Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: VIN checks here...READ POST #1 BEFORE ASKING
  #1381 (permalink)
Old 09-16-08, 05:15 PM
lusterblade's Avatar
Cadillac Owners Enthusiast
View lusterblade's Photo Album
Casino Cash: $6900
Re: VIN CHECKS here...and only here. Read first post.
Originally Posted by CadzillaTN View Post
thanks. Do you know if there a reason why my extd GMPP isn't showing on this list.....?
I believe only the OEM warranties show up on that list, but it does list your GMPP extended warranty under Service Contracts. I hid your policy number and name.
SERVICE CONTRACT
Policy Number : ***
Owner Name : ***
Description : 36/45000 GMPP MAJOR GUARD
Deductible Amount : $ 50
Inception Date : 07/18/2008
Expiration Date : 07/18/2011
Inception Odometer : 32508 miles
Expiration Odometer : 77508 miles
  #1382 (permalink)
Old 09-16-08, 06:05 PM
CadzillaTN's Avatar
Cadillac(s): 2004 CTS-V
View CadzillaTN's Photo Album
Casino Cash: $11155
thanks again
  #1383 (permalink)
Old 09-17-08, 01:26 PM
Cadillac(s): 08 Cadillac STS AWD Platinum Edition
View SwissSTS's Photo Album
Casino Cash: $4826
1G6DC67A870151319
thank you!
  #1384 (permalink)
Old 09-17-08, 04:28 PM
Casino Cash: $6900
Originally Posted by SwissSTS View Post
1G6DC67A870151319
thank you!
2007 STS V8
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/100000 IPC BUMPER TO BUMPER 03/02/2007 0 kilometres 03/02/2010 100000 kilometres
72/UNLIMITED IPC CORROSION 03/02/2007 0 kilometres 03/02/2013 Unlimited kilometres
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
05/19/2008 217352 # V1798 - 07204 - REPLACE FRONT AND REAR DIFFERENTIAL SEAL (SRX AWD, 17300 kilometres
09/28/2007 191868 # H0122 - FRONT BRAKE ROTOR REFINISHING 6493 kilometres
04/27/2007 186499 # N4862 - MODULE - DASH INTEGRATION - REPLACE 1811 kilometres
04/27/2007 186501 # N6626 - WIRING AND/OR CONNECTOR - THEFT DETERRENT - REPAIR OR REPL 1811 kilometres
04/27/2007 192489 # C9711 - INSTALL RUBBER HOSE (VACUUM LINE) ADJUSTER RAIL LEFT 1811 kilometres
04/27/2007 192492 # C9712 - INSTALL RUBBER HOSE (VACUUM LINE) ADJUSTER RAIL RIGHT 1811 kilometres
03/15/2007 165390 # E0420 - WHEEL - ONE - R&R OR REPLACE 381 kilometres
03/12/2007 163547 # N0100 - BATTERY - CHARGE AND TEST 26 kilometres
03/12/2007 168463 # C9722 - SPRAY LATCH ASSEMBLIES 26 kilometres
03/12/2007 168470 # C0631 - GRID, ELECTRIC BACK WINDOW DEFOGGER - REPAIR 26 kilometres
02/13/2007 159758 # B4300 - HANDLE AND REMOTE CONTROL, FRONT DOOR LOCK - RIGHT - R&R O 5 kilometres
12/15/2006 189723 T P0100 - LABEL / STICKER-REMOVE 5 kilometres
12/15/2006 189723 T P0104 - LOOSE ITEMS - BOX 5 kilometres
OPTION CODES
#XC
193 - EBONY
19I - BLACK INTERIOR TRIM
1SK - 1SK PACKAGE
30U - THUNDER GRAY
6SC - FRT LH COMPUTER SEL SUSP
7SC - FRT RH COMPUTER SEL SUSP
8HC - RR LH COMPUTER SEL SUSP
9HC - RR RH COMPUTER SEL SUSP
A26 - WINDOW EUROPEAN GLAZING, ALL
