Originally Posted by vee_eyes A few more prospects. Thank you Luster.
1G6DN57S140177334
1G6DN57S240154502
1G6DN56S650129539 |
1G6DN57S140177334 APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 05/28/2004 27 miles 05/28/2008 50027 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/28/2004 27 miles 05/28/2010 100027 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/28/2004 27 miles 05/28/2012 80027 miles
48/50000 FEDERAL EMISSION 05/28/2004 27 miles 05/28/2008 50027 miles
72/100000 LUXURY CERTIFIED PRE-OWNED LIMITED WARRANTY 05/28/2004 27 miles 05/28/2010 100027 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
12/18/2007 301118 # J1420 - FLYWHEEL (MANUAL TRANSMISSION) - REPLACE 55911 miles
12/18/2007 301118 # Z7901 - 1-DAY COURTESY TRANSPORTATION 55911 miles
10/09/2007 279013 # J1500 - ENGINE FRONT MOUNT REPLACEMENT - RIGHT SIDE 55329 miles
10/09/2007 279013 # E9050 - POWER STEERING PUMP REPLACEMENT 55329 miles
09/17/2007 271586 3 F2240 - PLATES, LIMITED SLIP CLUTCH - REPLACE 54931 miles
09/17/2007 271586 0 Z7904 - 4-DAY COURTESY TRANSPORTATION 54931 miles
08/28/2007 265227 # F3272 - PLUG, DIFFERENTIAL CARRIER DRAIN - REPLACE 54526 miles
01/10/2007 095621 # J1501 - ENGINE FRONT MOUNT REPLACEMENT - LEFT SIDE 48960 miles
01/10/2007 095621 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 48960 miles
01/10/2007 095621 # R0760 - RADIO, REMOVE AND REPLACE 48960 miles
10/05/2006 092716 # N4199 - INSTRUMENT CLUSTER REPROGRAMMING WITH SPS 47897 miles
10/05/2006 092716 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 47897 miles
10/05/2006 092716 # C4020 - TRIM ASSEMBLY, QUARTER - RIGHT - R&R OR REPLACE 47897 miles
10/05/2006 092716 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 47897 miles
07/07/2006 603642 # Z7902 - 2-DAY COURTESY TRANSPORTATION 47030 miles
06/28/2006 603150 # D1441 - DEFLECTOR, AIR (OUTLET VENT) - LEFT - REPLACE 47029 miles
03/01/2006 055476 # Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 46682 miles
03/01/2006 055477 # Z8014 - ROADSIDE SERVICE (BATTERY/JUMP START) 46682 miles
03/01/2006 055477 # N0110 - BATTERY - ONE - REPLACE 46682 miles
02/28/2006 B48343 # Z2085 - ROADSIDE SERVICE (PREMIUM) 35000 miles
02/28/2006 B48344 # Z2080 - ROADSIDE SERVICE (TOWING) 35000 miles
01/19/2006 173598 # C2200 - INSTRUMENT PANEL ASHTRAY REPLACEMENT 34677 miles
01/19/2006 173598 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 34677 miles
01/19/2006 173598 # Z7902 - 2-DAY COURTESY TRANSPORTATION 34677 miles
12/09/2005 171736 # V1302 - 05004 - REPLACE SDM 31942 miles
12/08/2005 958260 # Z2080 - ROADSIDE SERVICE (TOWING) 31000 miles
12/08/2005 958261 # Z2080 - ROADSIDE SERVICE (TOWING) 31000 miles
11/14/2005 170758 # R0942 - RADIO FRONT SIDE DOOR SPEAKER REPLACEMENT - RIGHT SIDE 30681 miles
11/14/2005 170758 # Z7903 - 3-DAY COURTESY TRANSPORTATION 30681 miles
11/14/2005 170758 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 30681 miles
10/12/2005 053019 # Z8013 - ROADSIDE SERVICE (FUEL DELIVERY) 29344 miles
10/11/2005 818226 # Z2085 - ROADSIDE SERVICE (PREMIUM) 29334 miles
09/12/2005 167803 # N0680 - BULBS, PARK AND TURN SIGNAL LAMP (RIGHT) - REPLACE 27618 miles
09/12/2005 167803 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 27618 miles
