Originally Posted by Yeqon Hey guys,
I am battling paypal as we speak to get my account figured out. I do love the forum you have been beyond helpful! Any way you could check out vin #1G6DN56S450104736. Look forward to joining soon and again thanks for all the help and support with the new car. |
GM Vehicle Inquiry System
Summary
VIN : 1G6DN56S450104736
VEHICLE INFORMATION
Merchandising Model : 6DN69 -2005 CTS-V Warranty Start Date : 07/10/2004
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : TOWNE CADILLAC, INC.
2214 KENNEDY BLVD
UNION CITY , NJ 07087-2195
(201) 866-3300
Selling Source : 12 - CADILLAC
Site Code : 23149
Business Associate Code : 119099
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04068 FUEL FEED JUMPER PIPE ASSEMBLY - REPLACE N/A Closed
YT 05544 ON-BOARD DIAGNOSTICS SYSTEM SOFTWARE UPGRADE (REPROGRAM PCM) N/A Closed
SERVICE INFORMATIONAL ITEMS
SB 06047 DETERMINE IF ONSTAR CAN BE UPGRADED AT GM GLOBALCONNECT-SEE TSB 05-08-46-006 02/21/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID 1KQE500Z XM Status Active Refer to Help page for details or:
www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 07/10/2004 10 miles 07/10/2008 50010 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/10/2004 10 miles 07/10/2010 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/10/2004 10 miles 07/10/2012 80010 miles
48/50000 FEDERAL EMISSION 07/10/2004 10 miles 07/10/2008 50010 miles
72/100000 LUXURY CERTIFIED PRE-OWNED LIMITED WARRANTY 07/10/2004 10 miles 07/10/2010 100010 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/18/2009 544027 # C8870 - INFLATABLE RESTRAINT PASSENGER SEAT SUPPRESSION MODULE REP 18053 miles
06/18/2009 544027 # D3041 - SEALS, REFRIGERANT O-RING - CONDENSER - REPLACE 18053 miles
06/18/2009 544027 # E2327 - FRONT WHEEL BEARING AND HUB REPLACEMENT - BOTH SIDES 18053 miles
06/18/2009 544027 # J1507 - MOUNT, ENGINE - FRONT - BOTH - REPLACE 18053 miles
06/18/2009 544027 # E8041 - TIE ROD, INNER - LEFT - REPLACE 18053 miles
06/18/2009 544027 # J3100 - RADIATOR REPLACEMENT 18053 miles
06/18/2009 544027 # K0610 - CYLINDER, CONCENTRIC SLAVE - REPLACE 18053 miles
06/18/2009 544027 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 18053 miles
06/18/2009 544027 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 18053 miles
03/13/2008 524528 # J9991 - CUSTOMER CONCERN NOT DUPLICATED - ENGINE MECHANICAL 15006 miles
03/13/2008 524528 # F1617 - SEAL, AXLE SHAFT OIL - REAR AXLE - BOTH - REPLACE 15006 miles
03/13/2008 524528 # E0722 - TIRE PRESSURE INDICATOR SENSOR REPLACEMENT 15006 miles
03/13/2008 524528 # H0137 - REAR BRAKE ROTOR REPLACEMENT - BOTH SIDES 15006 miles
03/13/2008 524528 # Z7901 - 1-DAY COURTESY TRANSPORTATION 15006 miles
03/29/2007 508329 # N6612 - EXTERIOR LIGHTING WIRING AND/OR CONNECTOR REPAIR OR REPLAC 8571 miles
01/22/2007 844797 # N0110 - BATTERY REPLACEMENT 6754 miles
03/27/2006 788893 # J3100 - RADIATOR REPLACEMENT 3808 miles
03/27/2006 788893 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 3808 miles
03/27/2006 788893 # R0760 - RADIO, REMOVE AND REPLACE 3808 miles
03/27/2006 788893 # C3540 - REAR SIDE DOOR TRIM PANEL REPLACEMENT - RIGHT SIDE 3808 miles
03/27/2006 788893 # C3541 - REAR SIDE DOOR TRIM PANEL REPLACEMENT - LEFT SIDE 3808 miles
03/27/2006 788893 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 3808 miles
03/27/2006 788893 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 3808 miles
03/27/2006 788893 # E5057 - SEAT, MOUNT AND/OR INSULATOR, REAR SPRING (UPPER AND/OR LO 3808 miles
03/27/2006 788893 # F1280 - PROPELLER SHAFT ASSEMBLY - R&R OR REPLACE 3808 miles
09/22/2004 030731 # N0110 - BATTERY REPLACEMENT 2040 miles
09/22/2004 030731 # N2154 - SWITCH - DOOR WINDOW - RIGHT REAR - REPLACE 2040 miles
09/22/2004 030731 # J3100 - RADIATOR REPLACEMENT 2040 miles
09/22/2004 030731 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 2040 miles
08/27/2004 410657 # T2020 - TOWING 2040 miles
