Originally Posted by trukk I've got a buddy looking for a V.
Can someone run: 1G6DN56S350160067 Thanks, Chris |
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
12/12000 BUYBACK LIMITED WARRANTY 01/12/2007 18605 miles 01/12/2008 30605 miles
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 07/02/2005 200 miles 07/02/2009 50200 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/02/2005 200 miles 07/02/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/02/2005 200 miles 07/02/2013 80200 miles
48/50000 FEDERAL EMISSION 07/02/2005 200 miles 07/02/2009 50200 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
12/14/2007 101345 # N0110 - BATTERY - ONE - REPLACE 27052 miles
10/28/2007 101638 # F3272 - PLUG, DIFFERENTIAL CARRIER DRAIN - REPLACE 25379 miles
10/28/2007 101638 # F3273 - PLUG, DIFFERENTIAL CARRIER FILL - REPLACE 25379 miles
09/17/2007 206118 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 24683 miles
09/17/2007 206118 # Z7903 - 3-DAY COURTESY TRANSPORTATION 24683 miles
11/09/2006 354072 # E1892 - SUPPORT, REAR FRAME - REPLACE 17802 miles
11/09/2006 354072 # Z7410 - GOODWILL OIL CHANGE 17802 miles
09/22/2006 012692 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 16187 miles
09/22/2006 012692 0 M0015 - LUBE, OIL AND FILTER 16187 miles
07/17/2006 097688 # E0420 - WHEEL - ONE - R&R OR REPLACE 13775 miles
06/19/2006 095144 # Z7902 - 2-DAY COURTESY TRANSPORTATION 13139 miles
06/19/2006 095144 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 13139 miles
06/19/2006 095144 # C4020 - TRIM ASSEMBLY, QUARTER - RIGHT - R&R OR REPLACE 13139 miles
06/19/2006 095144 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 13139 miles
05/08/2006 091435 # Z7903 - 3-DAY COURTESY TRANSPORTATION 11970 miles
05/08/2006 091435 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 11970 miles
03/24/2006 035167 # N0851 - BULB, FOG LAMP (LEFT) - REPLACE 10320 miles
01/23/2006 033596 # K0800 - DISC AND/OR CLUTCH COVER, CLUTCH - REPLACE 8325 miles
01/23/2006 033596 # Z7903 - 3-DAY COURTESY TRANSPORTATION 8325 miles
01/11/2006 033373 # F1280 - PROPELLER SHAFT ASSEMBLY (BETWEEN TRANS AND REAR DIFFERENT 7852 miles
01/11/2006 033373 # Z7901 - 1-DAY COURTESY TRANSPORTATION 7852 miles
12/23/2005 032902 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 7285 miles
12/23/2005 032902 # Z7091 - NON-WARRANTY INCREMENTAL EXPENSE/WHOLESALE 7285 miles
12/23/2005 032902 # Z7902 - 2-DAY COURTESY TRANSPORTATION 7285 miles
12/22/2005 995053 # Z2080 - ROADSIDE SERVICE (TOWING) 7300 miles
11/28/2005 032253 # E2020 - WHEEL ALIGNMENT - CHECK AND/OR ADJUST 6359 miles
11/28/2005 032253 # Z7901 - 1-DAY COURTESY TRANSPORTATION 6359 miles
11/15/2005 031970 # H9711 - FRAME, REAR SUPPLEMENTAL BUSHINGS - INSTALL 6023 miles
11/15/2005 031970 # F1280 - PROPELLER SHAFT ASSEMBLY (BETWEEN TRANS AND REAR DIFFERENT 6023 miles
11/15/2005 031970 # D0362 - CONTROL, HEATER AND AIR CONDITIONING - REPLACE 6023 miles
11/15/2005 031970 # B2720 - SUNROOF WINDOW HEIGHT AND OPENING FIT ADJUSTMENT 6023 miles
11/15/2005 031970 # Z7902 - 2-DAY COURTESY TRANSPORTATION 6023 miles
07/15/2005 963776 # B7571 - MOLDING, WINDSHIELD SIDE PILLAR REVEAL - LEFT - R&R OR REP 623 miles
07/15/2005 963776 # C4020 - TRIM ASSEMBLY, QUARTER - RIGHT - R&R OR REPLACE 623 miles
07/15/2005 963776 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 623 miles
05/09/2005 356048 # B5410 - BODY - RESEAL 44 miles
05/09/2005 356048 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 44 miles
05/09/2005 356048 # C4610 - NET AND/OR TRAY, REAR COMPARTMENT CARGO - REPLACE 44 miles
11/05/2004 A60067 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
