Originally Posted by steve230323 Please disregard the last post. That car was sold this morning.
Could you please check # 1G6DC67A060108821 and 1G6DX67D360200049.
Sorry about all of the requests.......I am trying to become a member of the OWNERS Club.
Thanks,
Steve |
1G6DC67A060108821
2006 STS V8 LUXURY SPORTS SEDAN APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 08/11/2005 0 miles 08/11/2009 50000 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 08/11/2005 0 miles 08/11/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/11/2005 0 miles 08/11/2013 80000 miles
48/50000 FEDERAL EMISSION 08/11/2005 0 miles 08/11/2009 50000 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
11/08/2008 Y86041 # Z2085 - ROADSIDE SERVICE (PREMIUM) 5045 miles
11/08/2008 088979 # N0110 - BATTERY REPLACEMENT 61671 miles
11/08/2008 088979 # Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 61671 miles
05/20/2008 135522 # V1777 - 07204 - REPLACE REAR DIFFERENTIAL SEAL ONLY 54006 miles
05/20/2008 135522 # Y0075 - 06516 SYSTEM SOFTWARE UPGRADE - REPROGRAM ENGINE CONTROL M 54006 miles
11/12/2007 Q87706 # Z2080 - ROADSIDE SERVICE (TOWING) 40000 miles
09/12/2007 130812 # C1101 - WEATHERSTRIP - BODY LOCK PILLAR - LEFT - ALIGN OR REPLACE 40875 miles
09/12/2007 130812 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 40875 miles
09/12/2007 130812 # Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 40875 miles
08/30/2007 130605 # C6555 - PANEL, FRONT SEAT CUSHION OUTER FINISH - LEFT - REPLACE 39929 miles
08/30/2007 130605 # C6554 - PANEL, FRONT SEAT CUSHION OUTER FINISH - RIGHT - REPLACE 39929 miles
08/30/2007 130605 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 39929 miles
08/30/2007 130605 # C6566 - CAP, FRONT SEAT ADJUSTER END - ONE OR ALL - LEFT - REPLACE 39929 miles
06/20/2007 129408 # J5490 - THROTTLE BODY ASSEMBLY REPLACEMENT 36180 miles
06/20/2007 129408 # Z7902 - 2-DAY COURTESY TRANSPORTATION 36180 miles
06/20/2007 129408 # N0680 - PARKING AND TURN SIGNAL LAMP BULB REPLACEMENT 36180 miles
06/20/2007 129408 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 36180 miles
06/08/2007 060467 # N6612 - EXTERIOR LIGHTING WIRING AND/OR CONNECTOR REPAIR OR REPLAC 35635 miles
06/08/2007 060467 # Z7901 - 1-DAY COURTESY TRANSPORTATION 35635 miles
06/07/2007 060378 # N0110 - BATTERY REPLACEMENT 35583 miles
06/07/2007 060378 # Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 35583 miles
06/06/2007 M88066 # Z2085 - ROADSIDE SERVICE (PREMIUM) 35000 miles
01/09/2007 126121 # E8622 - HOSES, POWER STEERING HYDRAULIC - PRESSURE - REPLACE 27478 miles
01/09/2007 126121 # E7020 - STEERING WHEEL REPLACEMENT 27478 miles
01/09/2007 126121 # C6625 - LUMBAR ASSEMBLY, FRONT SEAT BACK - LEFT - REPLACE 27478 miles
01/09/2007 126121 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 27478 miles
01/09/2007 126121 # Z7904 - 4-DAY COURTESY TRANSPORTATION 27478 miles
10/18/2006 124373 # R5650 - RECEIVER, DIGITAL SATELLITE RADIO - RETURN TO ACDELCO ESC 22283 miles
