Originally Posted by luvmy03caddy super duper pretty please with a cherry on top
I beg
1G6DN56S150105052 |
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 05/21/2005 127 miles 05/21/2009 50127 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/21/2005 127 miles 05/21/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/21/2005 127 miles 05/21/2013 80127 miles
48/50000 FEDERAL EMISSION 05/21/2005 127 miles 05/21/2009 50127 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
03/28/2007 305363 # B9650 - HIGH MOUNT STOP LAMP REPLACEMENT 25736 miles
09/08/2006 098372 # C3384 - BEZEL, FRONT DOOR INSIDE PULL HANDLE - RIGHT - REPLACE 18654 miles
08/29/2006 097141 # N0760 - BULBS, STOP, TAIL, AND TURN LAMP (RIGHT) - REPLACE 18017 miles
07/19/2006 091594 # C3385 - BEZEL, FRONT DOOR INSIDE PULL HANDLE - LEFT - REPLACE 16787 miles
07/19/2006 091594 # D1442 - DEFLECTOR, AIR (OUTLET VENT) - RIGHT CENTER - REPLACE 16787 miles
07/19/2006 091594 # N2155 - SWITCH - DOOR WINDOW - LEFT REAR - REPLACE 16787 miles
06/28/2006 088828 # C3385 - BEZEL, FRONT DOOR INSIDE PULL HANDLE - LEFT - REPLACE 15782 miles
06/28/2006 088828 # C3544 - BEZEL, REAR DOOR INSIDE HANDLE - RIGHT - REPLACE 15782 miles
06/28/2006 088828 # C3545 - BEZEL, REAR DOOR INSIDE HANDLE - LEFT - REPLACE 15782 miles
06/02/2006 132905 # C2200 - INSTRUMENT PANEL ASHTRAY REPLACEMENT 14872 miles
06/02/2006 132905 # Z7901 - 1-DAY COURTESY TRANSPORTATION 14872 miles
06/02/2006 132905 # R0760 - RADIO, REMOVE AND REPLACE 14872 miles
06/02/2006 132905 # D0362 - CONTROL, HEATER AND AIR CONDITIONING - REPLACE 14872 miles
05/30/2006 132728 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 14763 miles
05/03/2006 279777 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 13698 miles
05/03/2006 279777 # Z7902 - 2-DAY COURTESY TRANSPORTATION 13698 miles
04/04/2006 277513 # N9995 - CUSTOMER CONCERN NOT DUPLICATED 12676 miles
04/04/2006 277513 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 12676 miles
04/04/2006 277513 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 12676 miles
04/04/2006 277513 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 12676 miles
04/04/2006 277513 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 12676 miles
04/04/2006 277513 # Z7902 - 2-DAY COURTESY TRANSPORTATION 12676 miles
07/25/2005 257463 # B2720 - SUNROOF WINDOW HEIGHT AND OPENING FIT ADJUSTMENT 3282 miles
07/25/2005 257463 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 3282 miles
07/25/2005 257463 # Z7903 - 3-DAY COURTESY TRANSPORTATION 3282 miles
07/22/2005 257337 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 3141 miles
07/22/2005 257337 # B7280 - HEADLAMP - AIM 3141 miles
05/23/2005 252168 # N0761 - BULBS, STOP, TAIL, AND TURN LAMP (LEFT) - REPLACE 244 miles
06/02/2004 A05052 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