A45 - MEMORY SEAT ADJUSTER
A82 - HEAD RESTRAINT
AL0 - SENSOR INDICATOR, INFLATIBLE RESTRAINT PASS / CHILD PRES. DETECTOR
AL2 - POWER LUMBAR CONTROL
AP9 - TRUNK CARGO NET
AQ9 - SEAT FRT BKT, LUXURY
ARB - EQUIPMENT, BODY, STRUCTURE
AT8 - RESTRAINT PROVISIONS, CHILD RR SEAT, RR FACING
AX4 - RESTRAINT CONVERSION SEAT, MAN, EUROPEAN
AY0 - INFLATABLE RESTRAINT DRI & PASS
B20 - WOOD TRIM PACKAGE
B57 - ORNAMENTATION EXTRA DELUX
BAG - PARTS PKG EXPORT
CE1 - RAINSENSE WIPERS
CE4 - WASHER HEADLAMP, HIGH PRESSURE
CF5 - EXPRESS OPEN SUNROOF
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP
CT1 - COUNTRY BELGIUM
DD8 - MIRROR I/S R/V LT SENSITIVE
DL7 - MIRROR O/S LH / RH REMOTE CTRL POWER FOLDING COLOR
DT4 - ASHTRAY CIGARETTE LIGHTER
E5A - CHASSIS RETUNED
EXP - EXPORT
F55 - MAGNETIC RIDE CONTROL
FE3 - SPORT-TUNED SUSPENSION
GU5 - REAR AXLE 3.23 RATIO
IL3 - PREMIUM TUSCANY LEATHER SEATS
J56 - BREMBO PERFORMANCE BRAKES
JJA - PT DRESS SUBASSEMBLE
JJD - I/P SUBASSEMBLY INSTALLED
JJL - SUSPENSION FRT, NOT INSTALLED
JJM - SUSPENSION REAR, NOT INSTALLED
JNG - SHAFT PROPELLER PAINTED
K59 - ADAPTIVE CRUISE CONTROL
KA3 - HEATER ENGINE BLOCK 220V
KA6 - SEATS, REAR HEATED
KB6 - HEATED/VENTILATED FRONT SEATS
KC4 - NOT ON UNITS, CANCELLED PRIOR TO PRODUCTION PER S. JONGEWARD
KG4 - GENERATOR 150 AMP
LH2 - 4.6L NORTHSTAR V8 ENGINE
MAE - MARKETING AREA EUROPE
MX7 - ALL WHEEL DRIVE
MYB - TRANSMISSION, 6 SPD AUTOMATIC
N05 - LOCK CONTROL FUEL FILLER CAP
N31 - HEATED, WOOD STEERING WHEEL
NT4 - EMISSION SYSTEM EEC 05
NV7 - PREMIUM STEERING GEAR
P32 - 18" ALUMINUM PAINTED WHEEL
PB4 - LOCK CONTROL WHEEL
QAF - P255/45ZR18 ALL-SEASON BLKWALL
R7K - PROCESSING OPTION
R9I - SPA DEAL
T2J - EXPORT INTERIOR ORNAMENTATION
T43 - REAR SPOILER
T62 - LIGHTING DAYTIME RUNNING DELETE
T79 - LAMP FOG, RR
TR7 - HEADLAMPS LEVELING SYSTEM, AUTO
TT8 - HEADLAMPS HID, RH RULE OF ROAD
U03 - HORN NOISE EXPORT
U30 - INSTRUMENT CLUSTER, TACH, CLOCK
UA2 - THEFT DETERENT SYSTEM, EXPORT
UC2 - SPEEDOMETER INST. KILO & MILES, KILO ODOMETER
UHB - REMOTE KEYLESS ENTRY
UJ9 - INDICATOR, LOW TIRE PRESSURE
UV6 - HEAD UP DISPLAY
UY5 - SPEAKER SYSTEM 15, DELUXE
V08 - HEAVY-DUTY COOLING
V4X - PERFORMANCE PACKAGE
V76 - TOW HOOK
V78 - VEHICLE STATEMENT - DELETE
V92 - TRAILER PROVISION
VC5 - LABEL SHIPPING EXCEPT US/JAPAN
VG1 - CLEAR UNDERHOOD COMPOUND PROTECTOR
VG9 - EXTERIOR BODY WAX PROTECTION
VH5 - PLATE, VEHICLE IDENTIFICATION
VJ2 - LABEL, EXPORT HEADLAMP ADJUST
VL2 - COMPACT SPARE CAUTION LABEL
VL4 - LICENSE PLATE FRT MOUNTING PKG
VP6 - NOISE CONTROL
VR5 - SLOW VEHICLE WARNING MOUNTING
W11 - NAVIGATION DISC DATA NAV DATA
XA7 - WASHER NOZZLES, HEATED WINDSHIELDS
YQ6 - SOUND SYSTEM, AM/FM STUDIO SURROUND SOUND BOSE 5.1 WITH IN DASH 6 DISC DVD CHANGER AND DVD-BASED NAVIGATION
  #1385 (permalink)
Old 09-17-08, 08:56 PM
Cadillac(s): Cadillac
View staticuxo's Photo Album
Casino Cash: $525
1G6DN56S450125859
Thanks!
