Originally Posted by Boosted1456 Looking at 3 Cars currently...
Was hoping to get claim history, Warranty info, and Spec Sheet - Options listed on the Car, more specifically if it has FG2's or not.
Thanks!
1G6DN57S240178685
1G6DN56S650129539
1G6DN57S240177603
Thanks! Cant wait to pick one of these up! |
1G6DN57S240178685 APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 06/18/2004 107 miles 06/18/2008 50107 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 06/18/2004 107 miles 06/18/2010 100107 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 06/18/2004 107 miles 06/18/2012 80107 miles
48/50000 CALIFORNIA EMISSIONS 06/18/2004 107 miles 06/18/2008 50107 miles
84/70000 CALIFORNIA SELECT COMPONENT 06/18/2004 107 miles 06/18/2011 70107 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
09/21/2007 169488 # K2752 - GEAR - 3RD SPEED GEAR - R&R OR REPLACE 26117 miles
09/21/2007 169488 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 26117 miles
09/10/2007 168821 # K0600 - CYLINDER, ACTUATOR CLUTCH MASTER - R&R OR REPLACE 26117 miles
09/10/2007 168821 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 26117 miles
08/29/2007 168366 # H9711 - FRAME, REAR SUPPLEMENTAL BUSHINGS - INSTALL 25940 miles
08/08/2007 167360 # K0800 - DISC AND/OR CLUTCH COVER, CLUTCH - REPLACE 25628 miles
08/08/2007 167360 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 25628 miles
07/19/2007 166433 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 25526 miles
07/19/2007 166433 # K0800 - DISC AND/OR CLUTCH COVER, CLUTCH - REPLACE 25526 miles
07/19/2007 166433 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 25526 miles
09/07/2006 292026 # Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 22013 miles
09/07/2006 292026 # N0110 - BATTERY - ONE - REPLACE 22013 miles
09/06/2006 G06669 # Z2085 - ROADSIDE SERVICE (PREMIUM) 22013 miles
09/06/2006 G06673 # Z2085 - ROADSIDE SERVICE (PREMIUM) 22000 miles
08/01/2006 149515 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 21214 miles
08/01/2006 149515 # J1507 - MOUNT, ENGINE - FRONT - BOTH - REPLACE 21214 miles
08/01/2006 149515 # B2780 - SUNROOF MODULE ASSEMBLY REPLACEMENT 21214 miles
08/01/2006 149515 # J4640 - STARTER MOTOR REPLACEMENT 21214 miles
08/01/2006 149515 # Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 21214 miles
10/24/2005 135174 # C2760 - BOX, CONSOLE COMPARTMENT - REPLACE 13690 miles
10/24/2005 135174 # V1302 - 05004 - REPLACE SDM 13690 miles
08/25/2005 131865 # Z7901 - 1-DAY COURTESY TRANSPORTATION 12117 miles
04/05/2005 123368 # J9991 - CUSTOMER CONCERN NOT DUPLICATED 7940 miles
04/05/2005 123368 G J9991 - CUSTOMER CONCERN NOT DUPLICATED 0 miles
04/05/2005 123368 # H9991 - CUSTOMER CONCERN NOT DUPLICATED 7940 miles
04/05/2005 123368 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 7940 miles
04/05/2005 123368 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 7940 miles
04/05/2005 123368 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 7940 miles
10/01/2004 113103 # H2947 - PARKING BRAKE SHOE REPLACEMENT 3719 miles
09/04/2004 111595 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 1823 miles
08/02/2004 011205 # F1610 - SEAL, AXLE SHAFT OIL - REAR AXLE - RIGHT - REPLACE 1823 miles
