| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Friends don't let friends drive with bad motor mounts...
11-15-07, 06:50 PM
|  | Cadillac Owners Enthusiast | | Join Date: Jul 2006 Location: Manhattan | | | Friends don't let friends drive with bad motor mounts... I had forgotten what a difference these baby's make to the feel of the car. Replace em if you need to. Cadillac would not replace them for me because it would require the removal of my headers. However my service writer gave me new ones (gratis) and I got them replaced on my own. Since my engine shop had to take the long tubes off anyway, they replaced the Kooks flimsy gaskets with higher quality steel ones.
No ticking, no leaks, just the roar of the Magnaflows!!!
__________________ '04 Black Raven CTS-V | TTP XFI cam 228/230-115LSA | ASP UDP| Kooks Headers w/cats | LS7 Clutch | Magnaflow | K&N CAI | TTP Tune | 412RWHP/377RWTQ | QA1 Shocks | Hotchkis | Ground Control 550F/600R | ZO6 End Links | UUC Shifter w/bushings | UUC Leather V-Knob | Cross-drilled /Slotted Rotors | S.S. Brake Lines | Chrome Stock Wheels | HID Fogs-6000k | Valentine 1 w/concealed display | Corvette FRCs | Blacked-out Rear | iPod adapter | Infinity Kappas | JL Audio W7 Sub + 500/1 Amp |
11-15-07, 06:53 PM
|  | Moon Parasite Cadillac(s): 2006 STS-V BlackonBlack / 2005 CTS-V Redline (traded in) | | Join Date: Dec 2005 Location: D/FW Tejas | | | Re: Friends don't let friends drive with bad motor mounts... Cool ! Thanks for posting the pic of them  |
11-15-07, 06:58 PM
|  | Cadillac Owners Enthusiast Cadillac(s): CTS-V | | Join Date: Nov 2006 Location: St. Louis, Mo. | | | Re: Friends don't let friends drive with bad motor mounts... HMMM, HMMM, HMMM (twiddling thumbs) ...Luke and UUC making up the urethane mounts.
Feff |
11-15-07, 07:03 PM
| | Cadillac Owners Enthusiast Cadillac(s): CTS-V SERIES | | Join Date: Jul 2006 Location: BROOKLYN Age: 22 | | | Re: Friends don't let friends drive with bad motor mounts... which dealer? |
11-15-07, 07:19 PM
|  | Cadillac Owners Enthusiast | | Join Date: Jul 2006 Location: Manhattan | | | Re: Friends don't let friends drive with bad motor mounts... Quote:
Originally Posted by 1QUICKV which dealer? | What's up! North Bay Cadillac in Roslyn, NY. |
11-15-07, 10:39 PM
| | Cadillac Owners Enthusiast Cadillac(s): '05 CTS-V | | Join Date: Aug 2007 Location: On WESTPAC | | | Re: Friends don't let friends drive with bad motor mounts... Stupid question, but what sort of symptoms does one look for to know if your engine mounts are bad? From what I can see (I've had the car up on a lift a few times) mine are fine. But when I shut the engine off, it shakes quite a bit, which I've seen others mention here as a sign that the mounts are bad.
__________________ '05 Stealth Grey CTS-V, GM Accessory wheels w/Falken FK452s, Hyperblack Rota Torques w/Bridgestone RE-01Rs, KW Variant3s, Magnaflow exhaust, UUC shifter (not worth the trouble), Specter cradle bushings (somewhat useful), BMR pinion brace, and more to come I'm sure... |
11-15-07, 11:00 PM
|  | Cadillac Owners Connoisseur Cadillac(s): BANK OWNED!! CTSV & EXT | | Join Date: Feb 2006 Location: Asheboro, NC Age: 28 | | | Re: Friends don't let friends drive with bad motor mounts... Quote:
Originally Posted by Feffman HMMM, HMMM, HMMM (twiddling thumbs) ...Luke and UUC making up the urethane mounts.
