Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: VIN checks here...READ POST #1 BEFORE ASKING
  #1786 (permalink)
Old 02-09-09, 05:48 AM
mrchris1979's Avatar
Cadillac(s): None
View mrchris1979's Photo Album
Casino Cash: $1530
Re: VIN checks here...READ FIRST POST
Thank You so much. VIN: 1G6DN57S040191712. Planning to buy this vehicle this week. Really appreciate the info.
  #1787 (permalink)
Old 02-09-09, 10:23 AM
lusterblade's Avatar
Cadillac Owners Enthusiast
View lusterblade's Photo Album
Casino Cash: $6900
Re: History please!
Originally Posted by ToyCTSV View Post
1G6DN57S840161986
I would appreciate it if you could run the service history for me. Now that I've had everything under the sun replaced over the past year I'm out of warranty and my radiator just blew up. Must be karma?
Thanks in advance,
Joe
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
12/12000 BUYBACK LIMITED WARRANTY 01/22/2008 44352 miles 01/22/2009 56352 miles
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 03/05/2004 12 miles 03/05/2008 50012 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/05/2004 12 miles 03/05/2010 100012 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/05/2004 12 miles 03/05/2012 80012 miles
48/50000 CALIFORNIA EMISSIONS 03/05/2004 12 miles 03/05/2008 50012 miles
84/70000 CALIFORNIA SELECT COMPONENT 03/05/2004 12 miles 03/05/2011 70012 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/05/2009 440468 # K2720 - TRANSMISSION REPLACEMENT 56239 miles
01/05/2009 440468 # J1507 - MOUNT, ENGINE - FRONT - BOTH - REPLACE 56239 miles
01/05/2009 440468 # H9711 - FRAME, REAR SUPPLEMENTAL BUSHINGS - INSTALL 56239 miles
01/05/2009 440468 # K2283 - MOUNT, TRANSMISSION - REAR - REPLACE 56239 miles
10/02/2008 434879 # B5500 - LOCK, REAR COMPARTMENT LID - R&R OR REPLACE 53248 miles
10/02/2008 434879 # J1507 - MOUNT, ENGINE - FRONT - BOTH - REPLACE 53248 miles
10/02/2008 434879 # C1280 - WEATHERSTRIP - REAR COMPARTMENT OPENING - ALIGN OR REPLACE 53248 miles
10/02/2008 434879 # B9650 - HIGH MOUNT STOP LAMP REPLACEMENT 53248 miles
10/02/2008 434879 # B8676 - APPLIQUE, TAIL LAMP - CENTER - REPLACE 53248 miles
04/04/2008 423765 # J3480 - WATER PUMP REPLACEMENT 46215 miles
04/04/2008 423765 # N0100 - BATTERY - CHARGE AND TEST 46215 miles
04/04/2008 423765 # E9050 - POWER STEERING PUMP REPLACEMENT 46215 miles
04/04/2008 423765 # H9711 - FRAME, REAR SUPPLEMENTAL BUSHINGS - INSTALL 46215 miles
04/04/2008 423765 # R0762 - RECEIVER, RADIO - ORDER OR REMOVE 46215 miles
04/04/2008 423765 # E8360 - POWER STEERING PUMP PULLEY REPLACEMENT 46215 miles
04/04/2008 423765 # H2800 - PARKING BRAKE ADJUSTMENT 46215 miles
04/04/2008 423765 # E3917 - SHIELD AND/OR BUMPER, FRONT STRUT - BOTH - REPLACE 46215 miles
04/04/2008 423765 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 46215 miles
03/04/2008 421706 # E0722 - TIRE PRESSURE INDICATOR SENSOR REPLACEMENT 45710 miles
03/04/2008 421706 # B7289 - HEADLAMP/COMPOSITE ASSEMBLY - LEFT - REPLACE 45710 miles
03/04/2008 421706 # B7288 - HEADLAMP/COMPOSITE ASSEMBLY - RIGHT - REPLACE 45710 miles
02/20/2008 421019 # A2730 - REAR COMPARTMENT LID REFINISH/CLEAR COAT 45023 miles
