Originally Posted by boot275 Whoops! Sorry, just jumped to the last thread without reading the first thread. I just went in and became a "supporting member". If you can provide me with:
"Service information and RPO codes" for SRX '04 VIN 1GYDE63A040137613 I'd appreciate it.
thanks, Bruce |
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 06/28/2004 0 miles 06/28/2008 50000 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 06/28/2004 0 miles 06/28/2010 100000 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 06/28/2004 0 miles 06/28/2012 80000 miles
48/50000 FEDERAL EMISSION 06/28/2004 0 miles 06/28/2008 50000 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
04/23/2007 162492 # N0680 - BULBS, PARK AND TURN SIGNAL LAMP (RIGHT) - REPLACE 31651 miles
02/06/2007 159934 # E7690 - SENSOR, STEERING WHEEL ROTATION - REPLACE 26967 miles
02/06/2007 159934 # E2147 - LINK OR BUSHINGS, FRONT STABILIZER SHAFT AT CONTROL ARM - 26967 miles
02/06/2007 159934 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 26967 miles
02/06/2007 159934 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 26967 miles
01/23/2007 159562 # E9050 - POWER STEERING PUMP REPLACEMENT 26027 miles
01/23/2007 159562 # E3807 - SHOCK ABSORBER, FRONT - BOTH - REPLACE 26027 miles
01/23/2007 159562 # H9991 - CUSTOMER CONCERN NOT DUPLICATED 26027 miles
01/23/2007 159562 # C3904 - STRAP (HANDLE) AND/OR ESCUTCHEON, ASSIST - RIGHT - FRONT - 26027 miles
01/23/2007 159562 # Z7903 - 3-DAY COURTESY TRANSPORTATION 26027 miles
05/09/2006 150974 # E2320 - BEARING AND HUB ASSEMBLY, FRONT WHEEL - RIGHT - REPLACE 11988 miles
04/26/2006 150477 # V1457 - 06503 - REPROGRAM ECM 11723 miles
04/26/2006 150477 # H0700 - HYDRAULIC BRAKE SYSTEM BLEEDING 11723 miles
12/27/2005 146280 # E9050 - POWER STEERING PUMP REPLACEMENT 10364 miles
12/27/2005 146280 # R5110 - MAST, ANTENNA (COMMUNICATION AND/OR NAVIGATION SYSTEM) - R 10364 miles
12/27/2005 146280 # J0960 - OIL FILTER ADAPTER REPLACEMENT 10364 miles
12/27/2005 146280 # Z7902 - 2-DAY COURTESY TRANSPORTATION 10364 miles
08/09/2005 141258 # V1302 - 05004 - REPLACE SDM 6733 miles
08/09/2005 141258 # V1318 - 05018 - F/CMVSS NONCOMPLIANCE - ELECTRONIC THROTTLE CONTRO 6733 miles
02/15/2005 134433 0 M0017 - LUBE, OIL AND FILTER 3503 miles
02/15/2005 134433 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - REPLACE 3503 miles
02/15/2005 134433 # H0137 - ROTOR ASSEMBLY - REAR - BOTH - REPLACE 3503 miles
07/12/2004 126014 # V1138 - REPROGRAM ABS/TCS MODULE AND BPP SENSOR 15 miles
07/12/2004 126014 # V1176 - 04045 - APPLY ADHESIVE TO CHMSL BEZEL 15 miles
11/25/2003 A37613 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
A45 - MULTI-DRIVER MEMORY SETTINGS
AH8 - 8-WAY POWER PASSENGER SEAT
AL2 - POWER ADJUSTABLE LUMBAR
AQ9 - LUXURY FRONT BUCKET SEATS
AY0 - INFLATABLE RESTRAINT DRI & PASS
B19 - BURLED WALNUT WOOD TRIM
C57 - REAR AIR CONDITIONING
C8K - GVW RATING 2675 KG
CJ2 - DUAL ZONE CLIMATE CONTROL
D7E - RECONFIGURABLE STORAGE
DD7 - ELECTROCHROMIC ISRV MIRROR
DL5 - DECAL - ROADSIDE SERVICE INFO
DR2 - ELECTROCHROMIC OSRV DRIVER MIRROR
FE1 - 4-WHEEL INDEPENDENT SUSPENSION
FE9 - 50-STATE EMISSIONS
GU5 - AXLE REAR 3.23 RATIO
IL2 - TRIM INTERIOR DESIGN
JE5 - POWER ANTILOCK BRAKE SYSTEM
JF4 - POWER ADJUST PEDALS
JJA - PT DRESS SUBASSEMBLY INSTALLED
JL4 - STABILITRAK
KA1 - HEATED FRONT SEATS
KG4 - 150 AMP GENERATOR
LH2 - 4.6L V8 VVT SFI ENGINE 320 HP
MV3 - ALL WHEEL DRIVE
MX7 - ALL WHEEL DRIVE
N30 - STEERING WHEEL DELUXE
NT9 - EMISSION - FEDERAL
Q16 - P235/60R18 FRT & P255/55R18 RR ALL-SEASON, BLACKWALL TIRES
QF8 - WHEEL 18 X 8, ALUMINUM, MACHINE FINISHED
R6M - NEW JERSEY COST SURCHARGE
SLM - STOCK ORDERS
U2S - AUDIO SYSTEM WITH IN-DASH 6 CD CHANGER
U30 - CLUSTER INST, TACH, CLOCK
U42 - REAR SEAT ENTERTAINMENT
U66 - SPEAKER SYSTEM 7, CUSTOM
UA6 - THEFT DETERRENT SYSTEM
UE1 - 1-YR ONSTAR DIRECT/CONN SVC
UG1 - HOMELINK GARAGE DOOR OPENER
UJ6 - TIRE PRESSURE MONITOR
V4V - SRX V8 MODEL CONVERSION
V73 - VEHICLE STATEMENT
VK3 - LICENSE PLATE FRT MOUNTING PKG
VM3 - LABEL INFORMATION CONUMER, CONTAINS BPR IMP STANDARD FOR FRT 5MPH & RR 5MPH
YB6 - AXLE(BASE EQUIP) PROCESSING OPT
YD5 - SPRING FRT BASE EQUIP, PROC OPT
YD6 - SPRING RR, BASE EQUIP, PROC OPT
192 - EBONY
19I - INTERIOR TRIM EBONY
1SB - SRX-V8 STANDARD PACKAGE
1SZ - PREFERRED EQUIPMENT SAVINGS
67U - LIGHT PLATINUM
6NC - COMPONENT FRT LH COMP SEL SUSP
7NC - COMPONENT FRT RH COMP SEL SUSP
8GF - COMPONENT RR LH COMP SEL SUSP
9GF - COMPONENT RR RH COMP SEL SUSP
