Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V General Discussion
2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category.
Cadillac Forums: VIN checks here...READ POST #1 BEFORE ASKING
  #1726 (permalink)
Old 01-20-09, 09:57 AM
lusterblade's Avatar
Cadillac Owners Enthusiast
View lusterblade's Photo Album
Casino Cash: $6900
Re: VIN checks here...READ FIRST POST
Originally Posted by EChas3 View Post
Thank you for the VIN check. I ended up buying the car & negotiating to get it Certified. Would a new VIN Check show the extended warranty coverage? 2006 STS4 N* 1SG - 1G6DC67A160111999.
Yes, see below.
2006 STS V8 LUXURY SPORTS SEDAN
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 09/21/2005 34 miles 09/21/2009 50034 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 09/21/2005 34 miles 09/21/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 09/21/2005 34 miles 09/21/2013 80034 miles
48/50000 FEDERAL EMISSION 09/21/2005 34 miles 09/21/2009 50034 miles
72/100000 LUXURY CERTIFIED PRE-OWNED LIMITED WARRANTY 09/21/2005 34 miles 09/21/2011 100034 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/06/2009 267761 # N6606 - FUEL SYSTEM WIRING AND/OR CONNECTOR REPAIR OR REPLACEMENT 42732 miles
01/06/2009 267761 # B1670 - SUPPORT, HOOD (GAS TUBE) - ONE OR BOTH - REPLACE 42732 miles
01/06/2009 267761 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 42732 miles
12/29/2008 267370 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 42578 miles
12/29/2008 267370 # J5350 - PEDAL, ACCELERATOR - REPLACE 42578 miles
05/30/2008 582697 # Y0075 - 06516 SYSTEM SOFTWARE UPGRADE - REPROGRAM ENGINE CONTROL M 38962 miles
05/30/2008 582697 # V1798 - 07204 - REPLACE FRONT AND REAR DIFFERENTIAL SEAL (SRX AWD, 38962 miles
05/30/2008 582697 # Z7901 - 1-DAY COURTESY TRANSPORTATION 38962 miles
02/01/2008 572759 # R4490 - TRANSMITTER, REMOTE DOOR/REAR COMPARTMENT LOCK - REPLACE 36093 miles
01/30/2008 572547 # E0722 - TIRE PRESSURE INDICATOR SENSOR REPLACEMENT 36093 miles
01/30/2008 572547 # Z7901 - 1-DAY COURTESY TRANSPORTATION 36093 miles
01/30/2008 572547 # B0485 - FRONT AIR DEFLECTOR REPLACEMENT 36093 miles
04/26/2007 548922 0 M0016 - LUBE, OIL AND FILTER 26164 miles
04/26/2007 548922 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 26164 miles
08/01/2006 525175 0 M0017 - LUBE, OIL AND FILTER 13241 miles
05/01/2006 516782 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 9198 miles
05/01/2006 516782 0 M0017 - LUBE, OIL AND FILTER 9198 miles
05/01/2006 516782 # B4001 - FRONT SIDE DOOR ADJUSTMENT - LEFT SIDE 9198 miles
02/08/2006 509237 # Z7901 - 1-DAY COURTESY TRANSPORTATION 7203 miles
02/08/2006 509237 0 M0021 - MAINTENANCE SERVICE - TIRE ROTATION 7203 miles
02/08/2006 509237 0 M0017 - LUBE, OIL AND FILTER 7203 miles
02/08/2006 509237 # C1130 - WEATHERSTRIP - REAR DOOR OPENING - RIGHT - ALIGN OR REPLAC 7203 miles
11/23/2005 502498 0 M0017 - LUBE, OIL AND FILTER 3900 miles
07/29/2005 A11999 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
193 - EBONY
19I - EBONY INTERIOR TRIM