02/20/2008 421019 # B5410 - BODY - RESEAL 45023 miles
02/06/2008 420147 # F1280 - PROPELLER SHAFT ASSEMBLY - R&R OR REPLACE 45023 miles
02/06/2008 420147 # B7540 - MOLDING, WINDSHIELD REVEAL - R&R OR REPLACE 45023 miles
02/06/2008 420147 # J3362 - HOSE, ENGINE COOLANT - UPPER - REPLACE 45023 miles
02/06/2008 420147 # D2774 - HOSES, HEATER (WITH AIR CONDITIONING) - INLET - REPLACE 45023 miles
02/06/2008 420147 # E7690 - SENSOR, STEERING WHEEL ROTATION - REPLACE 45023 miles
02/06/2008 420147 # E8622 - HOSES, POWER STEERING HYDRAULIC - PRESSURE - REPLACE 45023 miles
02/06/2008 420147 # N6602 - WIRING AND/OR CONNECTOR - CHARGING/STARTING/BATTERY - REPA 45023 miles
02/06/2008 420147 # Z7901 - 1-DAY COURTESY TRANSPORTATION 45023 miles
02/01/2008 419863 # B2720 - SUNROOF WINDOW HEIGHT AND OPENING FIT ADJUSTMENT 45004 miles
02/01/2008 419863 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 45004 miles
02/01/2008 419863 # B7352 - PANEL, AIR INLET GRILLE - LEFT - REPLACE 45004 miles
02/01/2008 419863 # R0760 - RADIO, REMOVE AND REPLACE 45004 miles
02/01/2008 419863 # B5410 - BODY - RESEAL 45004 miles
01/21/2008 125486 # B4181 - CYLINDER, FRONT DOOR LOCK - LEFT - R&R OR REPLACE 44361 miles
01/09/2008 125252 # C3241 - FRONT SIDE DOOR PULL HANDLE REPLACEMENT - LEFT SIDE 44216 miles
11/20/2007 124274 # J3100 - RADIATOR REPLACEMENT 44215 miles
11/20/2007 124274 D J3100 - RADIATOR REPLACEMENT 44215 miles
10/10/2007 123440 # K0800 - DISC AND/OR CLUTCH COVER, CLUTCH - REPLACE 44212 miles
08/03/2007 280886 # F2154 - BUSHING, REAR DIFFERENTIAL CARRIER SUPPORT OR MOUNT - REPL 43195 miles
08/03/2007 280886 # E2020 - WHEEL ALIGNMENT MEASUREMENT 43195 miles
07/31/2007 113235 # Z7096 - BUYBACK DEALER ADMINISTRATIVE ALLOWANCE/LEGAL CASE 41619 miles
07/13/2007 278960 # N0680 - PARKING AND TURN SIGNAL LAMP BULB REPLACEMENT 41621 miles
06/06/2007 275559 # N0110 - BATTERY REPLACEMENT 40453 miles
06/06/2007 275559 # Z7901 - 1-DAY COURTESY TRANSPORTATION 40453 miles
08/30/2006 254048 # N0734 - FRONT SIDE MARKER LAMP BULB REPLACEMENT 30345 miles
08/30/2006 254048 # Z7903 - 3-DAY COURTESY TRANSPORTATION 30345 miles
07/05/2006 249840 # E9050 - POWER STEERING PUMP REPLACEMENT 27872 miles
04/26/2006 245095 # C2990 - KNOB, CONTROL AND/OR SELECT - ONE AND/OR ALL - REPLACE 24673 miles
04/26/2006 245095 # N1720 - FUSE - REPLACE 24673 miles
04/26/2006 245095 # N0760 - TAIL LAMP BULB REPLACEMENT 24673 miles
12/29/2005 236202 # C2990 - KNOB, CONTROL AND/OR SELECT - ONE AND/OR ALL - REPLACE 20050 miles
12/29/2005 236202 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 20050 miles
12/12/2005 234924 # N0110 - BATTERY REPLACEMENT 19277 miles
12/12/2005 234924 # K0610 - CYLINDER, CONCENTRIC SLAVE - REPLACE 19277 miles
12/12/2005 234924 # Z7904 - 4-DAY COURTESY TRANSPORTATION 19277 miles
10/28/2005 231540 # N0110 - BATTERY REPLACEMENT 17930 miles
10/10/2005 230023 # F3030 - BUSHING, REAR DIFFERENTIAL DAMPING - RIGHT - REPLACE 17531 miles
10/10/2005 230023 # Z7905 - 5-DAY COURTESY TRANSPORTATION 17531 miles
06/14/2005 221322 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 13485 miles
06/14/2005 221322 # V1302 - 05004 - REPLACE SDM 13485 miles
