| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: How important to get alignment done right after swapping in FG2's?
10-31-07, 01:08 PM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | How important to get alignment done right after swapping in FG2's? Installing my FG2's this saturday. There is a very good highly reccomended perforamnce alignment shop close to where i'm doing it - but they arent open on saturday.
Assuming I can even get time off from work monday to go in, How bad will my car be behaving saturday night and all sunday?
Should I settle for a tire rack alignment or something of that nature as they will be open saturday?
Any better reccomendations in south florida (WPB, Boca raton, i'd even go jupiter or south to miami)?
thanks,
-J |
10-31-07, 01:22 PM
| | my name is Tiffany Cadillac(s): 05 CTS-V | | Join Date: Mar 2003 Location: San 'tone, TX | | | Re: How important to get alignment done right after swapping in FG2's? i dont think there's a clear answer....but i did get mine done. pay for a real alignment, too...not some quickie |
11-01-07, 02:18 AM
|  | Cadillac Owners Enthusiast Cadillac(s): CTS-V | | | | | Re: How important to get alignment done right after swapping in FG2's? To my knowledge, shocks don't change the geometry. You should not have to get an alignment just for changing shocks. That said, if you haven't had an alignment in a while, this would probably be a good time. As Urby sez, go get a good one, not a "toe and go". Find a shop that has a Hunter 6000 machine. Make sure they have the adapters for the V before you go there. Check the FAQ for the specs. |
11-01-07, 09:53 AM
| | Cadillac Owners Connoisseur Cadillac(s): Kooks,MOMO seats,C5 hubs,3489# | | Join Date: Jun 2007 Location: Ashland, Ohio | | | Re: How important to get alignment done right after swapping in FG2's? You don't need an alignment from switching out shocks.
Norm |
11-01-07, 10:53 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 05 Mallett 427 CTS-V | | Join Date: Aug 2006 Location: SoCal | | | Re: How important to get alignment done right after swapping in FG2's? Waiting till Monday to hit the good alignment shop sounds like a good idea.
You should be ok in the mean time.
__________________ 05 Mallett [M] CTS-V: 499WHP 497WTQ | 427 C5R Block | Ron Davis 2-Row Rad | [M] Oi1 Cooler | P&P LS6 Heads | FAST 78 IM | LPE CAI | SW 1-3/4" Headars | RT Hi Flow Cats | B&B 3" Exhaust | RPS Street-Twin Clutch | McLeod Billet Slave Cyl | [M] ST Shifter | RPM Trans Level-V Build | MN6 Geer Ratio Conv | Cryo Treated Diff | GM T2 Diff Cooler | [M] Anti Wheel Hop Kit | FG2 Shocks | SS Brake Limes | Slotted Cryo Rotars | [M] Modified Front Spindles | 275-35-19 PS2 F&R | [M] 19x9 Billet Whels F&R | |
11-01-07, 12:14 PM
| | Cadillac Owners Enthusiast Cadillac(s): Cadillac | | | | | Re: How important to get alignment done right after swapping in FG2's? Quote:
Originally Posted by calicadi To my knowledge, shocks don't change the geometry. You should not have to get an alignment just for changing shocks. That said, if you haven't had an alignment in a while, this would probably be a good time. As Urby sez, go get a good one, not a "toe and go". Find a shop that has a Hunter 6000 machine. Make sure they have the adapters for the V before you go there. Check the FAQ for the specs. | what adapter? |
11-01-07, 12:34 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 05 Mallett 427 CTS-V | | Join Date: Aug 2006 Location: SoCal | | | Re: How important to get alignment done right after swapping in FG2's? All the good alignment shops I know are "old school".
No hunter rigs for those guys.
I long ago got sick of bad alignments where the tech points to his Hunter readout saying the alignment is good.  |
11-02-07, 10:01 PM
| | Cadillac Owners Member Cadillac(s): 2004 Cts V | | Join Date: Oct 2007 Location: Boston, MA | | | Re: How important to get alignment done right after swapping in FG2's? According to Hunter and a few other alignment machine companies, "caster/camber" are not adjustable on the V's but there is ALWAYS a way to adjust it, whether it be slightly enlarging the holes in the strut/whatever. Since the c/c is not adjustable on these cars from the factory, technically I would just do a toe and go on it, but from my experience at my shop, that is not always the case. Poor caster/camber will lead to all sorts of poor tread wear patterns on the tires and such. I would have it checked out to be safe.
As far as a shop goes, I would chose a reputable one over townfair/ntb etc. Just my opinion though. *Nothing against ANYONE who may work at those places  * |
11-03-07, 02:16 AM
|  | Cadillac Owners Enthusiast Cadillac(s): CTS-V | | | | | Re: How important to get alignment done right after swapping in FG2's? Quote:
Originally Posted by ZEUSROTTY what adapter? | Call Speed Inn at 510-259-1464. Speak with Dave or Les. They'll explain it better, but I believe there are special pieces for four-wheel, independent suspensions that are attached to the car to get exact measurements and one size does not fit all. Certain cars, like our V's, need special bits. | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