08/10/2004 377020 # Z8016 - ROADSIDE GONE ON ARRIVAL 1000 miles
06/02/2004 A04736 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Claim History
CLAIM HISTORY
Repair Order Date : 06/18/2009 Repair Order Number : 544027 Odometer Reading : 18053 miles
Serviced By : MORRIE S CADILLAC -SAAB
7400 WAYZATA BLVD
MINNEAPOLIS, MN 55426-1620
(763) 544-3501 Selling Source : 12 - CADILLAC
Site Code : 37186
Business Associate Code : 226476
Cycle Date Cycle Nbr Case Type Labor Operation Part Auth Code Person Code Line Total Comments
07/31/2009 27 01 # D3041 - SEALS, REFRIGERANT O-RING - CONDENSER - REPLACE 89023442 - PLUG N/A N/A $ 140.96 Y
07/24/2009 25 01 # C8870 - INFLATABLE RESTRAINT PASSENGER SEAT SUPPRESSION MODULE REP 19124390 - MODULE KI N/A N/A $ 449.77 Y
07/24/2009 25 02 # E2327 - FRONT WHEEL BEARING AND HUB REPLACEMENT - BOTH SIDES 12413103 - HUB N/A N/A $ 759.84 Y
07/24/2009 25 03 # J1507 - MOUNT, ENGINE - FRONT - BOTH - REPLACE 25759899 - MOUNT N/A N/A $ 515.69 N
07/24/2009 25 04 # E8041 - TIE ROD, INNER - LEFT - REPLACE 89060189 - ROD KIT N/A N/A $ 253.90 Y
07/24/2009 25 05 # J3100 - RADIATOR REPLACEMENT 19129908 - RADIATOR N/A N/A $ 511.53 Y
07/24/2009 25 06 # K0610 - CYLINDER, CONCENTRIC SLAVE - REPLACE 12587376 - CYLINDER N/A N/A $ 564.83 Y
07/24/2009 25 08 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 10358090 - CONVERTER N/A N/A $ 600.38 Y
07/24/2009 25 09 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 12587376 - CYLINDER N/A N/A $ 64.28 N
Repair Order Date : 03/13/2008 Repair Order Number : 524528 Odometer Reading : 15006 miles
7400 WAYZATA BLVD
Site Code : 37186
04/15/2008 891 01 # J9991 - CUSTOMER CONCERN NOT DUPLICATED - ENGINE MECHANICAL N/A N/A N/A $ 28.78 Y
04/15/2008 891 02 # F1617 - SEAL, AXLE SHAFT OIL - REAR AXLE - BOTH - REPLACE 88996591 - SEAL N/A N/A $ 393.01 Y
04/15/2008 891 03 # E0722 - TIRE PRESSURE INDICATOR SENSOR REPLACEMENT 25774006 - SENSOR N/A N/A $ 131.36 Y
04/15/2008 891 04 # H0137 - REAR BRAKE ROTOR REPLACEMENT - BOTH SIDES N/A N/A N/A $ 143.91 Y
04/15/2008 891 05 # Z7901 - 1-DAY COURTESY TRANSPORTATION N/A N/A N/A $ 45.00 N
Repair Order Date : 03/29/2007 Repair Order Number : 508329 Odometer Reading : 8571 miles
7400 WAYZATA BLVD
Site Code : 37186
04/24/2007 789 01 # N6612 - EXTERIOR LIGHTING WIRING AND/OR CONNECTOR REPAIR OR REPLAC N/A N/A N/A $ 46.54 Y
Repair Order Date : 01/22/2007 Repair Order Number : 844797 Odometer Reading : 6754 miles
Serviced By : GATEWAY CHEVROLET
PO BOX 2867
FARGO, ND 58108-2867
(701) 282-5522 Selling Source : 12 - CADILLAC
Site Code : 37182
Business Associate Code : 173280
01/26/2007 764 01 # N0110 - BATTERY REPLACEMENT 88901964 - BATTERY N/A N/A $ 167.41 N
Repair Order Date : 03/27/2006 Repair Order Number : 788893 Odometer Reading : 3808 miles
PO BOX 2867
Site Code : 37182
04/07/2006 680 01 # J3100 - RADIATOR REPLACEMENT 19129908 - RADIATOR N/A N/A $ 471.11 N
04/07/2006 680 02 # R0760 - RADIO, REMOVE AND REPLACE N/A N/A N/A $ 85.23 N
04/07/2006 680 03 # C3540 - REAR SIDE DOOR TRIM PANEL REPLACEMENT - RIGHT SIDE 15280045 - PANEL N/A N/A $ 132.55 N
04/07/2006 680 04 # C3541 - REAR SIDE DOOR TRIM PANEL REPLACEMENT - LEFT SIDE 15280046 - PANEL N/A N/A $ 132.55 N
04/07/2006 680 05 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 12581554 - PIPE N/A N/A $ 81.04 N
04/07/2006 680 06 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P N/A N/A N/A $ 28.99 N
04/07/2006 680 07 # E5057 - SEAT, MOUNT AND/OR INSULATOR, REAR SPRING (UPPER AND/OR LO 19133557 - SUSPENSIO N/A N/A $ 211.26 N
04/07/2006 680 08 # F1280 - PROPELLER SHAFT ASSEMBLY - R&R OR REPLACE N/A N/A N/A $ 36.24 N
Serviced By : SPECMO ENTERPRISES
1200 E. AVIS
MADISON HEIGHTS, MI 48071-1507
Selling Source : 45 - A/C DELCO
Site Code : 44835
Business Associate Code : 192110
04/07/2006 680 01 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 89047318 N/A N/A $ 759.63 Y
Repair Order Date : 09/22/2004 Repair Order Number : 030731 Odometer Reading : 2040 miles
Serviced By : TOWNE CADILLAC, INC.