04/01/2005 215754 # E0431 - GOODYEAR/DUNLOP TIRE REPLACEMENT 10623 miles
04/01/2005 215754 # Z7901 - 1-DAY COURTESY TRANSPORTATION 10623 miles
02/28/2005 213001 # Z7903 - 3-DAY COURTESY TRANSPORTATION 9732 miles
02/28/2005 213001 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 9732 miles
10/26/2004 203080 # N0110 - BATTERY REPLACEMENT 5410 miles
08/10/2004 197340 # N4199 - INSTRUMENT CLUSTER REPROGRAMMING WITH SPS 1091 miles
08/10/2004 197340 # Z7901 - 1-DAY COURTESY TRANSPORTATION 1091 miles
03/04/2004 105817 # E2020 - WHEEL ALIGNMENT MEASUREMENT 8 miles
02/18/2004 A61986 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
  #1788 (permalink)
Old 02-09-09, 10:25 AM
Casino Cash: $6900
Originally Posted by LT4POWR View Post
I didn't see an edit option, so I'll edit it like this. I typed the VIN wrong, it's actually 1G6DN57S340184124. I just upgraded my mebership (via paypal) and I would really appreciate some speedy feedback on this car....I need to make a decision tomorrow! Thanks
Anybody know how long it takes for my "support member" tag to appear?
12/12000 BUYBACK LIMITED WARRANTY 09/01/2006 41145 miles 09/01/2007 53145 miles
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 06/29/2004 15 miles 06/29/2008 50015 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 06/29/2004 15 miles 06/29/2010 100015 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 06/29/2004 15 miles 06/29/2012 80015 miles
48/50000 FEDERAL EMISSION 06/29/2004 15 miles 06/29/2008 50015 miles
CLAIM HISTORY
08/13/2008 265174 0 J0690 - PULLEY, ACCESSORY DRIVE BELT IDLER - REPLACE 64108 miles
08/13/2008 265174 0 J3480 - WATER PUMP REPLACEMENT 64108 miles
08/13/2008 265174 0 C6041 - ADJUSTER ASSEMBLY, FRONT SEAT POWER - BUCKET SEAT - DRIVER 64108 miles
01/08/2008 260967 B F9706 - INSTALL REAR DIFFERENTIAL HOSE AND VENT (CADILLAC) 58695 miles
11/13/2007 260109 0 F1280 - PROPELLER SHAFT ASSEMBLY - R&R OR REPLACE 58390 miles
11/13/2007 260109 0 Z7902 - 2-DAY COURTESY TRANSPORTATION 58390 miles
10/30/2007 259852 0 F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 58389 miles
10/30/2007 259852 0 E0722 - TIRE PRESSURE INDICATOR SENSOR REPLACEMENT 58389 miles
03/23/2007 255860 # F2154 - BUSHING, REAR DIFFERENTIAL CARRIER SUPPORT OR MOUNT - REPL 48867 miles
03/16/2007 255860 # N9995 - CUSTOMER CONCERN NOT DUPLICATED - ELECTRICAL 48867 miles
03/16/2007 255860 # E5021 - SPRINGS, REAR COIL - LEFT - R&R OR REPLACE 48867 miles
11/28/2006 254014 # R9995 - CUSTOMER CONCERN NOT DUPLICATED - CELLULAR, ENTERTAINMENT, 44919 miles
04/21/2006 104484 # E2020 - WHEEL ALIGNMENT MEASUREMENT 39169 miles
04/21/2006 104484 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 39169 miles
04/21/2006 104484 # K9995 - CUSTOMER CONCERN NOT DUPLICATED - AUTOMATIC TRANSMISSION 39169 miles
04/21/2006 104484 # F9995 - CUSTOMER CONCERN NOT DUPLICATED - DRIVELINE/AXLE 39169 miles
04/21/2006 104484 # J9995 - CUSTOMER CONCERN NOT DUPLICATED 39169 miles
04/21/2006 104484 # N0110 - BATTERY REPLACEMENT 39169 miles
02/14/2006 B14286 # Z2080 - ROADSIDE SERVICE (TOWING) 44000 miles
02/14/2006 101410 # N6630 - WIRING AND/OR CONNECTOR - TRANSMISSION/TRANSFER CASE/TRANS 39159 miles
