Originally Posted by 04deveni Much appreciated if anyone has a chance to look up 1G6DM57N530113521, suspension type and history are what's most important for me to find out. Thanks. |
2003 CTS SPORT APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/80000 BUMPER TO BUMPER LIMITED WARRANTY 05/22/2002 7 kilometres 05/22/2006 80007 kilometres
72/160000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/22/2002 7 kilometres 05/22/2008 160007 kilometres
96/130000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/22/2002 7 kilometres 05/22/2010 130007 kilometres
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
08/04/2005 340467 0 C8817 - INFLATABLE RESTRAINT SENSING AND DIAGNOSTIC MODULE REPLACE 93584 kilometres
08/04/2005 340467 0 N6600 - WIRING AND/OR CONNECTOR - BRAKE SYSTEM/TRACTION CONTROL - 93584 kilometres
08/04/2005 340467 0 R0760 - RADIO, REMOVE AND REPLACE 93584 kilometres
01/03/2005 323074 0 J3500 - ENGINE COOLANT THERMOSTAT REPLACEMENT 87379 kilometres
01/03/2005 323074 0 N6648 - WIRING AND/OR CONNECTOR - SEAT SYSTEM - REPAIR OR REPLACE 87379 kilometres
10/04/2004 315922 # E3557 - BUSHINGS AND/OR SHAFT, FRONT CONTROL ARM - LOWER - BOTH - 79476 kilometres
10/04/2004 315922 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 79476 kilometres
10/04/2004 315922 # Z8052 - CAD MAINTENANCE (AIR CLEANER RPL) 79476 kilometres
08/30/2004 313087 # E0032 - CAP, WHEEL CENTER - FRONT - REPLACE 75367 kilometres
08/30/2004 313087 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 75367 kilometres
08/30/2004 313087 # Z8051 - CAD MAINTENANCE (TIRE ROTATION ) 75367 kilometres
08/30/2004 313087 # Z8057 - CAD MAINTENANCE (BRAKES) 75367 kilometres
06/08/2004 306395 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 63783 kilometres
05/06/2004 303634 # V1043 - 03039 - COPY AND PLACE SUPPLEMENT IN THE OWNERS MANUAL 63783 kilometres
05/06/2004 303634 # V1063 - INSPECT TIRES - REPLACE ALL FOUR 63783 kilometres
05/06/2004 303634 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 63783 kilometres
11/17/2003 288923 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 51673 kilometres
07/04/2003 277703 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 37731 kilometres
02/26/2003 267536 # F1611 - SEAL, AXLE SHAFT OIL - REAR AXLE - LEFT - REPLACE 28971 kilometres
02/26/2003 267536 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 28971 kilometres
02/26/2003 267536 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - REPLACE 28971 kilometres
02/26/2003 267536 # V1007 - 03017 INTERMED STEERING SHAFT BOLT UNDER-TORQUED 2003 CTS 28971 kilometres
02/26/2003 267536 # Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 28971 kilometres
01/20/2003 264693 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 26415 kilometres
11/06/2002 259398 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 20871 kilometres
09/19/2002 255478 # E0032 - CAP, WHEEL CENTER - FRONT - REPLACE 15625 kilometres
09/19/2002 255478 G J9994 - CUSTOMER CONCERN NOT DUPLICATED 15625 kilometres
09/19/2002 255478 # J9994 - CUSTOMER CONCERN NOT DUPLICATED 15625 kilometres
09/19/2002 255478 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 15625 kilometres
09/19/2002 255478 # Z8051 - CAD MAINTENANCE (TIRE ROTATION ) 15625 kilometres
09/03/2002 253990 # J3120 - COOLER, ENGINE OIL - REPLACE 12300 kilometres
09/03/2002 253990 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 12300 kilometres
07/10/2002 249632 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 8200 kilometres
05/01/2002 A13521 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 kilometres
OPTION CODES
A45 - MEMORY: SEATS AND O/S MIRROR
AH8 - ADJUSTER: 8 WAY POWER PASSENGER
AM9 - SEAT: REAR SPLIT FOLDING BENCH
AQ9 - SEATS: LEATHER, HEATED FRONT
AY0
B19 - NATURAL WOOD ACCENT PACKAGE
CF5 - PREMIUM SUNROOF
CJ2 - AIR CONDITIONING - ELECTRONIC CLIMATE CONTROL DUAL ZONE
DD7 - MIRROR: AUTODIM WITH ONSTAR 3 BUTTON SYSTEM AND COMPASS
DR5
DT4 - ASHTRAY AND CIGARETTE LIGHTER
E2C
FE3 - SPORT PERFORMANCE SUSPENSION
GU6 - 3.42 REAR AXLE RATIO
IL2
JE2
JL4 - STABILITRAK CONTROL SYSTEM
JL9 - BRAKES - ANTI-LOCK
K05 - ENGINE BLOCK HEATER
KA1 - SEATS - FRONT, HEATED
KG9 - 140 AMP GENERATOR
LA3 - 3.2L V6 SFI DOHC ENGINE
LAL
M82 - TRANSMISSION: 5 SPEED AUTOMATIC
MX0 - 4-SPEED AUTOMATIC TRANSMISSION
N30 - STEERING WHEEL-WOOD TRIM PKGE
N93 - 17" POLISHED ALUMINUM WHEELS
NF7 - FEDERAL EMISSION SYSTEM
QWN - TIRES: P225/50R 17" BLACKWALL
R6Z
R7K - MISSING OPTION CREDIT
SLL - SOLD ORDERS
U19 - KILO SPEEDOMETER
U2S - PREMIUM BOSE SOUND SYSTEM
U30
U57 - BOSE SPEAKERS
UA6 - THEFT DETERRENT SYSTEM
UE1 - ONSTAR COMMUNICATION SYSTEM
UG1 - UNIVERSAL GARAGE DOOR OPENER
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
Z49 - CANADIAN BASE EQUIPMENT
1SC - PREFERRED EQUIPMENT GROUP
54U - CASHMERE METALLIC
6MA
702 - LIGHT NEUTRAL
70I - RED INTERIOR TRIM
7MA
8FS
9FS