08/02/2004 011205 # Z7903 - 3-DAY COURTESY TRANSPORTATION 1823 miles
04/02/2004 A78685 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
A45 - MEMORY SEAT ADJUSTER
AH8 - 10-WAY PWR. PASS. SEAT W/ PWR. LUMBAR
AL2 - POWER LUMBAR CONTROL
AM9 - SPLIT-FOLDING REAR SEAT
AQ9 - SEAT FRT BKT, LUXURY
AY0 - INFLATABLE RESTRAINT DRI & PASS
CE4 - WASHER HEADLAMP, HIGH PRESSURE
CF5 - EXPRESS OPEN SUNROOF
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP
DD8 - MIRROR AUTO DAY/NIGHT I/S R/V
DL5 - DECAL - ROADSIDE SERVICE INFO
DR5 - MIRROR O/S REMOTE L/H R/H
FE4 - SUSPENSION
GT4 - AXLE REAR 3.73 RATIO
IL3 - TRIM INTERIOR DESIGN
J56 - BRAKES, ANTILOCK
JJA - PT DRESS SUBASSEMBLY INSTALLED
KA1 - HEATED FRONT SEATS
KG4 - 150 AMP GENERATOR
LS6 - LS6 5.7L 400 HP V8 ENGINE
M12 - MANUAL TRANS
MN6 - TREMEC 6-SPEED MANUAL TRANS
N34 - STEERING WHEEL, LEATHER
NU4 - EMISSION - CALIFORNIA
P32 - WHEEL 18" ALUMINUM
PDL - LUXURY PACKAGE
QKR - P245/45R18 ALL SEASON BW
R8X - FLEET GUARANTEED DELIVERY PGRM
SLM - STOCK ORDERS
TT6 - HIGH INTENSITY HEADLAMPS
U2K - XM SATELLITE RADIO-100 CHANNELS OF GO ANYWHERE ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL
U30 - INSTRUMENT CLUSTER,TACH,CLOCK
U57 - 8 SPEAKER SYSTEM
UA6 - THEFT DETERENT SYSTEM
UAV - DVD NAVIGATION SYSTEM INCL: XM SATELLITE RADIO-100 CHANNEL COAST TO COAST DIGITAL SOUND (SUBSCRIPTION CHARGES EXTRA- DELETES COMPASS IN MIRROR)
UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1YR SAFE & SOUND PLAN
UG1 - UNIVERSAL GARAGE DOOR OPENER
V73 - VEHICLE STATEMENT USA/CANADA
VG6 - CALIF, 5 MPH BUMPER LABEL
VG8 - NOTICE TO BUYER LABEL
YF5 - 50-STATE EMISSIONS
1SA - CTS STANDARD PACKAGE
1SZ - PREFERRED EQUIPMENT SAVINGS
41U - BLACK RAVEN
6MH - COMP FRT LH COMPUTER SEL SUSP
703 - LIGHT NEUTRAL
70I - LIGHT NEUTRAL
7MH - COMP FRT RH COMPUTER SEL SUSP
8GW - SUSPENSION
9GW - SUSPENSION
1G6DN56S650129539 APPLICABLE WARRANTIES
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 01/08/2005 69 miles 01/08/2009 50069 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 01/08/2005 69 miles 01/08/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 01/08/2005 69 miles 01/08/2013 80069 miles
48/50000 CALIFORNIA EMISSIONS 01/08/2005 69 miles 01/08/2009 50069 miles
84/70000 CALIFORNIA SELECT COMPONENT 01/08/2005 69 miles 01/08/2012 70069 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading 08/18/2007 238682 # R4490 - TRANSMITTER, REMOTE DOOR/REAR COMPARTMENT LOCK - REPLACE 20946 miles
08/18/2007 238682 # E5800 - SHOCK ABSORBER, REAR - RIGHT - REPLACE 20946 miles
08/18/2007 238682 # J3260 - COOLANT RECOVERY RESERVOIR REPLACEMENT 20946 miles
08/18/2007 238682 # Z7903 - 3-DAY COURTESY TRANSPORTATION 20946 miles
11/17/2006 014083 # N0110 - BATTERY - ONE - REPLACE 15557 miles
09/07/2006 009192 # E0716 - DIAGNOSTIC SYSTEM CHECK - TIRE PRESSURE MONITORING 14700 miles
11/16/2005 089767 # C3128 - HEADLINING TRIM PANEL REPLACEMENT 6864 miles
10/13/2005 087297 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 6270 miles
05/16/2005 076406 # N0110 - BATTERY - ONE - REPLACE 2463 miles
09/20/2004 049774 I Z6998 - PDI ADDS 2 miles
08/27/2004 A29539 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
