Originally Posted by landell 1G6DN56S250106596 Please and Thank you. |
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 08/18/2004 80 miles 08/18/2008 50080 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 08/18/2004 80 miles 08/18/2010 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/18/2004 80 miles 08/18/2012 80080 miles
48/50000 CALIFORNIA EMISSIONS 08/18/2004 80 miles 08/18/2008 50080 miles
84/70000 CALIFORNIA SELECT COMPONENT 08/18/2004 80 miles 08/18/2011 70080 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
05/01/2008 043885 # Z7901 - 1-DAY COURTESY TRANSPORTATION 46745 miles
05/01/2008 043885 # D1440 - DEFLECTOR, AIR (OUTLET VENT) - RIGHT - REPLACE 46745 miles
12/11/2007 034637 # F2154 - BUSHING, REAR DIFFERENTIAL CARRIER SUPPORT OR MOUNT - REPL 39466 miles
12/11/2007 034637 # Z7902 - 2-DAY COURTESY TRANSPORTATION 39466 miles
12/11/2007 034637 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 39466 miles
10/18/2007 030817 # B7288 - HEADLAMP/COMPOSITE ASSEMBLY - RIGHT - REPLACE 36860 miles
10/18/2007 030817 # B7289 - HEADLAMP/COMPOSITE ASSEMBLY - LEFT - REPLACE 36860 miles
10/18/2007 030817 # N2460 - SUNROOF SWITCH REPLACEMENT 36860 miles
10/18/2007 030817 # Z7905 - 5-DAY COURTESY TRANSPORTATION 36860 miles
10/18/2007 030817 # H2505 - ELECTRONIC BRAKE AND TRACTION CONTROL MODULE REPLACEMENT 36860 miles
10/18/2007 030817 # H2496 - SENSOR, BRAKE PRESSURE MODULATOR - REPLACE 36860 miles
10/18/2007 030817 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 36860 miles
06/21/2007 022034 # E0722 - TIRE PRESSURE INDICATOR SENSOR REPLACEMENT 29874 miles
06/21/2007 022034 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 29874 miles
06/21/2007 022034 # R0760 - RADIO, REMOVE AND REPLACE 29874 miles
02/07/2007 014164 # H0127 - FRONT BRAKE ROTOR REPLACEMENT - BOTH SIDES 22095 miles
02/07/2007 014164 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 22095 miles
02/07/2007 014164 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 22095 miles
11/15/2006 011498 # E0719 - TIRE VALVE STEM GROMMET REPLACEMENT 16467 miles
11/15/2006 011498 # H9991 - CUSTOMER CONCERN NOT DUPLICATED 16467 miles
11/15/2006 011498 # C4020 - TRIM ASSEMBLY, QUARTER - RIGHT - R&R OR REPLACE 16467 miles
11/15/2006 011498 # Z7902 - 2-DAY COURTESY TRANSPORTATION 16467 miles
11/15/2006 011498 # C7210 - COVER, REAR SEAT BACK CENTER ARMREST - R&R OR REPLACE 16467 miles
10/18/2006 908685 # C2200 - INSTRUMENT PANEL ASHTRAY REPLACEMENT 15788 miles
10/18/2006 908685 # N0110 - BATTERY REPLACEMENT 15788 miles
09/25/2006 907261 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 15788 miles
09/25/2006 907261 # R0760 - RADIO, REMOVE AND REPLACE 15788 miles
07/31/2006 495388 # E0725 - SENSOR, LOW TIRE PRESSURE WARNING - REAR - LEFT - REPLACE 15086 miles
03/23/2006 077349 # J3100 - RADIATOR REPLACEMENT 14772 miles
03/23/2006 077349 # C8870 - INFLATABLE RESTRAINT PASSENGER SEAT SUPPRESSION MODULE REP 14772 miles
10/31/2005 481618 # E0724 - SENSOR, LOW TIRE PRESSURE WARNING - REAR - RIGHT - REPLACE 9038 miles
10/31/2005 481618 # H9711 - FRAME, REAR SUPPLEMENTAL BUSHINGS - INSTALL 9038 miles
10/31/2005 481618 # F1617 - SEAL, AXLE SHAFT OIL - REAR AXLE - BOTH - REPLACE 9038 miles
10/31/2005 481618 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 9038 miles
10/26/2005 088474 # N0110 - BATTERY REPLACEMENT 9032 miles
10/26/2005 854507 # Z2085 - ROADSIDE SERVICE (PREMIUM) 2000 miles
12/04/2004 090071 # Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 3637 miles
12/04/2004 405554 # Z2085 - ROADSIDE SERVICE (PREMIUM) 3000 miles
06/23/2004 453885 I Z6999 - PDI RELATED FLUID ADDS 2 miles
06/08/2004 A06596 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
06/08/2004 453885 I Z6998 - PDI ADDS 1 miles