Feff | Yep, they need to hurry it up. |
11-16-07, 12:30 AM
| | Cadillac Owners Fanatic Cadillac(s): 2004 CTS-V | | Join Date: Dec 2006 Location: Royal Oak, MI | | | Re: Friends don't let friends drive with bad motor mounts... Quote:
Originally Posted by AAIIIC Stupid question, but what sort of symptoms does one look for to know if your engine mounts are bad? From what I can see (I've had the car up on a lift a few times) mine are fine. But when I shut the engine off, it shakes quite a bit, which I've seen others mention here as a sign that the mounts are bad. | From my experience:
-Load rattling when turning off the car (a little is normal)
-Clutch chatter when accelerating from a stop
-In my case the extra movement also caused the Corsa to hit on the heat shield causes a very strange noise during hard accels.
The GM service manual has check engine mounts second on the list for clutch chatter. (First on the list is oil on surface of clutch or fw) |
11-16-07, 12:56 AM
| | Cadillac Owners Fanatic Cadillac(s): 05 Black CTS-V | | Join Date: Oct 2007 Location: Central FL | | | Re: Friends don't let friends drive with bad motor mounts... I am getting an engine shake when I turn the car off that may be normal, but I would like to check the motor mounts. I just got the car and am not really familiar where everything is. Could somebody post a pic of the best places to look to see if the motor mounts are indeed leaking? |
11-16-07, 03:48 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 05 Mallett 427 CTS-V | | Join Date: Aug 2006 Location: SoCal | | | Re: Friends don't let friends drive with bad motor mounts... Was the top mount (in pic) bad too?
It's hard to tell from the pic.
__________________ 05 Mallett [M] CTS-V: 499WHP 497WTQ | 427 C5R Block | Ron Davis 2-Row Rad | [M] Oi1 Cooler | P&P LS6 Heads | FAST 78 IM | LPE CAI | SW 1-3/4" Headars | RT Hi Flow Cats | B&B 3" Exhaust | RPS Street-Twin Clutch | McLeod Billet Slave Cyl | [M] ST Shifter | RPM Trans Level-V Build | MN6 Geer Ratio Conv | Cryo Treated Diff | GM T2 Diff Cooler | [M] Anti Wheel Hop Kit | FG2 Shocks | SS Brake Limes | Slotted Cryo Rotars | [M] Modified Front Spindles | 275-35-19 PS2 F&R | [M] 19x9 Billet Whels F&R | |
11-16-07, 09:29 AM
|  | Cadillac Owners Fanatic Cadillac(s): 04' Raven | | Join Date: Apr 2006 Location: Pa. | | | Re: Friends don't let friends drive with bad motor mounts... Easiest ways to tell if they are bad is if you have shake and if you look under the car by the oil pan, if you see what looks to be like stained splattered oilish kinda looking stuff around there, Its a leaky motor mount. |
11-17-07, 12:08 AM
| | Cadillac Owners Fanatic Cadillac(s): 05 Black CTS-V | | Join Date: Oct 2007 Location: Central FL | | | Re: Friends don't let friends drive with bad motor mounts... Thanks! I'll check for leaks tomorrow when I install my cags eliminator. |
11-17-07, 08:09 AM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 41 | | | Re: Friends don't let friends drive with bad motor mounts... Trukk won the award for "worst motor mount I ever saw".
I have pics at work, one of them is posted on here somewhere.
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
11-17-07, 02:00 PM
|  | Cadillac Owners Master Cadillac(s): '05 CTS-V | | Join Date: Jul 2004 Location: Elkridge, MD Age: 37 | | | Re: Friends don't let friends drive with bad motor mounts... Quote:
Originally Posted by ewill3rd Trukk won the award for "worst motor mount I ever saw".
I have pics at work, one of them is posted on here somewhere. |  DOH. Yes I am in the CTS-V Motor Mount hall of shame
I can't wait for UUC to crank out their new motor & tranny mounts, and rear diff bushing.
-Chris
__________________ 2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq |
11-17-07, 03:37 PM
|  | <10 poasts, CF newbie Cadillac(s): 2007 CTS-V Thunder Gray w/ Lt Gray interior | | Join Date: Mar 2007 Location: Sunny CA. Age: 43 | | | Re: Friends don't let friends drive with bad motor mounts... What a blowout, nice Trukk.
__________________ Friendship is like peeing your pants, everyone can see it, but only you can feel it's true warmth. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