  #1386 (permalink)
Old 09-18-08, 11:17 AM
Cadillac(s): 04 CTS-V, 05 CTS Sprt/Lux
View blaausl10's Photo Album
Casino Cash: $9094
1G6DN57S040191189
1G6DN57S440188666
1G6DN57S140185398
Would you be able to run these vin #'s for me? Going to check them out this evening. Thank You!
  #1387 (permalink)
Old 09-18-08, 12:50 PM
Casino Cash: $6900
Originally Posted by blaausl10 View Post
1G6DN57S040191189
1G6DN57S440188666
1G6DN57S140185398
1G6DN57S040191189
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 08/02/2004 325 miles 08/02/2008 50325 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 08/02/2004 325 miles 08/02/2010 100325 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/02/2004 325 miles 08/02/2012 80325 miles
48/50000 FEDERAL EMISSION 08/02/2004 325 miles 08/02/2008 50325 miles
72/100000 LUXURY CERTIFIED PRE-OWNED LIMITED WARRANTY 08/02/2004 325 miles 08/02/2010 100325 miles
CLAIM HISTORY
05/14/2008 209571 # J3100 - RADIATOR REPLACEMENT 35166 miles
05/14/2008 209571 D J3100 - RADIATOR REPLACEMENT 35166 miles
05/14/2008 209571 # Z7902 - 2-DAY COURTESY TRANSPORTATION 35166 miles
05/14/2008 209571 # J5670 - MASS AIRFLOW SENSOR REPLACEMENT 35166 miles
10/05/2007 135504 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 32203 miles
10/05/2007 135504 # J5670 - MASS AIRFLOW SENSOR REPLACEMENT 32203 miles
09/18/2007 134803 # C4020 - TRIM ASSEMBLY, QUARTER - RIGHT - R&R OR REPLACE 31202 miles
09/18/2007 134803 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 31202 miles
09/06/2007 191863 # F2154 - BUSHING, REAR DIFFERENTIAL CARRIER SUPPORT OR MOUNT - REPL 31165 miles
09/06/2007 191863 # K2250 - COVER AND/OR GASKET, SHIFT DETENT - REPLACE 31165 miles
09/06/2007 191863 # Z7901 - 1-DAY COURTESY TRANSPORTATION 31165 miles
05/09/2007 025349 # Z7901 - 1-DAY COURTESY TRANSPORTATION 27897 miles
05/09/2007 025349 # J9994 - CUSTOMER CONCERN NOT DUPLICATED 27897 miles
05/09/2007 025349 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 27897 miles
08/17/2006 016276 # V1302 - 05004 - REPLACE SDM 25196 miles
08/17/2006 016276 # C8800 - INFLATABLE RESTRAINT STEERING WHEEL MODULE COIL REPLACEMEN 25196 miles
08/17/2006 016276 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 25196 miles
08/17/2006 016276 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 25196 miles
08/17/2006 016276 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 25196 miles
06/08/2006 117757 # F1518 - HALFSHAFT, REAR DRIVE - REAR - BOTH - R&R 22044 miles
06/08/2006 117757 # Z7901 - 1-DAY COURTESY TRANSPORTATION 22044 miles
05/22/2006 117004 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 21689 miles
05/22/2006 117004 # E3807 - FRONT SHOCK ABSORBER REPLACEMENT - BOTH SIDES 21689 miles
05/02/2005 400675 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 11270 miles
05/02/2005 400675 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 11270 miles
05/02/2005 400675 # Z7902 - 2-DAY COURTESY TRANSPORTATION 11270 miles
04/04/2005 100002 # E0431 - TIRE, GOODYEAR/DUNLOP - REPLACE 9677 miles
03/02/2005 403860 # E2020 - WHEEL ALIGNMENT MEASUREMENT 8537 miles
03/02/2005 403860 # Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 8537 miles
05/28/2004 134692 # A0690 - FENDER, FRONT - REFINISH/CLEAR COAT - RIGHT SIDE 11 miles
05/25/2004 134588 # E0201 - WHEEL - TWO - BALANCE 4 miles
05/12/2004 A91189 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
1G6DN57S440188666
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 09/01/2004 23 miles 09/01/2008 50023 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 09/01/2004 23 miles 09/01/2010 100023 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 09/01/2004 23 miles 09/01/2012 80023 miles
48/50000 FEDERAL EMISSION 09/01/2004 23 miles 09/01/2008 50023 miles
CLAIM HISTORY
07/24/2007 166677 0 M0017 - LUBE, OIL AND FILTER 31568 miles
07/24/2007 166677 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 31568 miles
04/02/2007 121063 # J1420 - FLYWHEEL (MANUAL TRANSMISSION) - REPLACE 28917 miles