09/12/2005 167803 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 27618 miles
09/12/2005 167803 # R0760 - RADIO, REMOVE AND REPLACE 27618 miles
09/12/2005 167803 # N6620 - WIRING AND/OR CONNECTOR - POWER & GROUNDS DISTRIBUTION - R 27618 miles
09/12/2005 167803 # Z7901 - 1-DAY COURTESY TRANSPORTATION 27618 miles
09/12/2005 167803 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 27618 miles
05/16/2005 034946 # Z2085 - ROADSIDE SERVICE (PREMIUM) 18500 miles
05/16/2005 050085 # Z8014 - ROADSIDE SERVICE (BATTERY/JUMP START) 19055 miles
04/26/2005 161561 # C2200 - INSTRUMENT PANEL ASHTRAY REPLACEMENT 17199 miles
11/15/2004 305939 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 9380 miles
11/15/2004 305939 # Z7901 - 1-DAY COURTESY TRANSPORTATION 9380 miles
09/13/2004 293678 # Z7901 - 1-DAY COURTESY TRANSPORTATION 4961 miles
09/13/2004 293678 # N4585 - SENSOR, ENGINE OIL PRESSURE - REPLACE 4961 miles
09/13/2004 293678 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 4961 miles
09/01/2004 291925 # Z7902 - 2-DAY COURTESY TRANSPORTATION 4533 miles
09/01/2004 291925 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 4533 miles
09/01/2004 291925 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 4533 miles
03/30/2004 A77334 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
1G6DN57S240154502 APPLICABLE WARRANTIES
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 02/12/2004 16 miles 02/12/2008 50016 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 02/12/2004 16 miles 02/12/2010 100016 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 02/12/2004 16 miles 02/12/2012 80016 miles
48/50000 FEDERAL EMISSION 02/12/2004 16 miles 02/12/2008 50016 miles
72/100000 LUXURY CERTIFIED PRE-OWNED LIMITED WARRANTY 02/12/2004 16 miles 02/12/2010 100016 miles
CLAIM HISTORY
06/19/2007 578960 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 42093 miles
06/18/2007 578960 # C6690 - HEADREST AND/OR COVER, FRONT SEAT - PASSENGER - R&R OR REP 42093 miles
06/18/2007 578960 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 42093 miles
06/18/2007 578960 # Z7902 - 2-DAY COURTESY TRANSPORTATION 42093 miles
06/18/2007 578960 # R0760 - RADIO, REMOVE AND REPLACE 42093 miles
02/05/2007 569100 # E7690 - SENSOR, STEERING WHEEL ROTATION - REPLACE 37610 miles
02/05/2007 569100 # Z7903 - 3-DAY COURTESY TRANSPORTATION 37610 miles
01/29/2007 568538 # H2505 - ELECTRONIC BRAKE AND TRACTION CONTROL MODULE REPLACEMENT 37478 miles
01/29/2007 568538 # Z7903 - 3-DAY COURTESY TRANSPORTATION 37478 miles
09/18/2006 558205 # C7200 - REAR SEAT ARMREST REPLACEMENT 33418 miles
09/18/2006 558205 # C2021 - SUNSHADE REPLACEMENT - LEFT SIDE 33418 miles
09/18/2006 558205 # N2460 - SUNROOF SWITCH REPLACEMENT 33418 miles
09/18/2006 558205 # Z7902 - 2-DAY COURTESY TRANSPORTATION 33418 miles
09/06/2006 557268 # C3128 - HEADLINING TRIM PANEL REPLACEMENT 33183 miles
09/06/2006 557268 # Z7902 - 2-DAY COURTESY TRANSPORTATION 33183 miles
08/17/2006 555683 # R0520 - RADIO ANTENNA MODULE REPLACEMENT 32624 miles
08/17/2006 555683 # Z7903 - 3-DAY COURTESY TRANSPORTATION 32624 miles
08/17/2006 555683 # C3540 - REAR SIDE DOOR TRIM PANEL REPLACEMENT - RIGHT SIDE 32624 miles
