Originally Posted by jjava99 1g6dn57s140162428
thanks |
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 03/25/2005 0 miles 03/25/2009 50000 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/25/2005 0 miles 03/25/2011 100000 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/25/2005 0 miles 03/25/2013 80000 miles
48/50000 FEDERAL EMISSION 03/25/2005 0 miles 03/25/2009 50000 miles
72/100000 LUXURY CERTIFIED PRE-OWNED LIMITED WARRANTY 03/25/2005 0 miles 03/25/2011 100000 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
07/30/2007 073346 # E7690 - SENSOR, STEERING WHEEL ROTATION - REPLACE 43546 miles
07/30/2007 073346 # E0722 - TIRE PRESSURE INDICATOR SENSOR REPLACEMENT 43546 miles
04/24/2007 071122 # E2020 - WHEEL ALIGNMENT - CHECK AND/OR ADJUST 39762 miles
04/24/2007 071122 # N6642 - WIRING AND/OR CONNECTOR - HVAC SYSTEM - REPAIR OR REPLACE 39762 miles
04/24/2007 071122 # J3100 - RADIATOR ASSEMBLY - REPLACE 39762 miles
04/24/2007 071122 # Z7902 - 2-DAY COURTESY TRANSPORTATION 39762 miles
08/25/2006 127834 # R0760 - RADIO, REMOVE AND REPLACE 31650 miles
08/23/2006 127716 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 31462 miles
06/23/2006 124659 # F2043 - FLANGE, PINION SHAFT - REAR DIFFERENTIAL - REPLACE 29275 miles
06/23/2006 124659 # E0721 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - LEFT - REPLACE 29275 miles
06/23/2006 124659 # Z7901 - 1-DAY COURTESY TRANSPORTATION 29275 miles
03/30/2006 120759 # Z7903 - 3-DAY COURTESY TRANSPORTATION 25364 miles
03/30/2006 120759 # K0800 - DISC AND/OR CLUTCH COVER, CLUTCH - REPLACE 25364 miles
03/01/2006 119439 # E0716 - DIAGNOSTIC SYSTEM CHECK - TIRE PRESSURE MONITORING 24760 miles
03/01/2006 119439 # B4379 - STRIKER, FRONT/REAR/SWING-OUT OR SLIDING DOORS - ADJUST OR 24760 miles
03/01/2006 119439 # C2021 - SUNSHADE REPLACEMENT - LEFT SIDE 24760 miles
03/01/2006 119439 # H2800 - PARKING BRAKE - ADJUST 24760 miles
03/01/2006 119439 # Z7901 - 1-DAY COURTESY TRANSPORTATION 24760 miles
08/22/2005 323329 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 16358 miles
08/08/2005 437340 # R5132 - CABLE, COAX ASSEMBLY (CELLULAR) - REPLACE 14736 miles
08/08/2005 437340 # H2800 - PARKING BRAKE - ADJUST 14736 miles
08/08/2005 437340 # Z7901 - 1-DAY COURTESY TRANSPORTATION 14736 miles
08/08/2005 437340 # V1302 - 05004 - REPLACE SDM 14736 miles
07/12/2005 179789 # Z2080 - ROADSIDE SERVICE (TOWING) 13000 miles
05/12/2005 430450 # C3128 - HEADLINING TRIM PANEL REPLACEMENT 5876 miles
05/12/2005 430450 # C2686 - LAMP ASSEMBLY, INTERIOR AND/OR REAR COMPARTMENT - REPLACE 5876 miles
05/12/2005 430450 # E0431 - TIRE, GOODYEAR/DUNLOP - REPLACE 5876 miles
05/12/2005 430450 # Z7902 - 2-DAY COURTESY TRANSPORTATION 5876 miles
04/04/2005 427728 # B1308 - GRILLE ASSEMBLY - ONE PIECE - REPLACE 3539 miles
04/04/2005 427728 # E0203 - WHEEL - FOUR - BALANCE 3539 miles
04/04/2005 427728 # C2860 - CONSOLE ASSEMBLY - R&R OR REPLACE 3539 miles
04/04/2005 427728 # C4202 - FRONT FLOOR PANEL CARPET REPLACEMENT 3539 miles
04/04/2005 427728 # Z7901 - 1-DAY COURTESY TRANSPORTATION 3539 miles
02/02/2005 423181 # Y0027 - DOOR LATCH FREEZING IN COLD TEMPERATURES - APPLY SUPER LUB 1899 miles
11/29/2004 417961 # N0110 - BATTERY - ONE - REPLACE 1846 miles
11/29/2004 417961 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 1846 miles
11/29/2004 417961 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 1846 miles
02/19/2004 A62428 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