04/02/2007 121063 # Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 28917 miles
03/22/2007 120638 # Z8012 - ROADSIDE SERVICE (LOCKOUT) 28336 miles
03/10/2007 K72677 # Z2085 - ROADSIDE SERVICE (PREMIUM) 28000 miles
11/08/2006 114162 # Z7410 - GOODWILL OIL CHANGE 26526 miles
11/08/2006 114162 # B1790 - WINDSHIELD WASHER NOZZLE HOSE REPLACEMENT 26526 miles
11/08/2006 114162 # C0040 - INSIDE REARVIEW MIRROR REPLACEMENT 26526 miles
11/08/2006 114162 # Z7903 - 3-DAY COURTESY TRANSPORTATION 26526 miles
06/19/2006 107243 # N6608 - WIRING AND/OR CONNECTOR - EMISSIONS SYSTEM - REPAIR OR REP 21550 miles
05/19/2006 105759 # H0127 - FRONT BRAKE ROTOR REPLACEMENT - BOTH 20916 miles
05/19/2006 105759 # K0040 - HYDRAULIC CLUTCH BLEEDING 20916 miles
03/03/2006 102186 # D3082 - HOSES AND/OR LINES, REFRIGERANT - COMPRESSOR DISCHARGE - R 18063 miles
03/03/2006 102186 # Z7904 - 4-DAY COURTESY TRANSPORTATION 18063 miles
01/17/2006 029508 # H0127 - FRONT BRAKE ROTOR REPLACEMENT - BOTH 16138 miles
01/17/2006 029508 # K0800 - DISC AND/OR CLUTCH COVER, CLUTCH - REPLACE 16138 miles
01/17/2006 029508 # Z7410 - GOODWILL OIL CHANGE 16138 miles
01/17/2006 029508 # N2215 - SWITCH - ENGINE OIL LEVEL INDICATOR SENDER - REPLACE 16138 miles
08/29/2005 094050 # Z7091 - NON-WARRANTY INCREMENTAL EXPENSE/WHOLESALE 9457 miles
08/15/2005 093440 # D1443 - DEFLECTOR, AIR (OUTLET VENT) - LEFT CENTER - REPLACE 9309 miles
08/15/2005 093440 # Z7902 - 2-DAY COURTESY TRANSPORTATION 9309 miles
08/15/2005 093440 # C3192 - TRIM, CENTER PILLAR - LEFT - UPPER - R&R OR REPLACE 9309 miles
08/05/2005 092997 # D1442 - DEFLECTOR, AIR (OUTLET VENT) - RIGHT CENTER - REPLACE 8059 miles
07/28/2005 092572 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 8058 miles
07/28/2005 092572 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 8058 miles
07/28/2005 092572 # R0760 - RADIO, REMOVE AND REPLACE 8058 miles
07/27/2005 092486 # H0127 - FRONT BRAKE ROTOR REPLACEMENT - BOTH 8058 miles
07/27/2005 092486 # V1302 - 05004 - REPLACE SDM 8058 miles
03/11/2005 085963 # J3260 - COOLANT RECOVERY RESERVOIR REPLACEMENT 7931 miles
03/11/2005 085963 # Z7901 - 1-DAY COURTESY TRANSPORTATION 7931 miles
01/27/2005 084131 # H0127 - FRONT BRAKE ROTOR REPLACEMENT - BOTH 6755 miles
01/27/2005 084131 # Z7901 - 1-DAY COURTESY TRANSPORTATION 6755 miles
01/27/2005 084131 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 6755 miles
05/05/2004 A88666 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
1G6DN57S140185398
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 03/31/2005 521 miles 03/31/2009 50521 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/31/2005 521 miles 03/31/2011 100521 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/31/2005 521 miles 03/31/2013 80521 miles
48/50000 FEDERAL EMISSION 03/31/2005 521 miles 03/31/2009 50521 miles
CLAIM HISTORY
05/28/2008 527700 # N3865 - HEADLAMP WASHER PUMP REPLACEMENT 46738 miles
12/10/2007 520363 # E0722 - TIRE PRESSURE INDICATOR SENSOR REPLACEMENT 40800 miles
12/10/2007 520363 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 40800 miles
12/20/2006 504155 # R0760 - RADIO, REMOVE AND REPLACE 29314 miles
11/30/2006 503254 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 28132 miles
08/25/2005 162270 # V1302 - 05004 - REPLACE SDM 6500 miles
08/25/2005 162270 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 6500 miles
03/31/2005 733326 # B4350 - KNOB, FRONT DOOR INSIDE LOCKING - RIGHT - REPLACE 3866 miles
03/31/2005 733326 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 3866 miles
03/24/2005 733042 # C3270 - GRILLE, SPEAKER - REPLACE 386 miles
05/07/2004 495328 # Z6999 - PDI RELATED FLUID ADDS 6 miles
04/26/2004 A85398 D Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 1 miles
04/26/2004 A85398 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
  #1388 (permalink)
Old 09-18-08, 01:23 PM
Casino Cash: $9094
Thank You for the quick response
  #1389 (permalink)
Old 09-19-08, 03:04 PM
Cadillac(s): 2006 Black Cadillac CTS 3.6L
View xrionx's Photo Album
Casino Cash: $1280
Can you help me?