1SG - 1SG PREMIUM LUXURY PERFORMANCE PACKAGE: *PREMIUM TUSCANY LEATHER SEATS *MULTI-DRIVER MEMORY SETTINGS *POWER ADJUSTABLE LUMBAR *HEATED/VENTILATED FRONT SEATS *HEATED REAR OUTBOARD SEATS *HEATED, WOOD STEERING WHEEL *EUCALYPTUS WOOD TRIM ON CENTER STACK, CONSOLE, IP, SHIFT KNOB, DOOR TRIM AND STRG WHEEL *BOSE 5.1 STUDIO SURROUND SOUND WITH IN-DASH 6 DISC DVD CHANGER AND ADVANCED DVD NAVIGATION, INCLUDES TWO FREE MAP UPDATES (REPLACES STD/OPT RADIO) (REPLACES COMPASS IN MIRROR) *RAINSENSE WIPERS *UNIVERSAL HOME REMOTE *AUTO DIMMING ISRV MIRROR (REPLACES STD ISRV MIRROR) *HIGH INTENSITY DISCHARGE (HID) HEADLAMPS *INTELLIBEAM AUTO HIGH BEAM CONTROL *HEADLAMP WASHERS *18" POLISHED ALUMINUM WHEELS *MICHELIN P235/50R18 FRONT P255/45R18 REAR W-RATED TIRES *TIRE PRESSURE MONITOR *MAGNETIC RIDE CONTROL *EXPRESS OPEN/CLOSE SUNROOF *REAR SPOILER *TRUNK CONVENIENCE NET *AUTO AIR QUALITY SENSOR PERFORMANCE FEATURES: *LIMITED SLIP DIFFERENTIAL (N/A WITH ALL WHEEL DRIVE) *4-WHL. PERFORMANCE DISC BRAKES WITH ABS *PERFORMANCE COOLING PACKAGE *PREMIUM ZF STEERING GEAR
1SZ - PREFERRED EQUIPMENT SAVINGS
41U - BLACK RAVEN
6SD - COMPONENT SUSPENSION
7SD - COMPONENT SUSPENSION
8HJ - SUSPENSION
9HJ - SUSPENSION
A45 - MULTI-DRIVER MEMORY SETTINGS
AL2 - POWER LUMBAR CONTROL
AP9 - TRUNK CONVENIENCE NET
AQ9 - SEAT FRT BKT, LUXURY
AY0 - INFLATABLE RESTRAINT DRI & PASS
B20 - EUCALYPTUS WOOD TRIM ON CENTER STACK, CONSOLE,IP, SHIFT KNOB, DOOR TRIM AND STRG WHEEL
CE1 - RAINSENSE WIPERS
CE4 - HEADLAMP WASHERS
CF5 - EXPRESS OPEN/CLOSE SUNROOF
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP
DD8 - AUTO DIMMING ISRV MIRROR
DL5 - DECAL - ROADSIDE SERVICE INFO
DR2 - O/S REARVIEW PWR, HEATED MIRRS
F55 - CVRTD MAGNETO RHEOLOGICAL
FE3 - MAGNETIC RIDE CONTROL
FE9 - 50-STATE EMISSIONS
GU5 - AXLE REAR, 3.23 RATIO
IL3 - PREMIUM TUSCANY LEATHER SEATS
JE5 - 17" PERFORMANCE BRAKES
JJA - PT DRESS SUBASSEMBLY INSTALLED
K14 - FILTER, AIR, AUTO RECIRCULATING
K59 - ADAPTIVE CRUISE CONTROL INCLUDES HEAD-UP DISPLAY
KA6 - HEATED SEATS, REAR
KB6 - HEATED/VENTILATED FRONT SEATS
KG4 - 150 AMP GENERATOR
LH2 - 4.6L NORTHSTAR V8 VVT 320 HP
MV3 - ALL WHEEL DRIVE
MX7 - MERCH. TRANS
N31 - HEATED, WOOD STEERING WHEEL
N87 - 18" POLISHED ALUMINUM WHEELS
NT9 - EMISSION - FEDERAL
NV7 - PREMIUM ZF STEERING GEAR
Q12 - MICHELIN P235/50R18 FRONT P255/45R18 REAR W-RATED TIRES
R6P - PREMIUM PAINT
R8E - GAS GUZZLER TAX
R9N - LEATHER
R9U - GM ACCESS-AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS
T43 - REAR SPOILER
TQ5 - INTELLIBEAM AUTO HIGH BEAM CONTROL
TT6 - HIGH INTENSITY DISCHARGE (HID) HEADLAMPS
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
U30 - INSTRUMENT CLUSTER,TACH,CLOCK
UA6 - THEFT-DETERRENT ALARM SYSTEM
UE1 - ONSTAR SYSTEM INCLUDES 1 YR DIRECTIONS & CONNECTIONS
UG1 - UNIVERSAL HOME REMOTE
UJ6 - TIRE PRESSURE MONITOR
UV6 - RECONFIGURABLE HEAD UP DISPLAY
UY5 - 15 SPEAKER SYSTEM
V03 - PERFORMANCE COOLING PACKAGE
V4X - STS CONVERSION V8
V73 - VEHICLE STATEMENT USA/CANADA
YQ4 - BOSE 5.1 STUDIO SURROUND SOUND WITH IN-DASH 6 DISC DVD CHANGER AND ADVANCED DVD NAVIGATION, INCLUDES TWO FREE MAP UPDATES
  #1727 (permalink)
Old 01-20-09, 09:59 AM
Casino Cash: $6900
Originally Posted by JIMMYJOHNSON View Post
Thanks to you guys, I avoided buying another lemon- But that also means I am still looking- I found a nice one- please check vin????
