Originally Posted by mgscustomtune Could you check this one out l just purchased a V 1g6dn56sx50122268 |
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/80000 BUMPER TO BUMPER LIMITED WARRANTY 08/31/2004 35 kilometres 08/31/2008 80035 kilometres
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 08/31/2004 35 kilometres 08/31/2010 Unlimited kilometres
96/130000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/31/2004 35 kilometres 08/31/2012 130035 kilometres
48/80000 FEDERAL EMISSION 08/31/2004 35 kilometres 08/31/2008 80035 kilometres
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
10/01/2007 451965 # B4050 - LINK OR SPRING, FRONT DOOR HOLD OPEN - RIGHT - REPLACE 54252 kilometres
10/01/2007 451965 # B4051 - LINK OR SPRING, FRONT DOOR HOLD OPEN - LEFT - REPLACE 54252 kilometres
10/01/2007 451965 # C2860 - CONSOLE ASSEMBLY - R&R OR REPLACE 54252 kilometres
10/01/2007 451965 # Z8052 - CAD MAINTENANCE (AIR CLEANER RPL) 54252 kilometres
10/01/2007 451965 # Z8057 - CAD MAINTENANCE (BRAKES) 54252 kilometres
10/01/2007 451965 # Z8063 - REPLACE PASSENGER COMPARTMENT AIR FILTER. 54252 kilometres
10/01/2007 451965 # Z8066 - SEMI-ANNUAL INSPECTION (CAD MAINTENANCE) 54252 kilometres
07/03/2007 121521 # C8870 - INFLATABLE RESTRAINT PASSENGER SEAT SUPPRESSION MODULE REP 51419 kilometres
07/03/2007 121521 # Z7901 - 1-DAY COURTESY TRANSPORTATION 51419 kilometres
06/19/2007 120371 # D1322 - MOTOR AND/OR FAN, BLOWER - R&R OR REPLACE 50253 kilometres
06/19/2007 120371 # Z7901 - 1-DAY COURTESY TRANSPORTATION 50253 kilometres
05/01/2007 116087 # N0760 - BULBS, STOP, TAIL, AND TURN LAMP (RIGHT) - REPLACE 48213 kilometres
04/23/2007 115300 # B4660 - REAR SIDE DOOR LOCK REPLACEMENT - RIGHT SIDE 47714 kilometres
04/23/2007 115300 # Z7901 - 1-DAY COURTESY TRANSPORTATION 47714 kilometres
04/23/2007 115300 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 47714 kilometres
04/23/2007 115300 # Z8052 - CAD MAINTENANCE (AIR CLEANER RPL) 47714 kilometres
04/23/2007 115300 # Z8063 - REPLACE PASSENGER COMPARTMENT AIR FILTER. 47714 kilometres
04/23/2007 115300 # Z8066 - SEMI-ANNUAL INSPECTION (CAD MAINTENANCE) 47714 kilometres
01/16/2007 107381 # B0764 - SHIELD AND/OR LINER - FRONT WHEELHOUSE PANEL - RIGHT - REP 44375 kilometres
11/02/2006 101429 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 41863 kilometres
11/02/2006 101429 # Z8067 - ANNUAL INSPECTION (CAD MAINTENANCE) 41863 kilometres
07/17/2006 991557 # E0460 - STEM, VALVE - REPLACE 37714 kilometres
07/17/2006 991557 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 37714 kilometres
07/17/2006 991557 # Z7901 - 1-DAY COURTESY TRANSPORTATION 37714 kilometres
07/17/2006 991557 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 37714 kilometres
05/31/2006 987503 # B4261 - FRONT SIDE DOOR LOCK REPLACEMENT - LEFT SIDE 33935 kilometres
05/31/2006 987503 # Z7902 - 2-DAY COURTESY TRANSPORTATION 33935 kilometres
04/11/2006 983029 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 30000 kilometres
03/01/2006 979360 # B4661 - REAR SIDE DOOR LOCK REPLACEMENT - LEFT SIDE 28887 kilometres
03/01/2006 979360 # Z7901 - 1-DAY COURTESY TRANSPORTATION 28887 kilometres
11/15/2005 970218 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 25050 kilometres
11/15/2005 970218 # Z7901 - 1-DAY COURTESY TRANSPORTATION 25050 kilometres
11/15/2005 970218 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 25050 kilometres
11/15/2005 970218 # Z8063 - REPLACE PASSENGER COMPARTMENT AIR FILTER. 25050 kilometres
11/15/2005 970218 # Z8067 - ANNUAL INSPECTION (CAD MAINTENANCE) 25050 kilometres
07/04/2005 957269 # B7766 - MOLDING, ROCKER PANEL - REAR - RIGHT - R&R OR REPLACE 17933 kilometres
02/14/2005 943426 # C0040 - INSIDE REARVIEW MIRROR REPLACEMENT 9648 kilometres
02/14/2005 943426 # Z7901 - 1-DAY COURTESY TRANSPORTATION 9648 kilometres
02/14/2005 943426 # Z8050 - MAINTENANCE (LUBE OIL FILTER) 9648 kilometres
02/14/2005 943426 # Z8066 - SEMI-ANNUAL INSPECTION (CAD MAINTENANCE) 9648 kilometres
01/25/2005 941565 # E7690 - SENSOR, STEERING WHEEL ROTATION - REPLACE 873 kilometres
01/25/2005 941565 # Y0022 - CUSTOMER SATISFACTION PROGRAM - INCORRECT INSIDE REARVIEW 873 kilometres
01/25/2005 941565 # Z7901 - 1-DAY COURTESY TRANSPORTATION 873 kilometres
08/16/2004 A22268 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 kilometres