1G6DP577360122764
  #1390 (permalink)
Old 09-19-08, 06:56 PM
View staynumz's Photo Album
Casino Cash: $1370
Thank you
1G6DC67A550191662
  #1391 (permalink)
Old 09-21-08, 01:25 PM
View shawnrwitt's Photo Album
Casino Cash: $2945
Anything you got : 1G6DN57S740156262
Thanks guys!!!
  #1392 (permalink)
Old 09-21-08, 10:50 PM
View your maker's Photo Album
Casino Cash: $8206
1G6DN57U060188331 could i get a v check please
  #1393 (permalink)
Old 09-22-08, 11:25 AM
Casino Cash: $6900
Originally Posted by xrionx View Post
Can you help me?
1G6DP577360122764
2006 CTS 3.6L V6 VVT
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 11/14/2005 161 miles 11/14/2009 50161 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 11/14/2005 161 miles 11/14/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 11/14/2005 161 miles 11/14/2013 80161 miles
48/50000 FEDERAL EMISSION 11/14/2005 161 miles 11/14/2009 50161 miles
CLAIM HISTORY
02/11/2008 573364 # V1777 - 07204 - REPLACE REAR DIFFERENTIAL SEAL ONLY 50841 miles
02/05/2008 T17307 # Z2084 - ROADSIDE SERVICE (FLAT TIRE) 50000 miles
10/31/2007 569091 # J6400 - EVAPORATIVE EMISSION CANISTER PURGE SOLENOID VALVE REPLACE 44332 miles
10/31/2007 569091 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 44332 miles
10/31/2007 569091 # Z7901 - 1-DAY COURTESY TRANSPORTATION 44332 miles
10/22/2007 568612 # C2399 - INSTRUMENT PANEL LOWER EXTENSION REPLACEMENT 44096 miles
10/22/2007 568612 # Z7901 - 1-DAY COURTESY TRANSPORTATION 44096 miles
05/29/2007 561708 # N0681 - BULBS, PARK AND TURN SIGNAL LAMP (LEFT) - REPLACE 39521 miles
02/20/2007 557123 # N0760 - TAIL LAMP BULB REPLACEMENT 33979 miles
01/24/2007 555742 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 32029 miles
01/24/2007 555742 # Z7902 - 2-DAY COURTESY TRANSPORTATION 32029 miles
06/27/2006 545382 # N0760 - TAIL LAMP BULB REPLACEMENT 17328 miles
04/06/2006 541040 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 12115 miles
08/31/2005 243855 I Z6999 - PDI RELATED FLUID ADDS 2 miles
08/26/2005 A22764 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
1SB - CTS STANDARD PACKAGE
1SZ - PREFERRED EQUIPMENT SAVINGS
334 - CASHMERE
33I - INTERIOR, CASHMERE
41U - BLACK RAVEN
6ML - SUSPENSION
7ML - SUSPENSION
8FW - COMP RR LH COMPUTER SEL SUSP
9FW - COMP RR RH COMPUTER SEL SUSP
AH8 - 10-WAY PWR. PASS. SEAT W/ PWR. LUMBAR
B18 - WOOD TRIM
DL5 - DECAL - ROADSIDE SERVICE INFO
DR5 - MIRROR O/S REMOTE L/H R/H
FE2 - SPORT SUSPENSION
FE9 - 50-STATE EMISSIONS
G80 - LIMITED SLIP AXLE
GU6 - AXLE REAR 3.42 RATIO
IL4 - TRIM INTERIOR DESIGN
JE2 - HIGH PERFORMANCE BRAKE LINING
JJA - PT DRESS SUBASSEMBLY INSTALLED
