Originally Posted by chahockey could i get a vin check on this? thank you!
1G6DN57S940158563 |
GM Vehicle Inquiry System
Summary
Home - Summary - Claim History - Vehicle Build - Vehicle Component - Delivery Information - Dealer Information - Service Contract - Warranty Block - Branded Title
Help
VIN : 1G6DN57S940158563
VEHICLE INFORMATION
Merchandising Model : 6DN69 -2004 CTS-V Warranty Start Date : 03/01/2004
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : MOORE CADILLAC, INC.
15950 MANCHESTER RD
ELLISVILLE , MO 63011-2170
(636) 394-0300
Selling Source : 12 - CADILLAC
Site Code : 37405
Business Associate Code : 119187
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04043 LOWER CONTROL ARM WASHER N/A Closed
RC 04068 FUEL FEED JUMPER PIPE ASSEMBLY - REPLACE N/A Closed
RC 05004 INADVERTENT DRIVER AIRBAG DEPLOY WHEN IGNITION KEY TURNED TO ON POSITION N/A Closed
SERVICE INFORMATIONAL ITEMS
SB 06047 DETERMINE IF ONSTAR CAN BE UPGRADED AT GM GLOBALCONNECT-SEE TSB 05-08-46-006 02/21/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID 57MM308R XM Status Active Refer to Help page for details or:
www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 03/01/2004 21 miles 03/01/2008 50021 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/01/2004 21 miles 03/01/2010 100021 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/01/2004 21 miles 03/01/2012 80021 miles
48/50000 FEDERAL EMISSION 03/01/2004 21 miles 03/01/2008 50021 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/13/2007 J30348 # Z8020 - ONSTAR - TOW 56000 miles
02/28/2006 071673 # J3100 - RADIATOR REPLACEMENT 39407 miles
02/28/2006 071673 # N0760 - TAIL LAMP BULB REPLACEMENT 39407 miles
02/28/2006 071673 # V1302 - 05004 - REPLACE SDM 39407 miles
02/28/2006 071673 # N1720 - FUSE - REPLACE 39407 miles
02/28/2006 071673 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 39407 miles
09/27/2005 067356 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 31062 miles
08/24/2005 066427 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 26905 miles
08/10/2005 065993 # R5604 - DIGITAL RADIO ANTENNA REPLACEMENT 26902 miles
08/10/2005 065993 # F3030 - BUSHING, REAR DIFFERENTIAL DAMPING - RIGHT - REPLACE 26902 miles
08/10/2005 065993 # E4191 - TIE ROD END - LEFT - REPLACE 26902 miles
08/10/2005 065993 # F1617 - SEAL, AXLE SHAFT OIL - REAR AXLE - BOTH - REPLACE 26902 miles
04/28/2005 063910 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 19022 miles
04/28/2005 063910 # N6642 - HVAC SYSTEM WIRING AND/OR CONNECTOR REPAIR OR REPLACEMENT 19022 miles
09/02/2004 161692 # J4640 - STARTER REPLACEMENT 11630 miles
09/02/2004 161692 # N4199 - INSTRUMENT CLUSTER REPROGRAMMING WITH SPS 11630 miles
09/02/2004 161692 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 11630 miles
09/02/2004 161692 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 11630 miles
05/11/2004 158709 # E2020 - WHEEL ALIGNMENT MEASUREMENT 3647 miles
02/09/2004 A58563 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
CHECK HISTORY INFORMATION
Vehicle Has No Associated Check History Information.
? 2009 General Motors. All Rights Reserved.
Claim History
Help
CLAIM HISTORY
Repair Order Date : 01/13/2007 Repair Order Number : J30348 Odometer Reading : 56000 miles
Serviced By : GM ROADSIDE ASSISTANCE/CCAS
ONE CABOT RD
MEDFORD, MA 02155-5117
Site Code : 34415
Business Associate Code : 207453
Cycle Date Cycle Nbr Case Type Labor Operation Part Auth Code Person Code Line Total Comments
01/19/2007 762 01 # Z8020 - ONSTAR - TOW N/A CA N/A $ 48.23 N
Repair Order Date : 02/28/2006 Repair Order Number : 071673 Odometer Reading : 39407 miles
Serviced By : QUALITY BUICK PONTIAC GMC CADILLAC
1620 E HOMER ADAMS PKWY
ALTON, IL 62002-5601
(618) 465-8881 Selling Source : 12 - CADILLAC
Site Code : 19726
Business Associate Code : 116526
03/10/2006 672 01 # J3100 - RADIATOR REPLACEMENT 19129908 - RADIATOR N/A N/A $ 482.58 N
03/10/2006 672 02 # N0760 - TAIL LAMP BULB REPLACEMENT 09441839 - BULB LP N/A N/A $ 35.21 N
03/10/2006 672 03 # V1302 - 05004 - REPLACE SDM 19115245 - MDL SEN N/A N/A $ 239.59 N
03/10/2006 672 04 # N1720 - FUSE - REPLACE 88909757 - FUSE KIT N/A N/A $ 18.48 N
03/10/2006 672 05 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT N/A N/A N/A $ 40.63 N
Repair Order Date : 09/27/2005 Repair Order Number : 067356 Odometer Reading : 31062 miles
Site Code : 19726
09/30/2005 626 01 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 25774006 - SENSOR B N/A $ 147.87 N
Repair Order Date : 08/24/2005 Repair Order Number : 066427 Odometer Reading : 26905 miles
Site Code : 19726
09/16/2005 622 01 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 25774006 - SENSOR N/A N/A $ 151.25 N
Repair Order Date : 08/10/2005 Repair Order Number : 065993 Odometer Reading : 26902 miles
Site Code : 19726
09/20/2005 623 01 # R5604 - DIGITAL RADIO ANTENNA REPLACEMENT 25745960 - ANTENNA L N/A $ 208.15 Y
08/26/2005 616 02 # F3030 - BUSHING, REAR DIFFERENTIAL DAMPING - RIGHT - REPLACE 89058605 - BUSHING N/A N/A $ 150.00 N
08/26/2005 616 03 # E4191 - TIE ROD END - LEFT - REPLACE 25737367 - LINK N/A N/A $ 180.85 N
08/26/2005 616 04 # F1617 - SEAL, AXLE SHAFT OIL - REAR AXLE - BOTH - REPLACE 88996591 - SEAL B N/A $ 101.53 N
Repair Order Date : 04/28/2005 Repair Order Number : 063910 Odometer Reading : 19022 miles
Site Code : 19726
05/31/2005 591 01 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 12581554 - PIPE N/A N/A $ 86.54 N
05/31/2005 591 02 # N6642 - HVAC SYSTEM WIRING AND/OR CONNECTOR REPAIR OR REPLACEMENT 12102748 N/A N/A $ 59.48 N
Repair Order Date : 09/02/2004 Repair Order Number : 161692 Odometer Reading : 11630 miles
Serviced By : JACK SCHMITT OLDSMOBILE-CADILLAC, INC.