12/12/2005 098701 # T2020 - TOWING 35553 miles
12/12/2005 098701 # K0800 - DISC AND/OR CLUTCH COVER, CLUTCH - REPLACE 35553 miles
12/12/2005 098701 # K0600 - CYLINDER, ACTUATOR CLUTCH MASTER - R&R OR REPLACE 35553 miles
12/12/2005 098701 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 35553 miles
10/05/2005 095622 # J3100 - RADIATOR REPLACEMENT 32728 miles
10/05/2005 095622 # N2460 - SUNROOF SWITCH REPLACEMENT 32728 miles
10/05/2005 095622 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 32728 miles
07/15/2005 091995 # J1150 - BEARING, CRANKSHAFT MAIN - ONE BEARING - REPLACE 27469 miles
07/15/2005 091995 # N4833 - MODULE - EXPRESS SUNROOF - REPLACE 27469 miles
07/15/2005 091995 # J1501 - ENGINE FRONT MOUNT REPLACEMENT - LEFT SIDE 27469 miles
07/15/2005 091995 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 27469 miles
07/15/2005 184503 # Z2080 - ROADSIDE SERVICE (TOWING) 28000 miles
07/15/2005 184504 # Z2080 - ROADSIDE SERVICE (TOWING) 28000 miles
06/21/2005 090835 # F3030 - BUSHING, REAR DIFFERENTIAL DAMPING - RIGHT - REPLACE 25607 miles
06/21/2005 090835 # B9640 - LAMP ASSEMBLY, EXTERIOR - STOP, TAIL AND TURN SIGNAL - RIG 25607 miles
06/21/2005 090835 # Z7904 - 4-DAY COURTESY TRANSPORTATION 25607 miles
06/21/2005 090835 # B7540 - MOLDING, WINDSHIELD REVEAL - R&R OR REPLACE 25607 miles
06/21/2005 090835 # V1302 - 05004 - REPLACE SDM 25607 miles
05/20/2005 089246 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 23034 miles
05/20/2005 089246 # Z7902 - 2-DAY COURTESY TRANSPORTATION 23034 miles
05/04/2005 088484 # B0048 - FRONT BUMPER FASCIA REPLACEMENT 21919 miles
05/04/2005 088484 # E0721 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - LEFT - REPLACE 21919 miles
05/04/2005 088484 # Z7902 - 2-DAY COURTESY TRANSPORTATION 21919 miles
02/02/2005 084352 # E2020 - WHEEL ALIGNMENT MEASUREMENT 15975 miles
02/02/2005 084352 # J3340 - CLAMP, RADIATOR HOSE - REPLACE 15975 miles
02/02/2005 084352 # B5410 - BODY - RESEAL 15975 miles
02/02/2005 084352 # C2860 - FRONT FLOOR CONSOLE REPLACEMENT 15975 miles
02/02/2005 084352 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 15975 miles
02/02/2005 084352 # Z7902 - 2-DAY COURTESY TRANSPORTATION 15975 miles
11/23/2004 081365 # B9650 - HIGH MOUNT STOP LAMP REPLACEMENT 11055 miles
11/23/2004 081365 # C4202 - FRONT FLOOR PANEL CARPET REPLACEMENT 11055 miles
11/23/2004 081365 # C2421 - INSTRUMENT PANEL INSULATOR PANEL REPLACEMENT - LEFT SIDE 11055 miles
11/23/2004 081365 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 11055 miles
11/23/2004 081365 # Z7901 - 1-DAY COURTESY TRANSPORTATION 11055 miles
11/04/2004 344554 # Z2080 - ROADSIDE SERVICE (TOWING) 9657 miles
10/08/2004 079261 # E0431 - GOODYEAR/DUNLOP TIRE REPLACEMENT 7650 miles
10/08/2004 079261 # B1530 - HOOD INSULATOR REPLACEMENT 7650 miles
09/03/2004 077850 # B4350 - KNOB, FRONT DOOR INSIDE LOCKING - RIGHT - REPLACE 4401 miles
07/07/2004 075494 # E0431 - GOODYEAR/DUNLOP TIRE REPLACEMENT 788 miles
04/23/2004 A84124 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
  #1789 (permalink)
Old 02-09-09, 10:27 AM
Casino Cash: $6900
Originally Posted by Cowan480 View Post
1G6DN56S450116370
See what I have on this car!!