1G6DP577360178929 06 CTS SPORT
2006 CTS 3.6L V6 VVT SPORT
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 05/16/2006 224 miles 05/16/2010 50224 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/16/2006 224 miles 05/16/2012 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/16/2006 224 miles 05/16/2014 80224 miles
48/50000 FEDERAL EMISSION 05/16/2006 224 miles 05/16/2010 50224 miles
CLAIM HISTORY
04/08/2008 413472 # V1777 - 07204 - REPLACE REAR DIFFERENTIAL SEAL ONLY 26394 miles
04/08/2008 413472 # Z7901 - 1-DAY COURTESY TRANSPORTATION 26394 miles
11/09/2007 407821 # Z2159 - NATIONAL FALL PROMOTION 2007 21211 miles
04/27/2007 399819 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 12701 miles
04/27/2007 399819 # Z7901 - 1-DAY COURTESY TRANSPORTATION 12701 miles
12/01/2006 394485 # B7540 - MOLDING, WINDSHIELD REVEAL - R&R OR REPLACE 8666 miles
12/01/2006 394485 # Z7903 - 3-DAY COURTESY TRANSPORTATION 8666 miles
12/01/2006 394485 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 8666 miles
11/21/2006 394102 # B5410 - BODY - RESEAL 8324 miles
11/21/2006 394102 # Z7901 - 1-DAY COURTESY TRANSPORTATION 8324 miles
02/09/2006 086650 I Z6999 - PDI RELATED FLUID ADDS 2 miles
01/30/2006 A78929 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
194 - EBONY
1SB - CTS STANDARD PACKAGE
41U - BLACK RAVEN
6DS - SUSPENSION
7DS - SUSPENSION
8MK - SUSPENSION
9MK - SUSPENSION
A45 - MEMORY SEAT ADJUSTER
AH8 - 10-WAY PWR. PASS. SEAT W/ PWR. LUMBAR
B18 - WOOD TRIM
B56 - ROCKER MOLDING COLOR
CE4 - WASHER HEADLAMP, HIGH PRESSURE
CF5 - EXPRESS OPEN SUNROOF
DD7 - COMPASS IN ISRV MIRROR
DR5 - MIRROR O/S REMOTE L/H R/H
FE5 - PERFORMANCE SUSPENSION
G80 - LIMITED SLIP AXLE
GU6 - AXLE REAR 3.42 RATIO
IL4 - TRIM INTERIOR DESIGN
JL4 - STABILITRAK 2.0
KA1 - HEATED FRONT SEATS
KG9 - GENERATOR 140 AMP
LY7 - 3.6L V6 VVT ENGINE
M82 - 5-SPEED AUTOMATIC TRANSMISSION
MX0 - MERCH 5-SPEED AUTO TRANSMISSION
N30 - STEERING WHEEL DELUXE
NDB - CHROME EXHAUST TIPS
NT7 - EMISSION - FEDERAL
P40 - 18" POLISHED ALLOY 12 SPOKE SPORT WHEELS
QGQ - P225/50R18 W RATED TIRE
R1Y - 3.6L V6 VVT SPORT
R6P - PREMIUM PAINT
R8K - *******************************
R9N - LEATHER
SLM - STOCK ORDERS
T43 - REAR SPOILER
TL4 - SPORT GRILLE W/CHROME MESH INSERTS
TT6 - HIGH INTENSITY HEADLAMPS
U2R - AM/FM STEREO/CAS/IN-DASH SINGLE CD, RDS
U66 - 7 SPEAKER SYSTEM
UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL. 1 YR SAFE & SOUND PLAN
UJ6 - TIRE PRESSURE MONITORING
V4W - CTS CONVERSION
VGE - CUSTOM BODY COLOR FASCIA
Y41 - 3.6L V6 LUXURY PACKAGE: * MEMORY SEAT ADJUSTER * COMPASS IN ISRV MIRROR * 10-WAY POWER SEATS W/ LUMBAR * HEATED FRONT SEATS * UNIVERSAL HOME REMOTE * THEFT-DETERRENT ALARM SYSTEM
Y43 - 3.6L V6 18" WHEEL PERFORMANCE PACKAGE
  #1728 (permalink)
Old 01-20-09, 10:58 AM
Mr.Tickles's Avatar
Cadillac(s): 04 CTS-V, 66 Hearse, 78 Hearse
View Mr.Tickles's Photo Album
Casino Cash: $765
Thank you Very Much!
