Originally Posted by Jbone5237 I just bought a 2004 SRX. I should have done this first.
Can you run an equipment list and warranty info on this VIN please, and I'm wondering if the VIN identifies RWD vs AWD.
1GYEE637340143852
Thanks,
J |
I believe this vehicle is RWD, but I could be wrong.
2004 SRX-V6 CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
05/25/2007 096378 # B1791 - HOSES, NOZZLES OR STOPS, WIPER REAR - REPAIR OR REPLACE 34261 miles
09/26/2006 227130 # E8622 - HOSES, POWER STEERING HYDRAULIC - PRESSURE - REPLACE 26368 miles
09/26/2006 227130 # Z7903 - 3-DAY COURTESY TRANSPORTATION 26368 miles
05/22/2006 282098 # J6372 - SENSOR, OXYGEN (ENGINE CONTROL) - REPLACE 23086 miles
05/22/2006 282098 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 23086 miles
05/22/2006 282098 # Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 23086 miles
05/22/2006 282098 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 23086 miles
02/22/2006 214300 # N6604 - WIRING AND/OR CONNECTOR - IGNITION SYSTEM - REPAIR OR REPL 20320 miles
02/22/2006 214300 # Z7901 - 1-DAY COURTESY TRANSPORTATION 20320 miles
08/15/2005 204317 # D3040 - SEALS, REFRIGERANT O-RING - COMPRESSOR MANIFOLD - REPLACE 14210 miles
08/15/2005 204317 # Z7901 - 1-DAY COURTESY TRANSPORTATION 14210 miles
07/06/2005 202139 # V1318 - 05018 - F/CMVSS NONCOMPLIANCE - ELECTRONIC THROTTLE CONTRO 13097 miles
07/06/2005 202139 # V1321 - 05524 - REPROGRAM ECM 13097 miles
07/06/2005 202139 # V1302 - 05004 - REPLACE SDM 13097 miles
07/06/2005 202139 # Z7901 - 1-DAY COURTESY TRANSPORTATION 13097 miles
03/25/2004 150725 # B9718 - REAR STOP LAMP BEZEL TO LIFT GATE - RR 25 miles
12/15/2003 A43852 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
AH8 - 8-WAY POWER PASSENGER SEAT
AM0 - THIRD ROW POWER SEAT
AY0 - INFLATABLE RESTRAINT DRI & PASS
B19 - BURLED WALNUT WOOD TRIM
C4R - GVW RATING 6,008 LBS
DD7 - ELECTROCHROMIC ISRV MIRROR
DR2 - ELECTROCHROMIC OSRV DRIVER MIRROR
GT4 - AXLE REAR 3.73 RATIO
JE5 - POWER ANTILOCK BRAKE SYSTEM
JJA - PT DRESS SUBASSEMBLY INSTALLED
KA1 - HEATED FRONT SEATS
LY7 - 3.6L V6 VVT ENGINE 260 HP
M82 - 5-SPEED AUTOMATIC
N30 - STEERING WHEEL DELUXE
Q15 - P235/65R17 FRT & P255/60R17 RR ALL-SEASON, BLACKWALL TIRES
UA6 - THEFT DETERRENT SYSTEM
UG1 - HOMELINK GARAGE DOOR OPENER
U2S - AUDIO SYSTEM WITH IN-DASH 6 CD CHANGER
U66 - SPEAKER SYSTEM 7, CUSTOM
VG8 - NOTICE TO BUYER LABEL
V73 - VEHICLE STATEMENT
YD5 - SPRING FRT BASE EQUIP, PROC OPT
YF5 - 50-STATE EMISSIONS
1SZ - SPRING SPECIAL VALUE DISCOUNT
132 - LIGHT GRAY
67U - LIGHT PLATINUM
8GJ - COMPONENT RR LH COMP SEL SUSP
AL2 - POWER ADJUSTABLE LUMBAR
AQ9 - LUXURY FRONT BUCKET SEATS
A45 - MULTI-DRIVER MEMORY SETTINGS
CJ2 - DUAL ZONE CLIMATE CONTROL
C57 - REAR AIR CONDITIONING
DL5 - DECAL - ROADSIDE SERVICE INFO
FE1 - 4-WHEEL INDEPENDENT SUSPENSION
IL2 - TRIM INTERIOR DESIGN
JF4 - POWER ADJUST PEDALS
JL4 - STABILITRAK
KG4 - 150 AMP GENERATOR
MX0 - 5-SPEED AUTOMATIC
NU1 - EMISSION - CALIFORNIA
N93 - WHEEL 17 X 7.5, ALUMINUM
SLM - STOCK ORDERS
UE1 - 1-YR ONSTAR DIRECT/CONN SVC
UJ6 - TIRE PRESSURE MONITOR
U30 - CLUSTER INST, TACH, CLOCK
VG6 - LABEL INFORMATION BUMPER, IMPACT, 5 MPH, CALIFORNIA
VK3 - LICENSE PLATE FRT MOUNTING PKG
YB6 - AXLE(BASE EQUIP) PROCESSING OPT
YD6 - SPRING RR, BASE EQUIP, PROC OPT
1SB - LUXURY PACKAGE * BURLED WALNUT WOOD TRIM * AUDIO SYSTEM WITH IN-DASH 6 CD CHANGER * REAR AIR CONDITIONING * TIRE PRESSURE MONITORING * RECONFIGURABLE STORAGE * MULTI-DRIVER MEMORY SETTINGS * 8-WAY POWER PASSENGER SEAT * HEATED FRONT SEATS * POWER ADJUST PEDALS * ELECTROCHROMIC OSRV DRIVER MIRROR * HOMELINK GARAGE DOOR OPENER
13I - INTERIOR TRIM LIGHT GRAY
6NA - COMPONENT FRT LH COMP SEL SUSP
7NA - COMPONENT FRT RH COMP SEL SUSP
9GJ - COMPONENT RR RH COMP SEL SUSP