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 04/09/2005 0 miles 04/09/2009 50000 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 04/09/2005 0 miles 04/09/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 04/09/2005 0 miles 04/09/2013 80000 miles
48/50000 FEDERAL EMISSION 04/09/2005 0 miles 04/09/2009 50000 miles
CLAIM HISTORY
02/20/2006 242215 # N6608 - EMISSIONS SYSTEM WIRING AND/OR CONNECTOR REPAIR OR REPLACE 15520 miles
02/15/2006 242023 # J3100 - RADIATOR REPLACEMENT 15222 miles
02/15/2006 242023 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 15222 miles
02/15/2006 242023 # Z7901 - 1-DAY COURTESY TRANSPORTATION 15222 miles
10/18/2005 236798 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 8397 miles
10/04/2005 236135 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 8049 miles
10/04/2005 236135 # Z7902 - 2-DAY COURTESY TRANSPORTATION 8049 miles
10/04/2005 236135 # C4020 - TRIM ASSEMBLY, QUARTER - RIGHT - R&R OR REPLACE 8049 miles
10/04/2005 236135 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 8049 miles
07/14/2005 232594 # B7540 - MOLDING, WINDSHIELD REVEAL - R&R OR REPLACE 3657 miles
07/14/2005 232594 # Z7901 - 1-DAY COURTESY TRANSPORTATION 3657 miles
02/18/2005 301471 # Y0027 - DOOR LATCH FREEZING IN COLD TEMPERATURES - APPLY SUPER LUB 10 miles
07/21/2004 A16370 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
  #1790 (permalink)
Old 02-09-09, 10:28 AM
Casino Cash: $6900
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 09/20/2004 13 miles 09/20/2008 50013 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 09/20/2004 13 miles 09/20/2010 100013 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 09/20/2004 13 miles 09/20/2012 80013 miles
48/50000 FEDERAL EMISSION 09/20/2004 13 miles 09/20/2008 50013 miles
CLAIM HISTORY
04/27/2007 287951 # N4187 - INSTRUMENT CLUSTER-ASSEMBLY RETURN TO AC DELCO ESC 41312 miles
04/26/2007 287951 # N4180 - INSTRUMENT CLUSTER REPLACEMENT 41312 miles
04/26/2007 287951 # Z7901 - 1-DAY COURTESY TRANSPORTATION 41312 miles
04/26/2007 287951 # C2399 - INSTRUMENT PANEL LOWER EXTENSION REPLACEMENT 41312 miles
04/20/2007 287721 # C2540 - PANEL/PAD ASSEMBLY, INSTRUMENT PANEL - REPLACE 41087 miles
04/20/2007 287721 # J3255 - RADIATOR SURGE TANK CAP REPLACEMENT 41087 miles
12/11/2006 281493 # R9290 - NAVIGATIONAL 36654 miles
09/27/2006 277717 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 32586 miles
09/27/2006 277717 # R0760 - RADIO, REMOVE AND REPLACE 32586 miles
09/27/2006 277717 # Z7903 - 3-DAY COURTESY TRANSPORTATION 32586 miles
09/27/2006 277717 # C2860 - FRONT FLOOR CONSOLE REPLACEMENT 32586 miles
09/22/2006 277451 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 32444 miles
09/22/2006 277451 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 32444 miles
09/22/2006 277451 # Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 32444 miles
09/22/2006 277451 # R0760 - RADIO, REMOVE AND REPLACE 32444 miles
09/22/2006 277451 # D0362 - CONTROL, HEATER AND AIR CONDITIONING - REPLACE 32444 miles
09/22/2006 277451 # E3910 - SHIELD AND/OR BUMPER, FRONT STRUT - RIGHT - REPLACE 32444 miles
07/12/2006 310747 # J6372 - SENSOR, OXYGEN (ENGINE CONTROL) - REPLACE 26478 miles
07/12/2006 310747 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 26478 miles
07/12/2006 310747 # V1302 - 05004 - REPLACE SDM 26478 miles
03/09/2005 017899 # J3100 - RADIATOR REPLACEMENT 9264 miles
03/09/2005 017899 # Z7902 - 2-DAY COURTESY TRANSPORTATION 9264 miles
05/26/2004 167208 T S0011 - REPLACING KEYS 2 miles
05/13/2004 A91712 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
  #1791 (permalink)
Old 02-09-09, 10:47 AM
Cadillac(s): '04 CTS-V, '03 CTS 3.2, '92 C4 Corvette 425hp
View ToyCTSV's Photo Album
Casino Cash: $1210
thank you!
