Originally Posted by T.O. V Don't know if you're working over the holidays, but when you get a chance:
1G6DN57S140164602
Happy Holidays! |
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 04/21/2004 28 miles 04/21/2008 50028 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 04/21/2004 28 miles 04/21/2010 100028 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 04/21/2004 28 miles 04/21/2012 80028 miles
48/50000 CALIFORNIA EMISSIONS 04/21/2004 28 miles 04/21/2008 50028 miles
84/70000 CALIFORNIA SELECT COMPONENT 04/21/2004 28 miles 04/21/2011 70028 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
07/30/2007 O25777 # Z2080 - ROADSIDE SERVICE (TOWING) 28000 miles
07/30/2007 030838 # N4585 - SENSOR, ENGINE OIL PRESSURE - REPLACE 28644 miles
02/21/2007 K29896 # Z2085 - ROADSIDE SERVICE (PREMIUM) 27000 miles
02/21/2007 305492 # Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 27554 miles
02/21/2007 305492 # N0110 - BATTERY REPLACEMENT 27554 miles
01/06/2006 093193 # V1302 - 05004 - REPLACE SDM 22006 miles
01/06/2006 093193 # Z7901 - 1-DAY COURTESY TRANSPORTATION 22006 miles
06/30/2005 066437 # N4199 - INSTRUMENT CLUSTER REPROGRAMMING WITH SPS 14721 miles
05/10/2005 063279 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 13111 miles
05/10/2005 063279 # Z7901 - 1-DAY COURTESY TRANSPORTATION 13111 miles
02/07/2005 069420 # Z7901 - 1-DAY COURTESY TRANSPORTATION 10641 miles
10/18/2004 061571 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 6729 miles
10/18/2004 061571 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 6729 miles
10/18/2004 061571 # C3540 - REAR SIDE DOOR TRIM PANEL REPLACEMENT - RIGHT SIDE 6729 miles
10/18/2004 061571 # Z7901 - 1-DAY COURTESY TRANSPORTATION 6729 miles
08/25/2004 057971 # C3385 - BEZEL, FRONT DOOR INSIDE PULL HANDLE - LEFT - REPLACE 4013 miles
07/28/2004 056021 # Z7901 - 1-DAY COURTESY TRANSPORTATION 3168 miles
05/05/2004 050146 # C6871 - DRIVER SEAT CUSHION COVER REPLACEMENT 409 miles
05/05/2004 050146 # Z7901 - 1-DAY COURTESY TRANSPORTATION 409 miles
02/25/2004 A64602 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 1G6DN57S140164602
VEHICLE BUILD
Merchandising Model : 6DN69 -2004 CTS-V
Gross Vehicle Weight Rating : 2182 kg (4811 lb) Order Number : GVVB7W
Build Date : 02/25/2004 Build Plant : 140D
OPTION CODES
AH8 - 10-WAY PWR. PASS. SEAT W/ PWR. LUMBAR
AL2 - POWER LUMBAR CONTROL
AM9 - SPLIT-FOLDING REAR SEAT
AQ9 - SEAT FRT BKT, LUXURY
AY0 - INFLATABLE RESTRAINT DRI & PASS
A45 - MEMORY SEAT ADJUSTER
CE4 - WASHER HEADLAMP, HIGH PRESSURE
CF5 - EXPRESS OPEN SUNROOF
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP
DD8 - MIRROR AUTO DAY/NIGHT I/S R/V
DL5 - DECAL - ROADSIDE SERVICE INFO
DR5 - MIRROR O/S REMOTE L/H R/H
FE4 - SUSPENSION
GT4 - AXLE REAR 3.73 RATIO
IL3 - TRIM INTERIOR DESIGN
JJA - PT DRESS SUBASSEMBLY INSTALLED
J56 - BRAKES, ANTILOCK
KA1 - HEATED FRONT SEATS
KG4 - 150 AMP GENERATOR
LS6 - LS6 5.7L 400 HP V8 ENGINE
MN6 - TREMEC 6-SPEED MANUAL TRANS
M12 - MANUAL TRANS
NU4 - EMISSION - CALIFORNIA
N34 - STEERING WHEEL, LEATHER
PDL - LUXURY PACKAGE
P32 - WHEEL 18" ALUMINUM
QKR - P245/45R18 ALL SEASON BW
R8X - FLEET GUARANTEED DELIVERY PGRM
SLM - STOCK ORDERS
TT6 - HIGH INTENSITY HEADLAMPS
UAV - DVD NAVIGATION SYSTEM INCL: XM SATELLITE RADIO-100 CHANNEL COAST TO COAST DIGITAL SOUND (SUBSCRIPTION CHARGES EXTRA- DELETES COMPASS IN MIRROR)
UA6 - THEFT DETERENT SYSTEM
UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1YR SAFE & SOUND PLAN UG1 - UNIVERSAL GARAGE DOOR OPENER
U2K - XM SATELLITE RADIO-100 CHANNELS OF GO ANYWHERE ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL
U30 - INSTRUMENT CLUSTER,TACH,CLOCK
U57 - 8 SPEAKER SYSTEM
VG6 - CALIF, 5 MPH BUMPER LABEL
VG8 - NOTICE TO BUYER LABEL
V73 - VEHICLE STATEMENT USA/CANADA
YF5 - 50-STATE EMISSIONS
1SA - CTS STANDARD PACKAGE
1SZ - PREFERRED EQUIPMENT SAVINGS
6MH - COMP FRT LH COMPUTER SEL SUSP
67U - LIGHT PLATINUM
7MH - COMP FRT RH COMPUTER SEL SUSP
70I - LIGHT NEUTRAL
703 - LIGHT NEUTRAL
8GW - SUSPENSION
9GW - SUSPENSION