DNR - DEALER INSTALLED OPTION
FE4 - SUSPENSION
FG2 - PERFORMANCE SHOCK PACKAGE *** DEALER INSTALLED ***
LS6 - LS6 5.7L V8 ENGINE
M12 - TREMEC 6-SPEED MANUAL TRANS
QKR - P245/45R18 W RATED
R8E - GAS GUZZLER TAX
R9U - GM ACCESS-AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS
U2K - XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL
UAV - DVD NAVIGATION SYSTEM INCL: XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INC (DELETES COMPASS IN MIRROR)
ZV1 - MFG STATEMENT OF ORIGIN
193 - EBONY
19I - EBONY INTERIOR TRIM
1SA - CTS-V STANDARD PACKAGE
67U - LIGHT PLATINUM
8GW - SUSPENSION
9GW - SUSPENSION
1G6DN57S240177603 APPLICABLE WARRANTIES
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 05/27/2004 118 miles 05/27/2008 50118 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/27/2004 118 miles 05/27/2010 100118 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/27/2004 118 miles 05/27/2012 80118 miles
48/50000 CALIFORNIA EMISSIONS 05/27/2004 118 miles 05/27/2008 50118 miles
84/70000 CALIFORNIA SELECT COMPONENT 05/27/2004 118 miles 05/27/2011 70118 miles
CLAIM HISTORY
04/14/2008 600865 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 24464 miles
04/02/2008 600865 # Z2097 - ON-STAR ANALOG-TO-DIGITAL UPGRADE KIT - RETURN TO ACDELCO 24464 miles
03/31/2008 600865 # Z2096 - ONSTAR ANALOG-TO-DIGITAL UPGRADE KIT - INSTALL 24464 miles
03/31/2008 600865 # C2021 - SUNSHADE REPLACEMENT - LEFT SIDE 24464 miles
03/31/2008 600865 # R0760 - RADIO, REMOVE AND REPLACE 24464 miles
03/01/2007 571000 # N0761 - BULBS, STOP, TAIL, AND TURN LAMP (LEFT) - REPLACE 22573 miles
03/01/2007 571000 # F2154 - BUSHING, REAR DIFFERENTIAL CARRIER SUPPORT OR MOUNT - REPL 22573 miles
06/28/2006 551290 # N4199 - INSTRUMENT CLUSTER REPROGRAMMING WITH SPS 20650 miles
06/28/2006 551290 # Z7902 - 2-DAY COURTESY TRANSPORTATION 20650 miles
01/24/2006 538799 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 17866 miles
01/24/2006 538799 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 17866 miles
01/24/2006 538799 # C4020 - TRIM ASSEMBLY, QUARTER - RIGHT - R&R OR REPLACE 17866 miles
01/24/2006 538799 # R0760 - RADIO, REMOVE AND REPLACE 17866 miles
01/24/2006 538799 # Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 17866 miles
01/24/2006 538799 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 17866 miles
07/27/2005 524268 # V1302 - 05004 - REPLACE SDM 12894 miles
07/27/2005 524268 # J3100 - RADIATOR ASSEMBLY - REPLACE 12894 miles
07/27/2005 524268 # Z7902 - 2-DAY COURTESY TRANSPORTATION 12894 miles
07/27/2005 524268 # N0110 - BATTERY - ONE - REPLACE 12894 miles
03/07/2005 511469 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 8711 miles
03/07/2005 511469 # C2860 - CONSOLE ASSEMBLY - R&R OR REPLACE 8711 miles
03/07/2005 511469 # Z7901 - 1-DAY COURTESY TRANSPORTATION 8711 miles
09/22/2004 498139 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 3888 miles
09/22/2004 498139 # Z7901 - 1-DAY COURTESY TRANSPORTATION 3888 miles
07/13/2004 491958 # Z7901 - 1-DAY COURTESY TRANSPORTATION 1614 miles
03/31/2004 A77603 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
FE4 - SUSPENSION
M12 - MANUAL TRANS
SLM - STOCK ORDERS
193 - EBONY
8GW - SUSPENSION
9GW - SUSPENSION