JL4 - STABILITRAK 2.0
JL9 - ANTILOCK BRAKE FRT & REAR
KA1 - HEATED FRONT SEATS
KG9 - GENERATOR 140 AMP
LY7 - 3.6L V6 VVT ENGINE
M82 - 5-SPEED AUTOMATIC TRANSMISSION
MX0 - MERCH 5-SPEED AUTO TRANSMISSION
N30 - STEERING WHEEL DELUXE
N93 - 17" POLISHED ALLOY WHEELS
NT7 - EMISSION - FEDERAL
QWW - P255/50R17 W-RATED TIRES
R6P - PREMIUM PAINT
R9N - LEATHER
SLM - STOCK ORDERS
TT6 - HIGH INTENSITY HEADLAMPS
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
U30 - INSTRUMENT CLUSTER,TACH,CLOCK
U57 - 8 SPEAKER SYSTEM
UA6 - THEFT-DETERRENT ALARM SYSTEM
UAV - DVD NAVIGATION SYSTEM, WITH ETR AM/FM STEREO, 6-DISC CD CHANGER, BOSE, XM SATELLITE RADIO & XM NAVTRAFFIC-SERVICE FEES EXTRA. 1ST 3 MONTHS INCL INCLUDES TWO FREE MAP UPDATES (REPLACES STD/OPT RADIO) (DELETES COMPASS IN MIRROR)
UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL. 1 YR SAFE & SOUND PLAN
UG1 - UNIVERSAL HOME REMOTE
V4W - CTS CONVERSION
V73 - VEHICLE STATEMENT USA/CANADA
Y41 - 3.6L V6 LUXURY PACKAGE: * MEMORY SEAT ADJUSTER * COMPASS IN ISRV MIRROR * 10-WAY POWER SEATS W/ LUMBAR * HEATED FRONT SEATS * UNIVERSAL HOME REMOTE * THEFT-DETERRENT ALARM SYSTEM
Y42 - 17" WHEEL SPORT PACKAGE: * 4-WHL INDEPENDENT SUSPENSION * STABILITRAK-STABILITY CONTROL * P225/50R17 W-RATED TIRES * 17" MACHINE FINISHED WHEELS * LIMITED SLIP DIFFERENTIAL * HIGH INTENSITY HEADLAMPS
  #1394 (permalink)
Old 09-22-08, 11:28 AM
Casino Cash: $6900
Originally Posted by staynumz View Post
Thank you
1G6DC67A550191662
2005 STS V8 LUXURY SPORTS SEDAN
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 07/26/2005 47 miles 07/26/2009 50047 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/26/2005 47 miles 07/26/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/26/2005 47 miles 07/26/2013 80047 miles
48/50000 CALIFORNIA EMISSIONS 07/26/2005 47 miles 07/26/2009 50047 miles
84/70000 CALIFORNIA SELECT COMPONENT 07/26/2005 47 miles 07/26/2012 70047 miles
CLAIM HISTORY
09/08/2008 192694 # N6612 - WIRING AND/OR CONNECTOR - EXTERIOR LIGHTING - REPAIR OR RE 23059 miles
12/24/2007 329675 # N0110 - BATTERY REPLACEMENT 20226 miles
12/24/2007 329675 # J5670 - MASS AIRFLOW SENSOR REPLACEMENT 20226 miles
12/24/2007 329675 # Y0075 - 06516 SYSTEM SOFTWARE UPGRADE - REPROGRAM ENGINE CONTROL M 20226 miles
12/24/2007 329675 # Z7903 - 3-DAY COURTESY TRANSPORTATION 20226 miles
09/08/2007 A19984 # Z2150 - ONSTAR ANALOG-TO-DIGITAL UPGRADE KIT - RETURN TO ACDELCO E 16940 miles
09/06/2007 319984 # Z2097 - ON-STAR ANALOG-TO-DIGITAL UPGRADE KIT - RETURN TO ACDELCO 16790 miles
08/22/2007 319984 # Z2096 - ONSTAR ANALOG-TO-DIGITAL UPGRADE KIT - INSTALL 16940 miles
