Originally Posted by Gerbonium 1
1G6DN56S350104260
1G6DN56S550162838
3
1G6DN57S440171700
Thanks in advance! |
1G6DN56S350104260 APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 07/06/2004 21 miles 07/06/2008 50021 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/06/2004 21 miles 07/06/2010 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/06/2004 21 miles 07/06/2012 80021 miles
48/50000 CALIFORNIA EMISSIONS 07/06/2004 21 miles 07/06/2008 50021 miles
84/70000 CALIFORNIA SELECT COMPONENT 07/06/2004 21 miles 07/06/2011 70021 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
10/22/2007 218737 # C8870 - INFLATABLE RESTRAINT PASSENGER SEAT SUPPRESSION MODULE REP 50006 miles
10/22/2007 218737 # Z7901 - 1-DAY COURTESY TRANSPORTATION 50006 miles
10/03/2007 218141 # C2021 - SUNSHADE REPLACEMENT - LEFT SIDE 49581 miles
10/03/2007 218141 # Z2097 - ON-STAR ANALOG-TO-DIGITAL UPGRADE KIT - RETURN TO ACDELCO 49581 miles
10/03/2007 218141 0 M0017 - LUBE, OIL AND FILTER 49581 miles
10/03/2007 218141 # Z2096 - ONSTAR ANALOG-TO-DIGITAL UPGRADE KIT - INSTALL 49581 miles
10/03/2007 218141 # Z7901 - 1-DAY COURTESY TRANSPORTATION 49581 miles
07/06/2007 214956 # N0761 - BULBS, STOP, TAIL, AND TURN LAMP (LEFT) - REPLACE 45587 miles
07/06/2007 214956 0 M0017 - LUBE, OIL AND FILTER 45587 miles
04/06/2007 211713 0 M0017 - LUBE, OIL AND FILTER 42730 miles
01/02/2007 208098 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 39045 miles
12/15/2006 207525 # C7200 - REAR SEAT ARMREST REPLACEMENT 37595 miles
12/15/2006 207525 0 M0017 - LUBE, OIL AND FILTER 37595 miles
12/15/2006 207525 # Z7901 - 1-DAY COURTESY TRANSPORTATION 37595 miles
10/13/2006 205110 # B5500 - LOCK, REAR COMPARTMENT LID - R&R OR REPLACE 35142 miles
10/13/2006 205110 0 M0017 - LUBE, OIL AND FILTER 35142 miles
10/13/2006 205110 # F3030 - BUSHING, REAR DIFFERENTIAL DAMPING - RIGHT - REPLACE 35142 miles
10/13/2006 205110 # Z7901 - 1-DAY COURTESY TRANSPORTATION 35142 miles
06/30/2006 201176 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 29777 miles
06/30/2006 201176 # R0760 - RADIO, REMOVE AND REPLACE 29777 miles
06/30/2006 201176 # C1081 - WEATHERSTRIP - FRONT DOOR OPENING - LEFT - ALIGN OR REPLAC 29777 miles
06/30/2006 201176 # B5500 - LOCK, REAR COMPARTMENT LID - R&R OR REPLACE 29777 miles
06/30/2006 201176 0 M0015 - LUBE, OIL AND FILTER 29777 miles
06/30/2006 201176 # Z7901 - 1-DAY COURTESY TRANSPORTATION 29777 miles
03/02/2006 196638 0 M0017 - LUBE, OIL AND FILTER 23417 miles
10/27/2005 191598 # N0110 - BATTERY - ONE - REPLACE 18132 miles
10/27/2005 191598 # Z7903 - 3-DAY COURTESY TRANSPORTATION 18132 miles
10/23/2005 844227 # Z2080 - ROADSIDE SERVICE (TOWING) 12000 miles
10/19/2005 191270 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 17793 miles
10/19/2005 191270 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 17793 miles
10/19/2005 191270 # J6360 - POWERTRAIN CONTROL MODULE REPLACEMENT 17793 miles