10/17/2006 124373 # R5600 - DIGITAL RADIO RECEIVER REPLACEMENT 22283 miles
10/17/2006 124373 # Z7901 - 1-DAY COURTESY TRANSPORTATION 22283 miles
09/13/2006 123582 # E8622 - HOSES, POWER STEERING HYDRAULIC - PRESSURE - REPLACE 20239 miles
09/13/2006 123582 # Z7902 - 2-DAY COURTESY TRANSPORTATION 20239 miles
05/25/2006 121470 # Z7091 - NON-WARRANTY INCREMENTAL EXPENSE/WHOLESALE 15609 miles
05/25/2006 121470 # E9100 - RESERVOIR ASSEMBLY, POWER STEERING FLUID (REMOTE) - REPLAC 15609 miles
05/25/2006 121470 # C6554 - PANEL, FRONT SEAT CUSHION OUTER FINISH - RIGHT - REPLACE 15609 miles
05/25/2006 121470 # Z7901 - 1-DAY COURTESY TRANSPORTATION 15609 miles
12/13/2005 044667 # N0110 - BATTERY REPLACEMENT 7980 miles
12/13/2005 044667 # Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 7980 miles
12/07/2005 117774 # E9740 - STEERING GEAR REPLACEMENT 7263 miles
07/21/2005 A08821 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
1SG - 1SG PREMIUM LUXURY PERFORMANCE PACKAGE: *PREMIUM TUSCANY LEATHER SEATS *MULTI-DRIVER MEMORY SETTINGS *POWER ADJUSTABLE LUMBAR *HEATED/VENTILATED FRONT SEATS *HEATED REAR OUTBOARD SEATS *HEATED, WOOD STEERING WHEEL *EUCALYPTUS WOOD TRIM ON CENTER STACK, CONSOLE, IP, SHIFT KNOB, DOOR TRIM AND STRG WHEEL *BOSE 5.1 STUDIO SURROUND SOUND WITH IN-DASH 6 DISC DVD CHANGER AND ADVANCED DVD NAVIGATION, INCLUDES TWO FREE MAP UPDATES (REPLACES STD/OPT RADIO) (REPLACES COMPASS IN MIRROR) *RAINSENSE WIPERS *UNIVERSAL HOME REMOTE *AUTO DIMMING ISRV MIRROR (REPLACES STD ISRV MIRROR) *HIGH INTENSITY DISCHARGE (HID) HEADLAMPS *INTELLIBEAM AUTO HIGH BEAM CONTROL *HEADLAMP WASHERS *18" POLISHED ALUMINUM WHEELS *MICHELIN P235/50R18 FRONT P255/45R18 REAR W-RATED TIRES *TIRE PRESSURE MONITOR *MAGNETIC RIDE CONTROL *EXPRESS OPEN/CLOSE SUNROOF *REAR SPOILER *TRUNK CONVENIENCE NET *AUTO AIR QUALITY SENSOR PERFORMANCE FEATURES: *LIMITED SLIP DIFFERENTIAL (N/A WITH ALL WHEEL DRIVE) *4-WHL. PERFORMANCE DISC BRAKES WITH ABS *PERFORMANCE COOLING PACKAGE *PREMIUM ZF STEERING GEAR
1SZ - PREFERRED EQUIPMENT SA
A45 - MULTI-DRIVER MEMORY SETTINGS
AL2 - POWER LUMBAR CONTROL
AP9 - TRUNK CONVENIENCE NET
AQ9 - SEAT FRT BKT, LUXURY
AY0 - INFLATABLE RESTRAINT DRI & PASS
B20 - EUCALYPTUS WOOD TRIM ON CENTER STACK, CONSOLE,IP, SHIFT KNOB, DOOR TRIM AND STRG WHEEL
CE1 - RAINSENSE WIPERS
CE4 - HEADLAMP WASHERS
CF5 - EXPRESS OPEN/CLOSE SUNROOF
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP
DD8 - AUTO DIMMING ISRV MIRROR
DL5 - DECAL - ROADSIDE SERVICE INFO
DR2 - O/S REARVIEW PWR, HEATED MIRRS
F55 - CVRTD MAGNETO RHEOLOGICAL
FE3 - MAGNETIC RIDE CONTROL
FE9 - 50-STATE EMISSIONS
G80 - LIMITED SLIP DIFFERENTIAL
GU6 - AXLE REAR, 3.42 RATIO
IL3 - PREMIUM TUSCANY LEATHER SEATS
JE5 - 17" PERFORMANCE BRAKES
JJA - PT DRESS SUBASSEMBLY INSTALLED
K14 - FILTER, AIR, AUTO RECIRCULATING
KA6 - HEATED SEATS, REAR
KB6 - HEATED/VENTILATED FRONT SEATS
KG4 - 150 AMP GENERATOR
LH2 - 4.6L NORTHSTAR V8 VVT 320 HP
M22 - 5-SPEED AUTO W/DRV SHIFT CONTRL
MX0 - MERCH 5-SPEED AUTO TRANSMISSION
N31 - HEATED, WOOD STEERING WHEEL