01/26/2005 A91662 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
1SF - 1SF LUXURY PERFORMANCE PACKAGE *MULTI-DRIVER MEMORY SETTINGS *POWER ADJUSTABLE LUMBAR *HEATED/VENTILATED FRONT SEATS *HEATED REAR OUTBOARD SEATS *HEATED, WOOD STEERING WHEEL *EUCALYPTUS WOOD TRIM ON CENTER STACK, CONSOLE, IP, SHIFT KNOB, DOOR TRIM AND STRG WHEEL *BOSE 5.1 STUDIO SURROUND SOUND WITH IN DASH 6 DISC DVD CHANGER AND ADVANCED DVD NAVIGATION *XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA 1ST 3MO. INC *RAINSENSE WIPERS *HOMELINK GARAGE DOOR OPENER *AUTO DIMMING ISRV MIRROR (REPLACES STD ISRV MIRROR) *HIGH INTENSITY DISCHARGE (HID) HEADLAMPS *INTELLIBEAM AUTO HIGH BEAM CONTROL *HEADLAMP WASHERS *17" POLISHED ALUMINUM WHEELS *MICHELIN P235/50R17 FRONT P255/45R17 REAR V-RATED TIRES *TIRE PRESSURE MONITOR *MAGNETIC RIDE CONTROL *EXPRESS OPEN/CLOSE SUNROOF *REAR SPOILER *TRUNK CONVENIENCE NET PERFORMANCE FEATURES: *LIMITED SLIP DIFFERENTIAL (N/A WITH ALL WHEEL DRIVE) *4-WHL. PERFORMANCE DISC BRAKES WITH ABS *PERFORMANCE COOLING PACKAGE
322 - CASHMERE
32I - INT TRIM MED DK CASHMERE
61U - SAND STORM
6SG - COMPONENT SUSPENSION
7SG - COMPONENT SUSPENSION
8HC - COMPONENT SUSPENSION
9HC - COMPONENT SUSPENSION
A45 - MULTI-DRIVER MEMORY SETTINGS
AP9 - TRUNK CONVENIENCE NET
B20 - EUCALYPTUS WOOD TRIM ON CENTER STACK, CONSOLE,IP, SHIFT KNOB, DOOR TRIM AND STRG WHEEL
CE4 - HEADLAMP WASHERS
CF5 - EXPRESS OPEN/CLOSE SUNROOF
DD8 - AUTO DIMMING ISRV MIRROR
DR2 - O/S REARVIEW PWR, HEATED MIRRS
F55 - CVRTD MAGNETO RHEOLOGICAL
FE3 - MAGNETIC RIDE CONTROL
G80 - LIMITED SLIP DIFFERENTIAL
GU5 - AXLE REAR, 3.23 RATIO
IL2 - TRIM INTERIOR DESIGN
JE5 - 17" PERFORMANCE BRAKES
K14 - FILTER, AIR, AUTO RECIRCULATING
KA6 - HEATED SEATS, REAR
KG4 - 150 AMP GENERATOR
LH2 - 4.6L NORTHSTAR V8 VVT 320 HP
M22 - 5-SPEED AUTO W/DRV SHIFT CONTRL
NC1 - EMISSIONS SYSTEM CALIFORNIA,LEV
Q11 - MICHELIN P235/50R17 FRONT P255/45R17 REAR V-RATED TIRES
Q13 - 17" POLISHED ALUMINUM WHEELS
R7K - HURRICANE EXPEDITING
SLM - STOCK ORDERS
T43 - REAR SPOILER
TQ5 - INTELLIBEAM AUTO HIGH BEAM CONTROL
TT6 - HIGH INTENSITY DISCHARGE (HID) HEADLAMPS
U2K - XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT. SERVICE FEE EXTRA 1ST 3MO. INC
UE1 - ONSTAR SYSTEM INCLUDES 1 YR DIRECTIONS & CONNECTIONS
UG1 - HOMELINK GARAGE DOOR OPENER
UJ6 - TIRE PRESSURE MONITOR
UY5 - 15 SPEAKER SYSTEM
V09 - PERFORMANCE COOLING PACKAGE
V4X - STS CONVERSION V8
VG6 - CALIF, 5 MPH BUMPER LABEL
YF5 - 50-STATE EMISSIONS
YQ4 - BOSE 5.1 STUDIO SURROUND SOUND WITH IN DASH 6 DISC DVD CHANGER AND ADVANCED DVD NAVIGATION
  #1395 (permalink)
Old 09-22-08, 11:30 AM
Casino Cash: $6900
Thanks guys!!!