04 CTS-V, K&N CAI, 245/45/18 Nitto 555 Tires, B&B Cat Back Exhaust, Vette FRC, Extreme C. Hood, CTS arm rest, Blacked out and Slowly Being Modified
  #1729 (permalink)
Old 01-20-09, 12:58 PM
Cadillac(s): Cadillac
View humpsjr's Photo Album
Casino Cash: $275
Red face Re: VIN checks here...READ FIRST POST
1G6DW677950222858 Looking for vin check to find option package. any help would be greatly appreciated.
  #1730 (permalink)
Old 01-20-09, 01:32 PM
Cadillac(s): 2006 CTS-V
View ZX12monster's Photo Album
Casino Cash: $1125
hey lusterblade,
i bought my 06 V back in october and recently noticed the rear bumper cover was loose. i ordered the rear clips and put it back on but it leads me to believe the cover has been off b/c the car had been hit.
can you run this VIN for me?
1G6DN57U060193934
thanks
  #1731 (permalink)
Old 01-20-09, 04:55 PM
my name is Tiffany
Cadillac(s): 05 CTS-V
View urbanski's Photo Album
Casino Cash: $1133630
thanks lb
  #1732 (permalink)
Old 01-20-09, 10:42 PM
Cadillac(s): none
View surferd15's Photo Album
Casino Cash: $310
Can you run this please, these Vs are selling like crazy!!
1G6DN56S850172392
  #1733 (permalink)
Old 01-21-09, 09:30 AM
pmtom1's Avatar
Cadillac(s): '05 CTS-V Raven (wrecked 12/07), '05 CTS-V Raven #2
View pmtom1's Photo Album
Casino Cash: $1710
Surferd15
1G6DN56S850172392
VEHICLE INFORMATION
Merchandising Model : 6DN69 -2005 CTS-V Warranty Start Date : 06/10/2005
BARS Order Type : 81 - DEALER USED CAR (CVMS USE)
Delivering Dealer : N/A Selling Source : N/A
Site Code : N/A
Business Associate Code : N/A
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
YT 05544 ON-BOARD DIAGNOSTICS SYSTEM SOFTWARE UPGRADE (REPROGRAM PCM) N/A Closed
SERVICE INFORMATIONAL ITEMS
SB 06049 ONSTAR H/W IS DIGITAL-CAPABLE. NO UPGRADE IS NEEDED. SEE TSB 06-08-46-008. 02/22/2007 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Inactive
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 06/10/2005 0 miles 06/10/2009 50000 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 06/10/2005 0 miles 06/10/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 06/10/2005 0 miles 06/10/2013 80000 miles
48/50000 FEDERAL EMISSION 06/10/2005 0 miles 06/10/2009 50000 miles
72/100000 LUXURY CERTIFIED PRE-OWNED LIMITED WARRANTY 06/10/2005 0 miles 06/10/2011 100000 miles
CLAIM HISTORY
12/15/2008 042561 # K9992 - CUSTOMER CONCERN NOT DUPLICATED 45169 miles
11/05/2008 040933 # C2795 - PLATE OR BOOT, CONSOLE FLOOR SHIFT - REPLACE 44002 miles
11/05/2008 040933 # F2154 - BUSHING, REAR DIFFERENTIAL CARRIER SUPPORT OR MOUNT - REPL 44002 miles
11/05/2008 040933 # Z7901 - 1-DAY COURTESY TRANSPORTATION 44002 miles
10/17/2008 040143 # E0484 - STUD, WHEEL MOUNTING - RIGHT REAR - REPLACE 43281 miles
03/21/2008 031048 # H0122 - FRONT BRAKE ROTOR REFINISHING 41237 miles
