Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: Oil Pump Failure?
Old 11-12-07, 10:25 PM
rdjiv's Avatar
CTS-V Owner
Cadillac(s): 2007 Cadillac CTS-V
View rdjiv's Photo Album
Casino Cash: $6487
Oil Pump Failure?
Ok, I need some help with this. I drove last weekend to San Diego (about a 7 hour trip) and parked the V. No problems during the trip - the car ran great. It remained parked for about 24 hours before I started her back up. When I did, the "No Oil Pressure-Shut Engine Off" alarm came up and the oil pressure display read 0. My suspicions were either a bad oil pressure sensor or oil pump. Dealer said oil pump was failing intermittently. Has anyone else had this happen to them? Any advice?
I also discovered that like most everyone else, I too have a bad rear differential (the oil was leaking during the drive and depositing on the rear end). Luckily that was caught before it failed at 80mph.
Now the car is stuck in San Diego while i get to drive the loaner, an '08 CTS, for the next week.
  #2 (permalink)
Old 11-12-07, 10:50 PM
darkman's Avatar
Cadillac(s): 2005 CTS-V
View darkman's Photo Album
Casino Cash: $12594
Re: Oil Pump Failure?
Oil pump failure is not a routine problem. If the dealer is making the repair by all means let them. There are some other condions that can cause a loss in oil pressure that are more serious than just an oil pump. It can, for example, indicate excessive bearing clearances within the engine (rod, crank, cam) or even poroous or restricted oil galleries.
  #3 (permalink)
Old 11-12-07, 11:36 PM
heavymetals's Avatar
Cadillac(s): 05 maggied CTS-V, 03 maggied Z06
View heavymetals's Photo Album
Casino Cash: $19072
If you have no oil pressure you are gonna hear it
Mine did that (scared the sh*t out of me) after racing a Vette.
Was just a bad sensor, but it is a pain in the neck to get at.
Very easy if you remove the windshield wiper assy and facia.
I am so expensive I can't even afford to hire me....
  #4 (permalink)
Old 11-13-07, 10:30 AM
rdjiv's Avatar
CTS-V Owner
Casino Cash: $6487
thanks!
  #5 (permalink)
Old 11-13-07, 11:39 AM
tweeter81's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 2004 CTS-V
View tweeter81's Photo Album
Casino Cash: $13235
Sorry, I have to say it...
You just said "assy and facia" hahaha
2004 CTS-V
Mods: Lingenfelter CAI, OEM style spoiler, CCW SP600 wheels (19"x9" and 19"x10"), Toyo Proxes R888 (F: 235/35YR19 - R: 295/30YR19), Magnaflow Cat-back, UUC Shifter w/ Lindsay bushings, FG2 shocks, GC Coilover Kit (600f/650r), Hotchkis Swaybars, Custom FRCs, Kooks 1 3/4" Cermakromed LT Headers & HiFlo cats, ARP Header Studs, Granatelli 1200* Wires, NGK TR55ix Plugs, OC Autosports D&S Rotors, Hawk Pads, SS Brake Lines, 561 Wheelhop Kit, D.R.E. Dyno Tune = 351 hp/ 365 ft-lbs (corrected)
  #6 (permalink)
Old 11-13-07, 09:45 PM
JonCR96Z's Avatar
Cadillac(s): BANK OWNED!! CTSV & EXT
View JonCR96Z's Photo Album
Casino Cash: $3297139
While the oil pressure is down listen for any noise, it should be obvious.
  #7 (permalink)
Old 11-13-07, 09:51 PM
Cadillac(s): Sedan de Ville, CTS
View z06bigbird's Photo Album
Casino Cash: $5019
Sorry for your headaches. Remember: When you get lemons, make lemonade. Motor and rear have a problem, but tranny looks ok. 2 out of three isn't bad.
You also get to drive an 08.
Hope things work out for you.
  #8 (permalink)
Old 11-13-07, 09:59 PM
mlg mlg is offline
View mlg's Photo Album
Casino Cash: $622
been there , done that, long story but had same warning, caddy towed car to dealer , oil pump replaced, etc etc call me 423 773 9162 for full story
  #9 (permalink)
Old 11-13-07, 11:19 PM
View ssmith100's Photo Album
Casino Cash: $8726
Mine did the exact same (04 V) Drove it for four hours the day before, next day no oil pressure. They found a piece of rubber from the O-ring in the pick up tube. Apparently we aren't the only ones this has happened too. Replaced pump and haven't has any problems since.
Shane
  #10 (permalink)
Old 11-14-07, 10:25 PM
rdjiv's Avatar
CTS-V Owner
Casino Cash: $6487
Thanks for the info. Will get the V back on Friday with a hopefully fully fixed oil pump, replaced rear diff, and a bath. We'll see what the cause was.
  #11 (permalink)
Old 10-13-09, 01:04 PM
Cadillac(s): 2005 Cadillac CTS-V
View CTSVetteMark's Photo Album
Casino Cash: $325
What did this end up being? I brought my '05 CTS-V to the dealer to fix the standard leaky rear differential; when I went to pick the car up, NO oil pressure. They kept it for 2 weeks, said it was fixed, but when I start the car, NO oil pressure; after about 5 seconds pressure comes up to about 30 psi; should be 40-45 for sure. Ideas? How much is it to diagnose/fix the oil pump?
Thanks!
Tags: , ,
failure, oil, pump
Censor is OFF