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 02/12/2004 26 miles 02/12/2008 50026 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 02/12/2004 26 miles 02/12/2010 100026 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 02/12/2004 26 miles 02/12/2012 80026 miles
48/50000 FEDERAL EMISSION 02/12/2004 26 miles 02/12/2008 50026 miles
CLAIM HISTORY
10/03/2007 027581 # R0820 - AMPLIFIER, RADIO - REPLACE 43213 miles
10/03/2007 027581 # B7280 - HEADLAMP - AIM 43213 miles
07/31/2007 025547 # C7210 - COVER, REAR SEAT BACK CENTER ARMREST - R&R OR REPLACE 41098 miles
07/31/2007 025547 # C6690 - HEADREST AND/OR COVER, FRONT SEAT - PASSENGER - R&R OR REP 41098 miles
11/17/2006 255301 # N4187 - INSTRUMENT CLUSTER-ASSEMBLY RETURN TO AC DELCO ESC 36822 miles
11/17/2006 255301 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 36822 miles
11/16/2006 255301 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 36822 miles
11/16/2006 255301 # N4180 - INSTRUMENT CLUSTER REPLACEMENT 36822 miles
11/16/2006 255301 # Z7904 - 4-DAY COURTESY TRANSPORTATION 36822 miles
11/16/2006 255301 # R0760 - RADIO, REMOVE AND REPLACE 36822 miles
11/16/2006 255301 # E0032 - CAP, WHEEL CENTER - FRONT - REPLACE 36822 miles
05/24/2006 246570 # Z7902 - 2-DAY COURTESY TRANSPORTATION 31192 miles
05/24/2006 246570 # C2860 - FRONT FLOOR CONSOLE REPLACEMENT 31192 miles
04/24/2006 245110 # C3441 - HANDLE, REAR DOOR INSIDE PULL - LEFT - R&R OR REPLACE 29245 miles
04/24/2006 245110 # K2720 - TRANSMISSION REPLACEMENT 29245 miles
04/24/2006 245110 # C3241 - FRONT SIDE DOOR PULL HANDLE REPLACEMENT - LEFT SIDE 29245 miles
04/24/2006 245110 # Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 29245 miles
04/24/2006 245110 # C3240 - FRONT SIDE DOOR PULL HANDLE REPLACEMENT - RIGHT SIDE 29245 miles
04/24/2006 245110 # C3440 - HANDLE, REAR DOOR INSIDE PULL - RIGHT - R&R OR REPLACE 29245 miles
10/18/2005 236855 # K2753 - GEAR - 2ND SPEED GEAR - R&R OR REPLACE 19746 miles
10/18/2005 236855 # Z7909 - GAS/FUEL COURTESY TRANSPORTATION REIMBURSEMENT 19746 miles
10/18/2005 236855 # V1302 - 05004 - REPLACE SDM 19746 miles
10/18/2005 236855 # Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 19746 miles
03/01/2005 226473 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 12423 miles
03/01/2005 226473 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 12423 miles
03/01/2005 226473 # Z7903 - 3-DAY COURTESY TRANSPORTATION 12423 miles
03/01/2005 226473 # R0950 - RADIO REAR SIDE DOOR SPEAKER REPLACEMENT - RIGHT SIDE 12423 miles
01/30/2004 A56262 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES 1SA - CTS STANDARD PACKAGE
41U - BLACK RAVEN
6MH - COMP FRT LH COMPUTER SEL SUSP
703 - LIGHT NEUTRAL
70I - LIGHT NEUTRAL
7MH - COMP FRT RH COMPUTER SEL SUSP
8GW - SUSPENSION
9GW - SUSPENSION
AM9 - SPLIT-FOLDING REAR SEAT
DD8 - MIRROR AUTO DAY/NIGHT I/S R/V
E2C - RAPID DELIVERY SYSTEM
FE4 - SUSPENSION
GT4 - AXLE REAR 3.73 RATIO
IL3 - TRIM INTERIOR DESIGN
J56 - BRAKES, ANTILOCK
LS6 - LS6 5.7L 400 HP V8 ENGINE
M12 - MANUAL TRANS
MN6 - TREMEC 6-SPEED MANUAL TRANS
N34 - STEERING WHEEL, LEATHER
NT9 - EMISSION - FEDERAL
P32 - WHEEL 18" ALUMINUM
PDL - LUXURY PACKAGE
QKR - P245/45R18 ALL SEASON BW
R8X - FLEET GUARANTEED DELIVERY PGRM
R9Z - POMS EXPEDITE-SOLD ORDERS/TSE
SLL - SOLD ORDERS
U2K - XM SATELLITE RADIO-100 CHANNELS OF GO ANYWHERE ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL
UA6 - THEFT DETERENT SYSTEM
UAV - DVD NAVIGATION SYSTEM INCL: XM SATELLITE RADIO-100 CHANNEL COAST TO COAST DIGITAL SOUND (SUBSCRIPTION CHARGES EXTRA- DELETES COMPASS IN MIRROR)
UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1YR SAFE & SOUND PLAN
UG1 - UNIVERSAL GARAGE DOOR OPENER
VM3 - LABEL-FRT & RR 5 MPH BUMPER
Tags: , , , , ,
carfax, checks, favor, hereand, hereread, post, read, vin
Censor is OFF