01/17/2008 027735 # J3100 - RADIATOR REPLACEMENT 38014 miles
01/17/2008 027735 # Z7902 - 2-DAY COURTESY TRANSPORTATION 38014 miles
11/30/2007 025531 # H0127 - FRONT BRAKE ROTOR REPLACEMENT - BOTH SIDES 36994 miles
11/30/2007 025531 # D9995 - CUSTOMER CONCERN NOT DUPLICATED - HVAC 36994 miles
03/05/2007 011857 # N0850 - FRONT FOG LAMP BULB REPLACEMENT 24449 miles
03/05/2007 011857 # Z7901 - 1-DAY COURTESY TRANSPORTATION 24449 miles
01/17/2007 009519 # C6040 - ADJUSTER ASSEMBLY, FRONT SEAT POWER - BUCKET SEAT - PASSEN 23673 miles
01/09/2006 195998 # K1120 - TRANSMISSION CONTROL REPLACEMENT 15545 miles
10/12/2005 191591 # E0431 - GOODYEAR/DUNLOP TIRE REPLACEMENT 11562 miles
10/07/2005 191382 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 11176 miles
10/07/2005 191382 # F1517 - HALFSHAFT, REAR DRIVE - REAR - LEFT - R&R 11176 miles
02/03/2005 110049 # Y0027 - DOOR LATCH FREEZING IN COLD TEMPERATURES - APPLY SUPER LUB 4 miles
12/06/2004 A72392 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
AH8 - 10-WAY PWR. PASS. SEAT W/ PWR. LUMBAR AL2 - POWER LUMBAR CONTROL
AM9 - SPLIT-FOLDING REAR SEAT AQ9 - SEAT FRT BKT, LUXURY
AY0 - INFLATABLE RESTRAINT DRI & PASS A45 - MEMORY SEAT ADJUSTER
CE4 - WASHER HEADLAMP, HIGH PRESSURE CF5 - EXPRESS OPEN SUNROOF
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP DD8 - MIRROR AUTO DAY/NIGHT I/S R/V
DL5 - DECAL - ROADSIDE SERVICE INFO DR5 - MIRROR O/S REMOTE L/H R/H
FE4 - SUSPENSION FE9 - 50-STATE EMISSIONS
GT4 - AXLE REAR 3.73 RATIO IL5 - TRIM INTERIOR DESIGN
JJA - PT DRESS SUBASSEMBLY INSTALLED J56 - BRAKES, ANTILOCK
KA1 - HEATED FRONT SEATS KG4 - 150 AMP GENERATOR
LS6 - LS6 5.7L V8 ENGINE M12 - TREMEC 6-SPEED MANUAL TRANS
NT9 - EMISSION - FEDERAL N34 - STEERING WHEEL, LEATHER
P32 - WHEEL 18" ALUMINUM QKR - P245/45R18 W RATED
R7K - HURRICANE EXPEDITING R8E - GAS GUZZLER TAX
SLM - STOCK ORDERS UAV - DVD NAVIGATION SYSTEM INCL: XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INC (DELETES COMPASS IN MIRROR)
UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1YR SAFE & SOUND PLAN U2K - XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL
U30 - INSTRUMENT CLUSTER,TACH,CLOCK U57 - 8 SPEAKER SYSTEM
VM3 - LABEL-FRT & RR 5 MPH BUMPER V73 - VEHICLE STATEMENT USA/CANADA
1SA - CTS-V STANDARD PACKAGE 1SZ - PREFERRED EQUIPMENT SAVINGS
19I - EBONY INTERIOR TRIM 195 - EBONY
46U - STEALTH GRAY 6MH - COMP FRT LH COMPUTER SEL SUSP
7MH - COMP FRT RH COMPUTER SEL SUSP 8GW - SUSPENSION
9GW - SUSPENSION
  #1734 (permalink)
Old 01-23-09, 11:25 AM
View Plaster's Photo Album
Casino Cash: $450
Please check into #1G6DN57U270114927 when you get the chance. Thank you in advance.
  #1735 (permalink)
Old 01-23-09, 02:39 PM
Cadillac(s): Escalade
View jeepun77's Photo Album
Casino Cash: $645
Can you please run VIN 1GYEK63N82R179987. Thanks for your help.