N87 - 18" POLISHED ALUMINUM WHEELS
NT9 - EMISSION - FEDERAL
NV7 - PREMIUM ZF STEERING GEAR
Q12 - MICHELIN P235/50R18 FRONT P255/45R18 REAR W-RATED TIRES
R6P - PREMIUM PAINT
R9N - LEATHER
SLM - STOCK ORDERS
T43 - REAR SPOILER
TQ5 - INTELLIBEAM AUTO HIGH BEAM CONTROL
TT6 - HIGH INTENSITY DISCHARGE (HID) HEADLAMPS
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
U30 - INSTRUMENT CLUSTER,TACH,CLOCK
UA6 - THEFT-DETERRENT ALARM SYSTEM
UE1 - ONSTAR SYSTEM INCLUDES 1 YR DIRECTIONS & CONNECTIONS
UG1 - UNIVERSAL HOME REMOTE
UJ6 - TIRE PRESSURE MONITOR
UY5 - 15 SPEAKER SYSTEM
V03 - PERFORMANCE COOLING PACKAGE
V4X - STS CONVERSION V8
V73 - VEHICLE STATEMENT USA/CANADA
YQ4 - BOSE 5.1 STUDIO SURROUND SOUND WITH IN-DASH 6 DISC DVD CHANGER AND ADVANCED DVD NAVIGATION, INCLUDES TWO FREE MAP UPDATES
1G6DX67D360200049
2006 STS-V APPLICABLE WARRANTIES
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 07/21/2006 39 miles 07/21/2010 50039 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/21/2006 39 miles 07/21/2012 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/21/2006 39 miles 07/21/2014 80039 miles
48/50000 FEDERAL EMISSION 07/21/2006 39 miles 07/21/2010 50039 miles
CLAIM HISTORY
01/12/2009 082419 # R0942 - RADIO FRONT SIDE DOOR SPEAKER REPLACEMENT - RIGHT SIDE 45230 miles
12/03/2008 398153 # J9995 - CUSTOMER CONCERN NOT DUPLICATED - EMISSIONS 45145 miles
12/03/2008 398153 # K9995 - CUSTOMER CONCERN NOT DUPLICATED - AUTOMATIC TRANSMISSION 45145 miles
12/03/2008 398153 # N9995 - CUSTOMER CONCERN NOT DUPLICATED - ELECTRICAL 45145 miles
10/13/2008 394878 # K9995 - CUSTOMER CONCERN NOT DUPLICATED - AUTOMATIC TRANSMISSION 43789 miles
10/13/2008 394878 # Z7903 - 3-DAY COURTESY TRANSPORTATION 43789 miles
10/13/2008 394878 # J0250 - MANIFOLD, INTAKE - REPLACE 43789 miles
08/18/2008 391515 # J0103 - EXHAUST MANIFOLD WITH CATALYTIC CONVERTER REPLACEMENT - LE 43369 miles
08/18/2008 391515 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 43369 miles
08/18/2008 391515 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 43369 miles
08/18/2008 391515 # N0110 - BATTERY REPLACEMENT 43369 miles
08/18/2008 391515 # K7580 - CLUTCH, LOW AND REVERSE - REPLACE 43369 miles
08/18/2008 391515 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 43369 miles
08/18/2008 391515 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 43369 miles
08/07/2008 390937 # J3401 - MOTOR AND/OR BLADE, ELECTRIC COOLING FAN - LEFT - REPLACE 43178 miles
08/07/2008 390937 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 43178 miles
08/07/2008 390937 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 43178 miles
08/07/2008 390937 # N1720 - FUSE REPLACEMENT 43178 miles
03/17/2008 381436 # J0667 - DRIVE BELT REPLACEMENT - ACCESSORY 38371 miles
02/25/2008 379891 # J0102 - EXHAUST MANIFOLD WITH CATALYTIC CONVERTER REPLACEMENT - RI 38161 miles
02/25/2008 379891 # K5364 - TRANSMISSION CONTROL MODULE REPROGRAMMING WITH SPS 38161 miles
02/25/2008 379891 # V1777 - 07204 - REPLACE REAR DIFFERENTIAL SEAL ONLY 38161 miles
