Originally Posted by odla 1G6DN57S540186120
1G6DN57S640162411
1G6DN57SX40178787
thank you |
1G6DN57S540186120 APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer 48/50000 BUMPER TO BUMPER LIMITED WARRANTY 05/06/2004 20 miles 05/06/2008 50020 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/06/2004 20 miles 05/06/2010 100020 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/06/2004 20 miles 05/06/2012 80020 miles
48/50000 FEDERAL EMISSION 05/06/2004 20 miles 05/06/2008 50020 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
03/27/2007 444442 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 46797 miles
03/27/2007 444442 # Z7903 - 3-DAY COURTESY TRANSPORTATION 46797 miles
03/27/2007 444442 # E7680 - STEERING COLUMN REPLACEMENT 46797 miles
03/27/2007 444442 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 46797 miles
03/27/2007 444442 # C4020 - TRIM ASSEMBLY, QUARTER - RIGHT - R&R OR REPLACE 46797 miles
03/27/2007 444442 # N0761 - BULBS, STOP, TAIL, AND TURN LAMP (LEFT) - REPLACE 46797 miles
03/27/2007 444442 # N1720 - FUSE - REPLACE 46797 miles
09/18/2006 430107 # L2020 - HANGER AND/OR CLAMP, EXHAUST SYSTEM - REPLACE 38877 miles
07/11/2006 424738 # E7690 - SENSOR, STEERING WHEEL ROTATION - REPLACE 34687 miles
07/11/2006 424738 # C2200 - INSTRUMENT PANEL ASHTRAY REPLACEMENT 34687 miles
07/11/2006 424738 # C2990 - KNOB, CONTROL AND/OR SELECT - ONE AND/OR ALL - REPLACE 34687 miles
07/11/2006 424738 # Z7902 - 2-DAY COURTESY TRANSPORTATION 34687 miles
07/11/2006 424738 # N1720 - FUSE - REPLACE 34687 miles
04/24/2006 418669 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 29508 miles
04/24/2006 418669 # Z7903 - 3-DAY COURTESY TRANSPORTATION 29508 miles
02/24/2006 414420 # J3100 - RADIATOR ASSEMBLY - REPLACE 25340 miles
02/24/2006 414420 # Z7901 - 1-DAY COURTESY TRANSPORTATION 25340 miles
10/27/2005 405596 # H9711 - FRAME, REAR SUPPLEMENTAL BUSHINGS - INSTALL 19612 miles
10/27/2005 405596 # C2795 - PLATE OR BOOT, CONSOLE FLOOR SHIFT - REPLACE 19612 miles
10/27/2005 405596 # J3100 - RADIATOR ASSEMBLY - REPLACE 19612 miles
10/03/2005 145262 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 17285 miles
10/03/2005 145262 # T5999 - ADDITIONAL PART MARKUP PERCENTAGE OVER 40% NORM 17285 miles
05/19/2005 126582 # N0440 - BULB, COMPOSITE HEADLAMP (RIGHT) - REPLACE 12619 miles
05/19/2005 126582 # B7288 - HEADLAMP/COMPOSITE ASSEMBLY - RIGHT - REPLACE 12619 miles
05/19/2005 126582 # V1302 - 05004 - REPLACE SDM 12619 miles
10/19/2004 120448 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 7893 miles
06/17/2004 116550 # C2990 - KNOB, CONTROL AND/OR SELECT - ONE AND/OR ALL - REPLACE 3178 miles
04/28/2004 A86120 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
1G6DN57S640162411 APPLICABLE WARRANTIES
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 03/10/2004 18 miles 03/10/2008 50018 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/10/2004 18 miles 03/10/2010 100018 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/10/2004 18 miles 03/10/2012 80018 miles
48/50000 FEDERAL EMISSION 03/10/2004 18 miles 03/10/2008 50018 miles
CLAIM HISTORY
06/27/2007 201776 # L1020 - CAP, FUEL TANK - REPLACE 22174 miles
05/14/2007 200362 # N0110 - BATTERY - ONE - REPLACE 21413 miles
05/14/2007 200362 # J9992 - CUSTOMER CONCERN NOT DUPLICATED 21413 miles
12/05/2005 184676 # V1302 - 05004 - REPLACE SDM 17543 miles
12/05/2005 184676 # N1720 - FUSE - REPLACE 17543 miles
12/10/2004 032612 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 11877 miles
12/10/2004 032612 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 11877 miles
06/16/2004 021808 # J4100 - GENERATOR ASSEMBLY - REPLACE 3686 miles
03/03/2004 545658 # Z6999 - PDI RELATED FLUID ADDS 5 miles
02/19/2004 A62411 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
1G6DN57SX40178787 APPLICABLE WARRANTIES
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 05/10/2004 89 miles 05/10/2008 50089 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/10/2004 89 miles 05/10/2010 100089 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/10/2004 89 miles 05/10/2012 80089 miles
48/50000 FEDERAL EMISSION 05/10/2004 89 miles 05/10/2008 50089 miles
CLAIM HISTORY
09/25/2006 270773 # J4226 - PLUGS, SPARK - ONE - REPLACE 49665 miles
09/25/2006 270773 # J4340 - IGNITION COIL REPLACEMENT 49665 miles
09/25/2006 270773 # Z7902 - 2-DAY COURTESY TRANSPORTATION 49665 miles
08/30/2006 269515 # J3100 - RADIATOR ASSEMBLY - REPLACE 48320 miles
08/30/2006 269515 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 48320 miles
08/30/2006 269515 # H9991 - CUSTOMER CONCERN NOT DUPLICATED 48320 miles
08/30/2006 269515 # R0760 - RADIO, REMOVE AND REPLACE 48320 miles
08/30/2006 269515 # Z7902 - 2-DAY COURTESY TRANSPORTATION 48320 miles
07/25/2006 267836 # E9404 - P/STEERING FLUID FLUSH AND REPLACE W/COLD CLIMATE FLUID 45130 miles
07/25/2006 267836 # B7540 - MOLDING, WINDSHIELD REVEAL - R&R OR REPLACE 45130 miles
07/25/2006 267836 # Z7901 - 1-DAY COURTESY TRANSPORTATION 45130 miles
08/24/2005 252270 S E0431 - TIRE, GOODYEAR/DUNLOP - REPLACE 21125 miles
08/09/2005 251533 # C7200 - REAR SEAT ARMREST REPLACEMENT 21219 miles
08/09/2005 251533 # Z7901 - 1-DAY COURTESY TRANSPORTATION 21219 miles
06/30/2005 249508 # K0800 - DISC AND/OR CLUTCH COVER, CLUTCH - REPLACE 20420 miles
06/30/2005 249508 D K0800 - DISC AND/OR CLUTCH COVER, CLUTCH - REPLACE 20420 miles
06/30/2005 249508 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 20420 miles
06/30/2005 249508 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 20420 miles
06/22/2005 249008 # V1302 - 05004 - REPLACE SDM 19767 miles
02/10/2005 242390 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 11505 miles
02/10/2005 242390 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 11505 miles
08/20/2004 232643 # J3260 - COOLANT RECOVERY RESERVOIR REPLACEMENT 5440 miles
08/20/2004 232643 # Z7903 - 3-DAY COURTESY TRANSPORTATION 5440 miles
08/20/2004 232643 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 5440 miles
04/02/2004 A78787 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