Steve
  #1736 (permalink)
Old 01-23-09, 02:49 PM
Cadillac(s): 2005 CTS-V
View smackdaddy's Photo Album
Casino Cash: $4095
Steve
VIN : 1GYEK63N82R179987
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 11/17/2001 12 miles 11/17/2005 50012 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 11/17/2001 12 miles 11/17/2007 100012 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 11/17/2001 12 miles 11/17/2009 80012 miles
48/50000 FEDERAL EMISSION 11/17/2001 12 miles 11/17/2005 50012 miles
CLAIM HISTORY
08/19/2002 875238 # Z8015 - ROADSIDE SERVICE (FLAT TIRE) 5100 miles
12/19/2001 351848 # D0362 - HEATER AND AIR CONDITIONING CONTROL REPLACEMENT 8144 miles
12/19/2001 351848 # B7863 - MOLDING, FRONT DOOR - RIGHT - LOWER - R&R OR REPLACE 8144 miles
12/05/2001 350332 # D1810 - AIR INLET VALVE ACTUATOR REPLACEMENT 4143 miles
12/05/2001 350332 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 4143 miles
10/31/2001 A79987 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Merchandising Model : 6K15706 -2002 ESCALADE
Gross Vehicle Weight Rating : 3178 kg (7007 lb) Order Number : DNSJVX
Build Date : 10/31/2001 Build Plant : 12R06
OPTION CODES
AG1 - ADJUSTER FRT ST POWER, MULTI- DIRECTIONAL, DRIVER AG2 - ADJUSTER PASS ST POWER, MULTI- DIRECTIONAL
AJ1 - WINDOW TINTED DEEP, ALL EXCEPT W/S AND DRS AN3 - SEAT FRT, INDIVIDUAL (NON BKT)
ARL - PLANT CODE ARLINGTON, TX USA AS3 - SEAT RR SUBURBAN/UTILITY
AT5 - SEAT RR CTR, FLDG AU0 - LOCK CONTROL REMOTE ENTRY
AXP - VIN IDENT POSITION, MULTI- PURPOSE VEHICLE A31 - WINDOW POWER OPERATED, ALL DOORS
BS1 - INSULATION ACOUSTICAL PKG BVF - STEPS RUNNINGBOARD, SIDE, COLOR KEYED
BW2 - MOLDING B/S DELUXE B30 - COVERING FLOOR CARPET
B58 - COVERING FLOOR MAT, FRT & RR CARPETED INSERT CF5 - POWER GLASS SUNROOF
C25 - WIPER SYSTEM RR WINDOW, INTERMITTENT C36 - HEATER AUXILIARY
C49 - DEFOGGER RR WINDOW, ELECTRIC C5W - GVW RATING 7,000 LBS
C68 - HVAC SYSTEM AIR CONDITIONER FRT, AUTO, ELECTRONIC CONTROLS C69 - HVAC SYSTEM RR AIR CONDITIONER
DF5 - MIRROR I/S R/V LT SENSITIVE, COMPASS, O/S TEMP DISPLAY DH2 - MIRROR I/S FRT VAN LH & RH, ILLUM, WITH DUAL SUNSHADE
DK8 - CONSOLE ROOF INTERIOR, DELUXE DL7 - MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, COLOR
D07 - CONSOLE FRT COMPT, FLOOR,CUSTOM EVA - TEST DVT, EVAP EMISSION REQ.
E52 - BODY EQUIPMENT ONE PIECE LIFT GATE WITH LIFT GLASS FE9 - FEDERAL EMISSIONS
FK2 - ARM LH TORS BAR SPRING ADJ FK3 - ARM RH TORS BAR SPRING ADJ
GT4 - AXLE REAR 3.73 RATIO G69 - LEVEL CONTROL, AUTO AIR HD
G80 - AXLE POSITRACTION LIMITED SLIP JH5 - BRAKE HYD POWER, 4 WHL DISC. 7,200 LBS.
JL4 - CONTROL ACTIVE BRAKE KA6 - HEATER SEAT, RR
KC4 - COOLING SYSTEM ENG OIL KC5 - RECEPTACLE ELECTRICAL, ACCESSORY
KG8 - GENERATOR 130 AMP KNP - COOLING SYSTEM TRANS, HD
KUP - THROTTLE CONTROL ELECTRONIC K34 - CRUISE CONTROL AUTOMATIC, ELE.
