Originally Posted by ABCF here is another Vette I am looking at
1G1YY22G025118937
if i am doing this too much please let me know.
thank you |
No problem. Glad to run it for a supporting member.
2002 CORVETTE COUPE APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 02/15/2002 56 miles 02/15/2005 36056 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 02/15/2002 56 miles 02/15/2008 100056 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 02/15/2002 56 miles 02/15/2010 80056 miles
36/50000 CALIFORNIA EMISSIONS 02/15/2002 56 miles 02/15/2005 50056 miles
84/70000 CALIFORNIA SELECT COMPONENT 02/15/2002 56 miles 02/15/2009 70056 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
09/24/2007 401640 0 J1301 - PISTON, ROD AND/OR RINGS - ONE CYL - LEFT BANK - REPLACE 44696 miles
09/24/2007 401640 1 N4920 - MODULE, LOCAL INTERFACE UNIT - DOOR - RIGHT - REPLACE 44696 miles
09/24/2007 401640 0 N4920 - MODULE, LOCAL INTERFACE UNIT - DOOR - RIGHT - REPLACE 44696 miles
04/26/2007 758758 0 N3214 - FRONT SIDE DOOR LOCK ACTUATOR REPLACEMENT - RIGHT SIDE 42961 miles
04/26/2007 758758 0 Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 42961 miles
05/30/2006 712494 0 N1750 - FLASHER - HAZARD WARNING - REPLACE 38029 miles
05/24/2004 159082 # K7271 - BAND, 2-4 - R&R OR REPLACE 26329 miles
05/24/2004 159082 # C1013 - WEATHERSTRIP - ROOF - REAR - ALIGN OR REPLACE 26329 miles
05/24/2004 159082 # B3130 - SEAL, CENTER RAIL (CENTER ROOF RAIL WEATHERSTRIP) - RIGHT 26329 miles
07/03/2003 143857 # J6360 - POWERTRAIN CONTROL MODULE REPLACEMENT 17500 miles
07/03/2003 143857 # T2020 - TOWING 17500 miles
07/02/2003 534602 # T2020 - TOWING 17288 miles
06/30/2003 143592 # J5582 - MODULE, ELECTRONIC THROTTLE CONTROL - REPLACE 17288 miles
06/30/2003 143592 # N6600 - WIRING AND/OR CONNECTOR - BRAKE SYSTEM/TRACTION CONTROL - 17288 miles
04/16/2003 383975 # T2020 - TOWING 14003 miles
04/14/2003 140013 # J5490 - THROTTLE BODY ASSEMBLY REPLACEMENT 14977 miles
04/14/2003 140013 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 14977 miles
04/14/2003 140013 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - REPLACE 14977 miles
01/27/2003 136278 # L2020 - HANGER AND/OR CLAMP, EXHAUST SYSTEM - REPLACE 12077 miles
01/27/2003 136278 # Z7904 - 4-DAY COURTESY TRANSPORTATION 12077 miles
01/24/2003 136188 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 11951 miles
01/24/2003 136188 # C1013 - WEATHERSTRIP - ROOF - REAR - ALIGN OR REPLACE 11951 miles
01/24/2003 136188 # Z7901 - 1-DAY COURTESY TRANSPORTATION 11951 miles
01/21/2003 136024 # L2905 - EXHAUST SYSTEM (COMPLETE) - DUAL - REPLACE 11940 miles
01/21/2003 136024 # B2317 - STRIKER, HATCH ROOF - LEFT - REPLACE 11940 miles
01/21/2003 136024 # Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 11940 miles
01/21/2003 136024 # R0955 - SPEAKER, RADIO - REAR COMPARTMENT LIFTGATE OR DOOR - LEFT 11940 miles
10/15/2002 131754 # N6600 - WIRING AND/OR CONNECTOR - BRAKE SYSTEM/TRACTION CONTROL - 8718 miles
01/16/2002 A18937 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT
C60 - AIR CONDITIONING
CC3 - TRANSPARENT LIFT-OFF ROOF PANEL
DL5 - ROADSIDE SERVICE INFORMATION DECAL
DL8 - HEATED OUTSIDE REARVIEW MIRRORS
FE1 - SUSPENSION SYSTEM-SOFT RIDE
GU2 - REAR AXLE 2.73 RATIO
IP3 - INTERIOR TRIM DESIGN
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
NC1 - CALIFORNIA EMISSIONS LEV
NC7 - FEDERAL EMISSIONS OVERRIDE
NG1 - 50-STATE LOW EMISSION VEHICLE
NK4 - LEATHER WRAPPED STEERING WHEEL
QF5 - POLISHED ALUMINUM WHEEL
SLM - STOCK ORDERS
U52 - ELECTRONIC INSTRUMENTATION
UN0 - AM/FM STEREO W/CD PLAYER
UV7 - WINDSHIELD ANTENNA
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
VM3 - CONSUMER INFORMATION LABEL
XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR
193 - BLACK LEATHER TRIM SEATING
19I - BLACK INTERIOR TRIM
1SA - CORVETTE COUPE BASE EQUIPMENT GROUP
41U - BLACK
