO? Did you return?
  7. #7
    Jun 2007
    OH-IO!
    2,648
    Right, and back again. Some of us have had two V's. Got another project V when I wear out the current one.
    Norm
  8. #8
    bpitas's Avatar
    bpitas is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac CTS-V
    May 2007
    Winchester, MA
    46
    389
    Make sure it's actually the heater core, there was a problem with the bottom radiator hose connection on the '04s that's a known problem. Just had my radiator replaced under warranty for this - the first time they looked at it, they actually thought it was a "misrouted hose", and then when they were replacing my engine mount they realized it was the radiator outlet separating from the tank.
    I noticed the leak after a day at the strip so I assumed it was something bad, but it was probably just from the engine torquing over with my blown motor mounts. I could see some coolant on the plastic under the front, and the usual smell inside the car. Just cuz you smell it in the car doesn't necessarily mean it's the heater core, you might just be pulling that smell in through the cabin filter.
    -B
  9. Remove Advertisements