K47 - AIR CLEANER HIGH CAPACITY LQ9 - 8 CYL, 6.0L, HIGH OUTPUT ENGINE
M32 - 4-SPD AUTOMATIC TRANSMISSION NF2 - EMISSION SYSTEM FEDERAL, TIER 1
NP3 - TRANSFER CASE ALL WHEEL DRIVE N30 - STEERING WHEEL DELUXE
N93 - WHEEL 17 X 7.5, ALUMINUM QAN - TIRE ALL P265/7OR17-1135 BW
QE4 - WHEEL SPARE 16 X 6.5, ALUMINUM R4Y - TIRE BRAND ALL GOODYEAR
SLM - SALES STOCK ORDERS TL1 - GRILLE SPECIAL
T74 - HEADLAMPS CONTROL AUTOMATIC DELAY T96 - LAMP FOG, FRT
UD7 - SENSOR INDICATOR REAR PARKING ASSIST. UE1 - COMMUNICATION SYSTEM VEHICLE
UG1 - OPENER GARAGE DOOR UNIVERSAL UK3 - CONTROL STEERING WHEEL, ACCESSORY
UK6 - RADIO CONTROL RR SEAT & EARPHONE JACKS UL9 - RADIO AM/FM STEREO, SEEK/SCAN AUTO REV MUSIC SEARCH CASS, CD, AUTO TONE CLOCK, ETR, BOSE
UQ7 - SPEAKER SYSTEM PREMIUM PERF. ENHANCED AUDIO, BOSE UY7 - WIRING HARNESS TRUCK TRAILER,HD
U1Z - PLAYER MULTIPLE COMPACT DISC PASS COMPARTMENT U68 - DISPLAY DRIVER INFO CENTER
U84 - ANTENNA BODY SIDE WINDOW, RADIO VP6 - NOISE CONTROL
VR4 - TRAILER HITCH WEIGHT DIST. PLATFORM VT4 - BUMPER FRT COLOR KEYED
VT5 - BUMPER RR COLOR KEYED VXS - VEHICLE COMPLETE
V54 - LUGGAGE CARRIER ROOF, PAINTED V73 - VEHICLE STATEMENT USA/CANADA
XAN - TIRE FRONT P265/7OR17-113S BW YAN - TIRE REAR P265/7OR17-113S BW
YD3 - AXLE (BASE EQUIP) YD6 - SPRING RR BASE EQUIP.
YE9 - CONVENIENCE PKG COMFORT & DECOR LEVEL #3 Y91 - MERCHANDISED PKG LUXURY EDITION
ZGC - TIRE SPARE P265/75R16-114S BW ZY1 - COLOR COMBINATION SOLID
Z55 - CHASSIS PACKAGE BI-STATE REAL TIME DAMPING Z75 - CONVERSION NAME PLT CADILLAC
Z82 - TRAILER PROVISIONS SPECIAL EQUIP H.D. 15I - INTERIOR TRIM SHALE
152 - SHALE LEATHER 41U - SABLE BLACK
6XK - COMPONENT FRT LH COMPUTER SEL 7XK - COMPONENT FRT RH COMPUTER SEL SUSP
  #1737 (permalink)
Old 01-23-09, 02:52 PM
chazglenn3's Avatar
Cadillac(s): 2000 Bronzemist Seville STS
View chazglenn3's Photo Album
Casino Cash: $3744
Would you please run a check for 1G6KY5494YU305600...thank you! This is a great service that you guys do!
Charles
2000 Bronzemist Z-Rated STS
  #1738 (permalink)
Old 01-23-09, 02:54 PM
Casino Cash: $4095
VIN : 1G6KY5494YU305600
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 05/05/2000 0 miles 05/05/2004 50000 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/05/2000 0 miles 05/05/2006 100000 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/05/2000 0 miles 05/05/2008 80000 miles
48/50000 FEDERAL EMISSION 05/05/2000 0 miles 05/05/2004 50000 miles
CLAIM HISTORY
04/11/2005 137339 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 63184 miles
04/11/2005 137339 # Z7901 - 1-DAY COURTESY TRANSPORTATION 63184 miles
04/13/2004 121869 # C2710 - LATCH, CONSOLE COMPARTMENT - ADJUST OR REPLACE 51931 miles
04/13/2004 121869 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 51931 miles
04/13/2004 121869 # C1280 - WEATHERSTRIP - REAR COMPARTMENT OPENING - ALIGN OR REPLACE 51931 miles
04/13/2004 121869 # B5410 - BODY - RESEAL 51931 miles
02/20/2004 119678 # K6500 - PAN AND/OR GASKET, TRANSMISSION OIL- REPLACE 49975 miles
12/22/2003 117311 # J4640 - STARTER REPLACEMENT 48868 miles
12/22/2003 117311 # J1840 - ENGINE, UNIVERSAL - REPLACE 48868 miles
12/22/2003 117311 # Z7903 - 3-DAY COURTESY TRANSPORTATION 48868 miles
11/28/2003 116382 # N2320 - IGNITION AND START SWITCH REPLACEMENT 48146 miles