10/19/2005 191270 # J4100 - GENERATOR ASSEMBLY - REPLACE 17793 miles
10/19/2005 191270 # R0760 - RADIO, REMOVE AND REPLACE 17793 miles
10/19/2005 191270 # N3860 - WINDSHIELD WASHER PUMP REPLACEMENT 17793 miles
10/13/2005 191270 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 17793 miles
07/28/2005 188583 # C2021 - SUNSHADE REPLACEMENT - LEFT SIDE 15002 miles
07/28/2005 188583 # Z7901 - 1-DAY COURTESY TRANSPORTATION 15002 miles
06/30/2005 187468 0 M0017 - LUBE, OIL AND FILTER 14387 miles
06/30/2005 187468 # B7540 - MOLDING, WINDSHIELD REVEAL - R&R OR REPLACE 14387 miles
06/30/2005 187468 # C2021 - SUNSHADE REPLACEMENT - LEFT SIDE 14387 miles
06/30/2005 187468 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 14387 miles
06/30/2005 187468 # Z7901 - 1-DAY COURTESY TRANSPORTATION 14387 miles
02/25/2005 182473 # J3080 - RADIATOR ASSEMBLY - R&R 9306 miles
02/25/2005 182473 # Z7901 - 1-DAY COURTESY TRANSPORTATION 9306 miles
12/27/2004 180259 # J6360 - POWERTRAIN CONTROL MODULE REPLACEMENT 7243 miles
12/27/2004 180259 # N2360 - SWITCH - CLUTCH START - REPLACE 7243 miles
12/27/2004 180259 # Z7901 - 1-DAY COURTESY TRANSPORTATION 7243 miles
12/23/2004 180204 # C0101 - GLASS, FRONT DOOR - LEFT - ALIGN 7094 miles
12/23/2004 180204 # N2360 - SWITCH - CLUTCH START - REPLACE 7094 miles
12/23/2004 180204 # Z7901 - 1-DAY COURTESY TRANSPORTATION 7094 miles
12/10/2004 179702 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 6564 miles
12/10/2004 179702 # B1783 - WINDSHIELD WIPER BLADE REPLACEMENT 6564 miles
10/15/2004 177391 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 4225 miles
10/07/2004 177015 # N4862 - MODULE - DASH INTEGRATION - REPLACE 4053 miles
10/07/2004 177015 # Z7901 - 1-DAY COURTESY TRANSPORTATION 4053 miles
08/06/2004 174441 # Z7901 - 1-DAY COURTESY TRANSPORTATION 1276 miles
06/01/2004 A04260 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
1G6DN56S550162838 APPLICABLE WARRANTIES
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 05/16/2005 5 miles 05/16/2009 50005 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/16/2005 5 miles 05/16/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/16/2005 5 miles 05/16/2013 80005 miles
48/50000 CALIFORNIA EMISSIONS 05/16/2005 5 miles 05/16/2009 50005 miles
84/70000 CALIFORNIA SELECT COMPONENT 05/16/2005 5 miles 05/16/2012 70005 miles
CLAIM HISTORY
12/04/2007 082989 # E9050 - POWER STEERING PUMP REPLACEMENT 31178 miles
10/28/2005 041099 # C2860 - CONSOLE ASSEMBLY - R&R OR REPLACE 6693 miles
10/26/2005 040882 # N4187 - INSTRUMENT CLUSTER-ASSEMBLY RETURN TO AC DELCO ESC 6663 miles
10/25/2005 040882 # N4180 - INSTRUMENT CLUSTER REPLACEMENT 6663 miles
10/25/2005 040882 # Z7902 - 2-DAY COURTESY TRANSPORTATION 6663 miles
07/20/2005 035159 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 2208 miles
11/10/2004 A62838 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
1G6DN57S440171700
Not a valid VIN. Double check it.