02/25/2008 379891 # J0103 - EXHAUST MANIFOLD WITH CATALYTIC CONVERTER REPLACEMENT - LE 38161 miles
02/25/2008 379891 # R0942 - RADIO FRONT SIDE DOOR SPEAKER REPLACEMENT - RIGHT SIDE 38161 miles
02/25/2008 379891 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 38161 miles
02/25/2008 379891 # J3480 - WATER PUMP REPLACEMENT 38161 miles
12/10/2007 374722 # J9995 - CUSTOMER CONCERN NOT DUPLICATED - EMISSIONS 36406 miles
12/10/2007 374722 # K6350 - SWITCH, AUTOMATIC TRANSMISSION MANUAL SHIFT SHAFT POSITION 36406 miles
12/10/2007 374722 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 36406 miles
12/09/2007 R58468 # Z2085 - ROADSIDE SERVICE (PREMIUM) 40000 miles
12/09/2007 R58469 # Z2080 - ROADSIDE SERVICE (TOWING) 40000 miles
10/30/2007 027916 # Z7902 - 2-DAY COURTESY TRANSPORTATION 33765 miles
08/30/2007 367407 # E4301 - BEARING AND HUB ASSEMBLY, REAR WHEEL - LEFT - REPLACE 28631 miles
08/30/2007 367407 # Z7903 - 3-DAY COURTESY TRANSPORTATION 28631 miles
04/02/2007 356031 # N9995 - CUSTOMER CONCERN NOT DUPLICATED - ELECTRICAL 16254 miles
04/02/2007 356031 # Z7902 - 2-DAY COURTESY TRANSPORTATION 16254 miles
01/11/2007 349936 # E8625 - HOSES, POWER STEERING HYDRAULIC - RETURN, GEAR TO COOLING 10862 miles
01/11/2007 349936 # Z7903 - 3-DAY COURTESY TRANSPORTATION 10862 miles
01/09/2007 349818 # E9740 - STEERING GEAR REPLACEMENT 10810 miles
01/09/2007 349818 # Z7901 - 1-DAY COURTESY TRANSPORTATION 10810 miles
11/06/2006 345235 # N0110 - BATTERY REPLACEMENT 7438 miles
11/06/2006 345235 # Z7902 - 2-DAY COURTESY TRANSPORTATION 7438 miles
11/06/2006 345235 # C2326 - INSTRUMENT PANEL CENTER TRIM PLATE REPLACEMENT 7438 miles
11/06/2006 345235 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 7438 miles
10/23/2006 H26273 # Z2083 - ROADSIDE SERVICE (BATTERY/JUMP START) 5000 miles
04/14/2006 330855 I Z6999 - PDI RELATED FLUID ADDS 10 miles
04/14/2006 330855 # B1790 - WINDSHIELD WASHER NOZZLE HOSE REPLACEMENT 10 miles
03/28/2006 A00049 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
194 - EBONY
19I - EBONY INTERIOR TRIM
1SA - STS-V EQUIPMENT: * 4.4L NORTHSTAR V8 SUPERCHARGED ENGINE WITH 469 HP/439 LB-FT TORQUE * 6-SPD AUTO W/DRVR SHIFT CNTL * PERFORMANCE TUNED SUSPENSION * PERFORMANCE BREMBO BRAKES * 18" FRT & 19" RR ALUM WHLS * P255/45R18 FRT, P275/40R19 RR EMT PIRELLI TIRES * REAR V-SERIES SPOILER * LEATHER WRAPPED INTERIOR, INCL. DOOR TRIM, CONSOLE, IP
1SZ - PREFERRED EQUIPMENT SAVINGS
41U - BLACK RAVEN
6LL - COMPONENT FRT LH COMPUTER SEL
7LL - SUSPENSION
8ZM - SUSPENSION
9ZM - SUSPENSION
CF5 - EXPRESS OPEN SUNROOF
FE4 - SUSPENSION
GU5 - AXLE REAR, 3.23 RATIO
IL4 - TRIM INTERIOR DESIGN
J56 - PERFORMANCE BREMBO BRAKES
LC3 - 4.4L NORTHSTAR V8 SUPERCHARGED ENGINE WITH 469 HP/439 LB-FT TORQUE
MYC - 6-SPD AUTO W/DRVR SHIFT CNTL
NR7 - HEATED LEATHER STEERING WHEEL
Q19 - P25545R18 FRT, P27540R19 REAR
Q20 - 10-SPOKE WHEELS
R6P - PREMIUM PAINT
R8E - GAS GUZZLER TAX
R8K - *******************************
R9N - LEATHER.
ROO - ORDER FULFILLMENT TRACKING
SLM - STOCK ORDERS