  #1792 (permalink)
Old 02-09-09, 10:53 AM
Cadillac(s): Cadillac
View LT4POWR's Photo Album
Casino Cash: $655
Thanks!...and wow , that's a lot of "issues"...this car scares me...
  #1793 (permalink)
Old 02-09-09, 12:03 PM
Cadillac(s): None
Casino Cash: $1530
This one as well: VIN# 1G6DN57S840176228. Thanks for the find 96Fleetwood
  #1794 (permalink)
Old 02-09-09, 02:44 PM
Casino Cash: $6900
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 04/20/2004 24 miles 04/20/2008 50024 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 04/20/2004 24 miles 04/20/2010 100024 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 04/20/2004 24 miles 04/20/2012 80024 miles
48/50000 FEDERAL EMISSION 04/20/2004 24 miles 04/20/2008 50024 miles
CLAIM HISTORY
07/02/2008 466550 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 51165 miles
07/02/2008 466550 # H9991 - CUSTOMER CONCERN NOT DUPLICATED - BRAKES 51165 miles
04/09/2008 460514 # J3340 - CLAMP, RADIATOR HOSE - REPLACE 49473 miles
04/09/2008 460514 # Z7902 - 2-DAY COURTESY TRANSPORTATION 49473 miles
10/15/2007 446740 # Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 46128 miles
10/15/2007 446740 # J1507 - MOUNT, ENGINE - FRONT - BOTH - REPLACE 46128 miles
10/15/2007 446740 # C2860 - FRONT FLOOR CONSOLE REPLACEMENT 46128 miles
10/15/2007 446740 # K0610 - CYLINDER, CONCENTRIC SLAVE - REPLACE 46128 miles
09/10/2007 296882 # Z8014 - ROADSIDE SERVICE (BATTERY/JUMP START) 44171 miles
09/10/2007 296882 # N0110 - BATTERY REPLACEMENT 44171 miles
09/10/2007 296891 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 44171 miles
09/10/2007 296891 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 44171 miles
09/10/2007 296891 # J0540 - VALVE STEM OIL SEAL AND VALVE SPRING REPLACEMENT - RIGHT S 44171 miles
09/10/2007 296891 # Z7901 - 1-DAY COURTESY TRANSPORTATION 44171 miles
09/10/2007 296891 # T2020 - TOWING 44171 miles
09/09/2007 P25891 # Z2085 - ROADSIDE SERVICE (PREMIUM) 44000 miles
08/16/2007 308400 # F2154 - BUSHING, REAR DIFFERENTIAL CARRIER SUPPORT OR MOUNT - REPL 42829 miles
08/16/2007 308400 # N2460 - SUNROOF SWITCH REPLACEMENT 42829 miles
08/16/2007 308400 # Z7903 - 3-DAY COURTESY TRANSPORTATION 42829 miles
08/01/2007 307211 # R0760 - RADIO, REMOVE AND REPLACE 42404 miles
08/01/2007 307211 # Z7902 - 2-DAY COURTESY TRANSPORTATION 42404 miles
08/01/2007 307211 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 42404 miles
01/31/2007 914719 # B7289 - HEADLAMP/COMPOSITE ASSEMBLY - LEFT - REPLACE 33129 miles
01/31/2007 914719 # Z7901 - 1-DAY COURTESY TRANSPORTATION 33129 miles
11/13/2006 288285 # Z7901 - 1-DAY COURTESY TRANSPORTATION 30294 miles
11/13/2006 288285 G Z7901 - 1-DAY COURTESY TRANSPORTATION 30294 miles
11/13/2006 288285 # E9050 - POWER STEERING PUMP REPLACEMENT 30294 miles
11/13/2006 288285 # Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 30294 miles
11/06/2006 287713 # N4199 - INSTRUMENT CLUSTER REPROGRAMMING WITH SPS 30005 miles
10/10/2006 285834 # Z7903 - 3-DAY COURTESY TRANSPORTATION 28405 miles
10/10/2006 285834 # J3100 - RADIATOR REPLACEMENT 28405 miles
10/10/2006 285834 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 28405 miles
08/01/2006 280736 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 24843 miles
08/01/2006 280736 # Z7902 - 2-DAY COURTESY TRANSPORTATION 24843 miles
