Originally Posted by JIMMYJOHNSON one more check pretty please? 2006 CTS
1G6DP577660120247 |
2006 CTS 3.6L V6 VVT APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 10/31/2005 11 miles 10/31/2009 50011 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 10/31/2005 11 miles 10/31/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 10/31/2005 11 miles 10/31/2013 80011 miles
48/50000 FEDERAL EMISSION 10/31/2005 11 miles 10/31/2009 50011 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
11/17/2008 M22660 # N0110 - BATTERY REPLACEMENT 34753 miles
11/17/2008 M22660 # C8870 - INFLATABLE RESTRAINT PASSENGER SEAT SUPPRESSION MODULE REP 34753 miles
11/17/2008 M22660 # H0127 - FRONT BRAKE ROTOR REPLACEMENT - BOTH SIDES 34753 miles
07/01/2008 586343 # N0761 - BULBS, STOP, TAIL, AND TURN LAMP (LEFT) - REPLACE 28666 miles
03/25/2008 577219 # V1777 - 07204 - REPLACE REAR DIFFERENTIAL SEAL ONLY 25782 miles
03/19/2008 576730 # B9640 - LAMP ASSEMBLY, EXTERIOR - STOP, TAIL AND TURN SIGNAL - RIG 25393 miles
01/30/2008 572515 # E0431 - GOODYEAR/DUNLOP TIRE REPLACEMENT 23607 miles
01/30/2008 572515 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 23607 miles
01/16/2008 571295 # E8060 - STEERING LINKAGE OUTER TIE ROD REPLACEMENT - RIGHT SIDE 23390 miles
01/16/2008 571295 # R0760 - RADIO, REMOVE AND REPLACE 23390 miles
12/17/2007 568899 # E1707 - FRAME, ENGINE - COMPLETE - REPLACE 19453 miles
12/17/2007 568899 # R4490 - TRANSMITTER, REMOTE DOOR/REAR COMPARTMENT LOCK - REPLACE 19453 miles
12/17/2007 568899 # E8061 - STEERING LINKAGE OUTER TIE ROD REPLACEMENT - LEFT SIDE 19453 miles
09/24/2007 561826 # Z7901 - 1-DAY COURTESY TRANSPORTATION 16861 miles
09/24/2007 561826 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 16861 miles
09/22/2007 561773 # Z2159 - NATIONAL FALL PROMOTION 2007 16751 miles
08/14/2006 526288 # C0034 - WINDSHIELD REPLACEMENT 6800 miles
04/24/2006 516088 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 4680 miles
04/24/2006 516088 # R0760 - RADIO, REMOVE AND REPLACE 4680 miles
02/17/2006 509978 # Z8014 - ROADSIDE SERVICE (BATTERY/JUMP START) 2853 miles
11/10/2005 501163 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 695 miles
11/10/2005 501163 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 695 miles
11/10/2005 501163 # Z7901 - 1-DAY COURTESY TRANSPORTATION 695 miles
08/19/2005 A20247 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
OPTION CODES
194 - EBONY
19I - EBONY INTERIOR TRIM
1SB - CTS STANDARD PACKAGE
1SZ - PREFERRED EQUIPMENT SAVINGS
41U - BLACK RAVEN
6ML - SUSPENSION
7ML - SUSPENSION
8FW - COMP RR LH COMPUTER SEL SUSP
9FW - COMP RR RH COMPUTER SEL SUSP
A45 - MEMORY SEAT ADJUSTER
AH8 - 10-WAY PWR. PASS. SEAT W/ PWR. LUMBAR
AL2 - POWER LUMBAR CONTROL
AM9 - SPLIT-FOLDING REAR SEAT
AQ9 - SEAT FRT BKT, LUXURY
AY0 - INFLATABLE RESTRAINT DRI & PASS
B18 - WOOD TRIM
CE4 - WASHER HEADLAMP, HIGH PRESSURE
CF5 - EXPRESS OPEN SUNROOF
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP
DL5 - DECAL - ROADSIDE SERVICE INFO
DR5 - MIRROR O/S REMOTE L/H R/H
FE2 - SPORT SUSPENSION
FE9 - 50-STATE EMISSIONS
G80 - LIMITED SLIP AXLE
GU6 - AXLE REAR 3.42 RATIO
IL4 - TRIM INTERIOR DESIGN
JE2 - HIGH PERFORMANCE BRAKE LINING
JJA - PT DRESS SUBASSEMBLY INSTALLED
JL4 - STABILITRAK 2.0
JL9 - ANTILOCK BRAKE FRT & REAR
KA1 - HEATED FRONT SEATS
KG9 - GENERATOR 140 AMP
LY7 - 3.6L V6 VVT ENGINE
M82 - 5-SPEED AUTOMATIC TRANSMISSION
MX0 - MERCH 5-SPEED AUTO TRANSMISSION
N30 - STEERING WHEEL DELUXE
N93 - 17" POLISHED ALLOY WHEELS
NT7 - EMISSION - FEDERAL
QWW - P255/50R17 W-RATED TIRES
R6P - PREMIUM PAINT
R9N - LEATHER
SLM - STOCK ORDERS
TT6 - HIGH INTENSITY HEADLAMPS
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
U30 - INSTRUMENT CLUSTER,TACH,CLOCK
U57 - 8 SPEAKER SYSTEM
UA6 - THEFT-DETERRENT ALARM SYSTEM
UAV - DVD NAVIGATION SYSTEM, WITH ETR AM/FM STEREO, 6-DISC CD CHANGER, BOSE, XM SATELLITE RADIO & XM NAVTRAFFIC-SERVICE FEES EXTRA. 1ST 3 MONTHS INCL INCLUDES TWO FREE MAP UPDATES (REPLACES STD/OPT RADIO) (DELETES COMPASS IN MIRROR)
UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL. 1 YR SAFE & SOUND PLAN
UG1 - UNIVERSAL HOME REMOTE
V4W - CTS CONVERSION
V73 - VEHICLE STATEMENT USA/CANADA
Y41 - 3.6L V6 LUXURY PACKAGE: * MEMORY SEAT ADJUSTER * COMPASS IN ISRV MIRROR * 10-WAY POWER SEATS W/ LUMBAR * HEATED FRONT SEATS * UNIVERSAL HOME REMOTE * THEFT-DETERRENT ALARM SYSTEM
Y42 - 17" WHEEL SPORT PACKAGE: * 4-WHL INDEPENDENT SUSPENSION * STABILITRAK-STABILITY CONTROL * P225/50R17 W-RATED TIRES * 17" MACHINE FINISHED WHEELS * LIMITED SLIP DIFFERENTIAL * HIGH INTENSITY HEADLAMPS