2214 KENNEDY BLVD
UNION CITY, NJ 07087-2195
(201) 866-3300 Selling Source : 12 - CADILLAC
Site Code : 23149
10/01/2004 522 01 # N0110 - BATTERY REPLACEMENT 88901964 - BATTERY N/A N/A $ 147.60 N
10/01/2004 522 02 # N2154 - SWITCH - DOOR WINDOW - RIGHT REAR - REPLACE 25750264 - SWITCH N/A N/A $ 47.96 N
10/01/2004 522 03 # J3100 - RADIATOR REPLACEMENT 89022478 - RADIATOR N/A N/A $ 518.84 N
10/01/2004 522 04 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT N/A N/A N/A $ 32.72 N
Repair Order Date : 08/27/2004 Repair Order Number : 410657 Odometer Reading : 2040 miles
Serviced By : GM ROADSIDE ASSISTANCE
PO BOX 5033
TROY, MI 48007-5033
Site Code : 10827
Business Associate Code : 160087
09/03/2004 514 01 # T2020 - TOWING N/A C N/A $ 99.41 N
Repair Order Date : 08/10/2004 Repair Order Number : 377020 Odometer Reading : 1000 miles
PO BOX 5033
TROY, MI 48007-5033
Site Code : 10827
08/20/2004 510 01 # Z8016 - ROADSIDE GONE ON ARRIVAL N/A CA N/A $ 25.68 N
Repair Order Date : 06/02/2004 Repair Order Number : A04736 Odometer Reading : 0 miles
2214 KENNEDY BLVD
Site Code : 23149
06/08/2004 489 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N/A N/A $ 116.32 N
CHECK HISTORY
Vehicle Has No Associated Check History.
? 2009 General Motors. All Rights Reserved.
Vehicle Build
VIN 1G6DN56S450104736
VEHICLE BUILD
Gross Vehicle Weight Rating : 2182 kg (4811 lb) Order Number : HGGTZQ
Build Date : 06/02/2004 Build Plant : 150D
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AH8 - 10-WAY PWR. PASS. SEAT W/ PWR. LUMBAR AL2 - POWER LUMBAR CONTROL
AM9 - SPLIT-FOLDING REAR SEAT AQ9 - SEAT FRT BKT, LUXURY
AY0 - INFLATABLE RESTRAINT DRI & PASS A45 - MEMORY SEAT ADJUSTER
CE4 - WASHER HEADLAMP, HIGH PRESSURE CF5 - EXPRESS OPEN SUNROOF
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP DD8 - MIRROR AUTO DAY/NIGHT I/S R/V
DL5 - DECAL - ROADSIDE SERVICE INFO DR5 - MIRROR O/S REMOTE L/H R/H
E2C - RAPID DELIVERY SYSTEM FE4 - SUSPENSION
FE9 - 50-STATE EMISSIONS GT4 - AXLE REAR 3.73 RATIO
IL3 - TRIM INTERIOR DESIGN JJA - PT DRESS SUBASSEMBLY INSTALLED
J56 - BRAKES, ANTILOCK KA1 - HEATED FRONT SEATS
KG4 - 150 AMP GENERATOR LS6 - LS6 5.7L V8 ENGINE
M12 - TREMEC 6-SPEED MANUAL TRANS NT9 - EMISSION - FEDERAL
N34 - STEERING WHEEL, LEATHER P32 - WHEEL 18" ALUMINUM
QKR - P245/45R18 W RATED R6M - NEW JERSEY COST SURCHARGE
R8E - GAS GUZZLER TAX SLL - SOLD ORDERS
UAV - DVD NAVIGATION SYSTEM INCL: XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INC (DELETES COMPASS IN MIRROR) UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1YR SAFE & SOUND PLAN
U2K - XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL U30 - INSTRUMENT CLUSTER,TACH,CLOCK
U57 - 8 SPEAKER SYSTEM VM3 - LABEL-FRT & RR 5 MPH BUMPER
V73 - VEHICLE STATEMENT USA/CANADA 1SA - CTS-V STANDARD PACKAGE
1SZ - PREFERRED EQUIPMENT SAVINGS 19I - EBONY INTERIOR TRIM
193 - EBONY 41U - BLACK RAVEN
6MH - COMP FRT LH COMPUTER SEL SUSP 7MH - COMP FRT RH COMPUTER SEL SUSP
8GW - SUSPENSION 9GW - SUSPENSION