11/28/2003 116382 # Z7901 - 1-DAY COURTESY TRANSPORTATION 48146 miles
11/08/2003 089814 # Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 47691 miles
11/08/2003 089814 # N0110 - BATTERY REPLACEMENT 47691 miles
11/08/2003 089814 # N1720 - FUSE - REPLACE 47691 miles
11/03/2003 115208 # E7692 - SENSOR ASSEMBLY, STEERING WHEEL SPEED - REPLACE 47593 miles
11/03/2003 115208 # Z7901 - 1-DAY COURTESY TRANSPORTATION 47593 miles
10/03/2003 113972 # B7280 - HEADLAMP AIMING 46697 miles
06/24/2003 109959 # E8067 - STEERING LINKAGE OUTER TIE ROD REPLACEMENT - BOTH SIDES 42872 miles
06/09/2003 109293 # I7000 - PART REPLACEMENT FOR IUV RE-CONFIGURE CAMPAIGN 42500 miles
06/09/2003 109293 # V0744 - INSTALL & RECONFIGURE VIU 42500 miles
06/09/2003 109293 # Z7901 - 1-DAY COURTESY TRANSPORTATION 42500 miles
11/29/2002 102090 # N4855 - MODULE - MEMORY MIRROR - REPLACE 35025 miles
11/29/2002 102090 # Z7901 - 1-DAY COURTESY TRANSPORTATION 35025 miles
04/30/2002 095018 # C3358 - FRONT SIDE DOOR TRIM PANEL REPLACEMENT - LEFT SIDE 27409 miles
04/30/2002 095018 # C3348 - FRONT SIDE DOOR TRIM PANEL REPLACEMENT - RIGHT SIDE 27409 miles
04/15/2002 094412 # J4355 - CRANKSHAFT POSITION SENSOR REPLACEMENT 26285 miles
04/15/2002 094412 # H0042 - PADS, DISC BRAKE - FRONT - R&R OR REPLACE 26285 miles
04/15/2002 094412 # Z7902 - 2-DAY COURTESY TRANSPORTATION 26285 miles
12/05/2000 074492 # R3290 - MIRROR, OUTSIDE REAR VIEW - ELECTRIC REMOTE CONTROL - RIGH 9746 miles
12/05/2000 074492 # E9050 - POWER STEERING PUMP REPLACEMENT 9746 miles
11/20/2000 073922 # J4355 - CRANKSHAFT POSITION SENSOR REPLACEMENT 9714 miles
11/20/2000 073922 # N2145 - SWITCH - DOOR WINDOW - LEFT FRONT - REPLACE 9714 miles
11/20/2000 073922 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 9714 miles
07/25/2000 076715 # J4355 - CRANKSHAFT POSITION SENSOR REPLACEMENT 4852 miles
07/25/2000 076715 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 4852 miles
05/03/2000 U05600 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 5 miles
Merchandising Model : 6KY69 -2000 SEVILLE STS
Gross Vehicle Weight Rating : 2272 kg (5010 lb) Order Number : CJVFDC
Build Date : 04/17/2000 Build Plant : 1YUK - HAMTRAMCK ASSEMBLY
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AC9 - ADAPTIVE SEATS AJ7
AQ9 A45
CE1 CF5
CJ2 DD7
DEH DR2
FE3 FE9
FV4 F45
IL5 - TRIM INTERIOR DESIGN JL4
JL9 KA1
KG4 LHD
L37 MH1
MX0 NF2
NP5 P05
QDC - TIRES-GOODYEAR EAGLE LS P235/60ZR16 R7F - FEDERAL EMISSIONS DEALER
UE1 - ONSTAR COMMUNICATIONS & ASSISTANCE SYSTEM (INCLUDES ONE YEAR PREMIUM SERVICE PLAN) UG1
UM9 UV7 - RADIO ANTENNA - WINDSHIELD
UX9 - SPEAKER SYSTEM 8, DUAL F/D MTD, DUAL RR DR, TRIPLE I/P, PKG SHELF AMPLIFIER, BOSE UY9
VM3 - LABEL INFORMATION CONUMER, CONTAINS BPR IMP STANDARD FOR FRT 5MPH & RR 5MPH V03 - COOLING SYSTEM EXTRA CAPACITY
V73 WJ7
YM5 1AY
1SE 15I
155 6PA
7PA 76U - BRONZEMIST
8DH - COMP RR LH COMPUTER SEL SUSP 9DH - COMP RR RH COMPUTER SEL SUSP
  #1739 (permalink)
Old 01-23-09, 05:49 PM
Casino Cash: $450
Didn't realize my membership wasn't paid up. Let's try again: #1G6DN57U270114927.
Thank you.
  #1740 (permalink)
Old 01-24-09, 02:16 AM
chazglenn3's Avatar
Casino Cash: $3744
Awesome...thanks Smackdaddy!
Tags: , , , , ,
carfax, checks, favor, hereand, hereread, post, read, vin
Censor is OFF