08/17/2006 555683 # C3541 - REAR SIDE DOOR TRIM PANEL REPLACEMENT - LEFT SIDE 32624 miles
06/28/2006 E22945 # Z2082 - ROADSIDE SERVICE (FUEL DELIVERY) 29000 miles
04/20/2006 545775 # J3480 - PUMP AND/OR GASKET, COOLANT - REPLACE 26531 miles
04/20/2006 545775 # Z7902 - 2-DAY COURTESY TRANSPORTATION 26531 miles
01/31/2006 093000 # Z8013 - ROADSIDE SERVICE (FUEL DELIVERY) 21805 miles
01/26/2006 A71697 # Z2085 - ROADSIDE SERVICE (PREMIUM) 21000 miles
10/24/2005 350956 # C7200 - REAR SEAT ARMREST REPLACEMENT 17699 miles
08/30/2005 346782 # V1302 - 05004 - REPLACE SDM 16230 miles
08/30/2005 346782 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 16230 miles
08/30/2005 346782 # E5801 - SHOCK ABSORBER, REAR - LEFT - REPLACE 16230 miles
03/11/2005 333298 S Z7902 - 2-DAY COURTESY TRANSPORTATION 11465 miles
03/07/2005 332710 # J3480 - PUMP AND/OR GASKET, COOLANT - REPLACE 11464 miles
03/07/2005 332710 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 11464 miles
03/07/2005 332710 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 11464 miles
03/07/2005 332710 # B2780 - SUNROOF MODULE ASSEMBLY REPLACEMENT 11464 miles
03/07/2005 332710 # D2109 - HEATER/AIR DISTRIBUTION CASE, PASSENGER COMPARTMENT (AIR C 11464 miles
03/07/2005 332710 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 11464 miles
03/07/2005 332710 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 11464 miles
08/11/2004 315858 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 5008 miles
08/11/2004 315858 # R5140 - MODULE, VEHICLE INTERFACE UNIT VIU/VCIM - REPLACE 5008 miles
08/11/2004 315858 # C2860 - CONSOLE ASSEMBLY - R&R OR REPLACE 5008 miles
08/11/2004 315858 # Z7901 - 1-DAY COURTESY TRANSPORTATION 5008 miles
02/12/2004 146305 # Z6999 - PDI RELATED FLUID ADDS 16 miles
02/12/2004 146311 # N4821 - MODULE - AUTOMATIC DOOR LOCKING SYSTEM - REPLACE 16 miles
01/26/2004 A54502 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
1G6DN56S650129539 APPLICABLE WARRANTIES
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 01/08/2005 69 miles 01/08/2009 50069 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 01/08/2005 69 miles 01/08/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 01/08/2005 69 miles 01/08/2013 80069 miles
48/50000 CALIFORNIA EMISSIONS 01/08/2005 69 miles 01/08/2009 50069 miles
84/70000 CALIFORNIA SELECT COMPONENT 01/08/2005 69 miles 01/08/2012 70069 miles
CLAIM HISTORY
08/18/2007 238682 # R4490 - TRANSMITTER, REMOTE DOOR/REAR COMPARTMENT LOCK - REPLACE 20946 miles
08/18/2007 238682 # E5800 - SHOCK ABSORBER, REAR - RIGHT - REPLACE 20946 miles
08/18/2007 238682 # J3260 - COOLANT RECOVERY RESERVOIR REPLACEMENT 20946 miles
08/18/2007 238682 # Z7903 - 3-DAY COURTESY TRANSPORTATION 20946 miles
11/17/2006 014083 # N0110 - BATTERY - ONE - REPLACE 15557 miles
09/07/2006 009192 # E0716 - DIAGNOSTIC SYSTEM CHECK - TIRE PRESSURE MONITORING 14700 miles
11/16/2005 089767 # C3128 - HEADLINING TRIM PANEL REPLACEMENT 6864 miles
10/13/2005 087297 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 6270 miles
05/16/2005 076406 # N0110 - BATTERY - ONE - REPLACE 2463 miles
09/20/2004 049774 I Z6998 - PDI ADDS 2 miles
08/27/2004 A29539 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