05/01/2006 273870 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 19904 miles
04/10/2006 272258 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 19118 miles
04/10/2006 272258 # N3360 - SUNROOF WINDOW MOTOR REPLACEMENT 19118 miles
04/10/2006 272258 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 19118 miles
04/10/2006 272258 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 19118 miles
03/29/2006 271421 # N6644 - MIRROR SYSTEM WIRING AND/OR CONNECTOR REPAIR OR REPLACEMEN 18175 miles
12/27/2005 264804 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 16894 miles
12/27/2005 264804 # R0760 - RADIO, REMOVE AND REPLACE 16894 miles
12/27/2005 264804 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 16894 miles
12/27/2005 264804 # K2720 - TRANSMISSION REPLACEMENT 16894 miles
12/27/2005 264804 # N2460 - SUNROOF SWITCH REPLACEMENT 16894 miles
12/27/2005 264804 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 16894 miles
07/18/2005 880019 # C4020 - TRIM ASSEMBLY, QUARTER - RIGHT - R&R OR REPLACE 14797 miles
07/18/2005 880019 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 14797 miles
07/18/2005 880019 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 14797 miles
07/18/2005 880019 # F1280 - PROPELLER SHAFT ASSEMBLY - R&R OR REPLACE 14797 miles
07/18/2005 880019 # V1302 - 05004 - REPLACE SDM 14797 miles
12/22/2004 866363 # R5140 - MODULE, VEHICLE INTERFACE UNIT VIU/VCIM - REPLACE 10158 miles
12/22/2004 866363 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 10158 miles
12/22/2004 866363 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 10158 miles
05/05/2004 850604 # E0720 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - RIGHT - REPLAC 756 miles
03/29/2004 A76228 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
  #1795 (permalink)
Old 02-09-09, 05:00 PM
Cadillac(s): 94 Fleetwood / 83 El Dog.
View SmurfsElDog's Photo Album
Casino Cash: $405
6G2VX12G54L183022
Im looking to buy this 2004 GTO but the dealer says there is some problems and with love it'd work better but Im trying to figure out what problems. I know I'm not a supporting member but I havn't really got that much help on the one cadillac I do own; maybe if this dealer will drop the price on this V2 I'll be a proud owner and donate a little to the forums
Thanks for help.
  #1796 (permalink)
Old 02-09-09, 05:22 PM
my name is Tiffany
Cadillac(s): 05 CTS-V
View urbanski's Photo Album
Casino Cash: $1133630
^^your thread received plenty of attention, and you were banned for insulting a supermod here...
  #1797 (permalink)
Old 02-09-09, 05:32 PM
Casino Cash: $405
My thread got attention of people telling me what to do that I stated I have already done.
  #1798 (permalink)
Old 02-09-09, 06:11 PM
josney's Avatar
AA is for quitters
Cadillac(s): CTS
View josney's Photo Album
Casino Cash: $13420
could you check this CTS for me? Thanks!!
1G6DM577640185296
  #1799 (permalink)
Old 02-09-09, 06:32 PM
Cadillac(s): '94 Eldorado , '05 V8 STS
View blunted's Photo Album
Casino Cash: $6767
removed
  #1800 (permalink)
Old 02-10-09, 02:05 AM
Cadillac(s): 2006 Escalade ESV Platinum
View mbovinet's Photo Album
Casino Cash: $2795
Please send mine over.
3GYFK66N46G228902
PM or email to mbovinet@hotmail.com
Thanks
Mike
Tags: , , , , ,
carfax, checks, favor, hereand, hereread, post, read, vin
Censor is OFF