915 W HWY 50
O FALLON, IL 62269-1829
(618) 632-1000 Selling Source : 12 - CADILLAC
Site Code : 37398
Business Associate Code : 111347
09/14/2004 517 01 # N4199 - INSTRUMENT CLUSTER REPROGRAMMING WITH SPS N/A E N/A $ 201.70 N
09/10/2004 516 01 # J4640 - STARTER REPLACEMENT 89017491 - STRTR REM N/A N/A $ 309.13 N
09/10/2004 516 03 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 10282253 - NUT N/A N/A $ 39.75 N
09/10/2004 516 04 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 89017491 - STRTR REM N/A N/A $ 20.30 N
Repair Order Date : 05/11/2004 Repair Order Number : 158709 Odometer Reading : 3647 miles
915 W HWY 50
Site Code : 37398
05/21/2004 484 01 # E2020 - WHEEL ALIGNMENT MEASUREMENT N/A N/A N/A $ 100.85 N
Repair Order Date : 02/09/2004 Repair Order Number : A58563 Odometer Reading : 0 miles
Serviced By : MOORE CADILLAC, INC.
15950 MANCHESTER RD
ELLISVILLE, MO 63011-2170
(636) 394-0300 Selling Source : 12 - CADILLAC
Site Code : 37405
02/13/2004 456 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N/A N/A $ 128.90 N
CHECK HISTORY
Vehicle Has No Associated Check History.
Vehicle Build
Help
VIN 1G6DN57S940158563
VEHICLE BUILD
Gross Vehicle Weight Rating : 2182 kg (4811 lb) Order Number : GTDKZ9
Build Date : 02/09/2004 Build Plant : 140D
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AH8 - 10-WAY PWR. PASS. SEAT W/ PWR. LUMBAR AL2 - POWER LUMBAR CONTROL
AM9 - SPLIT-FOLDING REAR SEAT AQ9 - SEAT FRT BKT, LUXURY
AY0 - INFLATABLE RESTRAINT DRI & PASS A45 - MEMORY SEAT ADJUSTER
CE4 - WASHER HEADLAMP, HIGH PRESSURE CF5 - EXPRESS OPEN SUNROOF
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP DD8 - MIRROR AUTO DAY/NIGHT I/S R/V
DL5 - DECAL - ROADSIDE SERVICE INFO DR5 - MIRROR O/S REMOTE L/H R/H
FE4 - SUSPENSION FE9 - 50-STATE EMISSIONS
GT4 - AXLE REAR 3.73 RATIO IL3 - TRIM INTERIOR DESIGN
JJA - PT DRESS SUBASSEMBLY INSTALLED J56 - BRAKES, ANTILOCK
KA1 - HEATED FRONT SEATS KG4 - 150 AMP GENERATOR
LS6 - LS6 5.7L 400 HP V8 ENGINE MN6 - TREMEC 6-SPEED MANUAL TRANS
M12 - MANUAL TRANS NT9 - EMISSION - FEDERAL
N34 - STEERING WHEEL, LEATHER PDL - LUXURY PACKAGE
P32 - WHEEL 18" ALUMINUM QKR - P245/45R18 ALL SEASON BW
R8X - FLEET GUARANTEED DELIVERY PGRM SLM - STOCK ORDERS
TT6 - HIGH INTENSITY HEADLAMPS UAV - DVD NAVIGATION SYSTEM INCL: XM SATELLITE RADIO-100 CHANNEL COAST TO COAST DIGITAL SOUND (SUBSCRIPTION CHARGES EXTRA- DELETES COMPASS IN MIRROR)
UA6 - THEFT DETERENT SYSTEM UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1YR SAFE & SOUND PLAN
UG1 - UNIVERSAL GARAGE DOOR OPENER U2K - XM SATELLITE RADIO-100 CHANNELS OF GO ANYWHERE ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL
U30 - INSTRUMENT CLUSTER,TACH,CLOCK U57 - 8 SPEAKER SYSTEM
VM3 - LABEL-FRT & RR 5 MPH BUMPER V73 - VEHICLE STATEMENT USA/CANADA
1SA - CTS STANDARD PACKAGE 1SZ - PREFERRED EQUIPMENT SAVINGS
19I - EBONY INTERIOR TRIM 193 - EBONY
41U - BLACK RAVEN 6MH - COMP FRT LH COMPUTER SEL SUSP
7MH - COMP FRT RH COMPUTER SEL SUSP 8GW - SUSPENSION
9GW - SUSPENSION
