Cadillac now offers shock absorbers for the CTS-V...
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
2004-2007 Cadillac CTS-V General Discussion Discussion, Cadillac now offers shock absorbers for the CTS-V... in Cadillac CTS-V Series Forum - 2004 - 2007; Does that option cure the wheel hop? You can see it under the Build your cts-v under options. This is ...
    trekster's Avatar
    trekster is offline Cadillac Owners Connoisseur
    Automobile(s): 04 CTS-V R.I.P.
    Apr 2004
    Downey,CA
    30
    1,234
    Does that option cure the wheel hop? You can see it under the Build your cts-v under options. This is what it says:
    SHOCK ABSORBERS Regular Production Accessory, Performance Shock Absorber Package (SPO-supplied, dealer-installed) (FG2) $1260
  2. #2
    lasstss's Avatar
    lasstss is offline Cadillac Owners Connoisseur
    Dec 2003
    Ellicott City
    2,873
    Re: Cadillac now offers shock absorbers for the CTS-V...
    $300+ ea. for shocks is insane, even if it did cure the wheel hop. I dont know where they get off charging that kind of cash for a shock. IMO.
    I will wait for an aftermarket resolution..
  3. #3
    trekster's Avatar
    Apr 2004
    Downey,CA
    30
    1,234
    Quote Originally Posted by lasstss
    Do you have any idea when the aftermarket shocks are coming out? I'm getting my CTS-V next saturday. I wanted to fix the wheel hopping by the time I break in the engine for the cts-v due to various reasons .
  4. #4
    Uber-V's Avatar
    Uber-V is offline Cadillac Owners Member
    Mar 2004
    57
    82
    The shocks may help wheel hop but I doubt it will eliminate it. Both Lund and Mallett will offer alternatives as well but expect pricing to be relative to quality and performance. 300 per shock may seem expensive when compared to basic shocks but my understanding is that the GM upgrade is a pretty special shock. The shocks from Mallett are Penske in two versions. One is non adjustable and the other is adjustable. The adjustable ones I've seen also have remote reserviors. If you think $1200 for a set is expensive check this out:
    Mallett-Penske
    Non adjustable full set $2529.90
    Adjustable full set $3915.00
    Coil-over upgrade for adjustable full set $1575.00
    So, full adjustable coil-over Penske's for $5490.00
    I'll bet the Lund setup won't be less than the GM since it will be adjustable coil-overs as well.
    The GM upgrade at $1200 doesn't look too bad now if it works well.
    Also, if you are going to run aggressive track events you will want the diff. cooler as well. From GMPD soon.
  5. #5
    Cal
    Cal is offline Cadillac Owners Enthusiast
    Apr 2004
    NJ Shore
    763
    It does kind of burn my balls that they came out with this a couple months after the release of the V so all the people who see the car and go buy one will have the option, while we don't. Ah well.
    $5k for a serious suspension is OK in my book, since aggressive track will be my main focus with the car. Very important modification.
    Diff. cooler from GM? Hadn't heard anyone else talk about that being necessary. Forgive my ignorance when I ask what it does/helps/fixes. I had planned on doing a thermo mod, just not sure yet which part it takes.
    - C.
  6. #6
    Uber-V's Avatar
    Mar 2004
    57
    82
    The diff cooler will be available late next month. It is for the serious road race track day user. The diff fluid gets hot enough to change state after 15 minutes of constant race driving. The cooler will keep the fluid at a reasonable temperature for extended periods.
  7. #7
    benjet's Avatar
    benjet is offline Cadillac Owners Connoisseur
    Dec 2003
    Bay Area, CA
    1,372
    Quote Originally Posted by Cal
    (OT to this thread) Do you mean changing out the coolant thermostat to a lower temp one? The Z06 guys (from what I've read on their forum) say that is is counter productive.
    Now an Oil Cooler would be helpful....
    -Ben
  8. #8
    trekster's Avatar
    Apr 2004
    Downey,CA
    30
    1,234
    [QUOTE=Uber-V]The shocks may help wheel hop but I doubt it will eliminate it. Both Lund and Mallett will offer alternatives as well but expect pricing to be relative to quality and performance. 300 per shock may seem expensive when compared to basic shocks but my understanding is that the GM upgrade is a pretty special shock. The shocks from Mallett are Penske in two versions. One is non adjustable and the other is adjustable. The adjustable ones I've seen also have remote reserviors. If you think $1200 for a set is expensive check this out:
    Mallett-Penske
    Also, if you are going to run aggressive track events you will want the diff. cooler as well. From GMPD soon.[/QUOTE Which of the shocks enlisted would be the most suitable for drag racing?
  9. #9
    Uber-V's Avatar
    Mar 2004
    57
    82
    I really don't know which shocks will be the best for drag racing. All of the upgrades I mentioned including the GM upgrade are intended for road racing. Drag racing has its own set of demands on shocks that are much different from road racing. The CTS-V performance traits lend itself more to road racing than drag racing. IRS is not the best setup for drag racing. If your serious about it you may want to check into a 4 link with a ford 9". That will cure wheel hop for sure.
  10. #10
    gothicaleigh's Avatar
    gothicaleigh is offline Cadillac Owners Master
    Automobile(s): Current: None Past: '94 STS, '93 Eldorado, '98 ETC, '03 CTS
    Oct 2003
    MyWorldIsEvil, ButAmericanMade
    6,654
    It does seem like kind of a waste to buy a CTS-V for the strip. Sure, it comes with monstrous amounts of horsepower and torque, but the car shines in the twisties...
  11. #11
    trekster's Avatar
    Apr 2004
    Downey,CA
    30
    1,234
    Quote Originally Posted by gothicaleigh
    True lets see what I end up doing.
  12. #12
    Cal
    Apr 2004
    NJ Shore
    763
    Strange, because the shop I go to which is primarily Z06 does suggest lower-temp thermo mods. I guess if you ask 100 different people you will get 100 different answers on how to modify your car.
    Thanks for the heads up on the diff. cooler U-V, I am new to aggresive track racing so any advice of that nature is always appreciated.
  13. #13
    lasstss's Avatar
    Dec 2003
    Ellicott City
    2,873
    Im not sure what the factory is usung for Diff fluid. If its not already synthetic and you have over 500miles on the gearset you could switch.
    On the stat, just about everyone doing any racing had switched out to the 160deg stat. Im speaking of the LT-1 here. The LS-1 should be no different. The slight lowering of temp gives a little denser fuel mixture. It works! I know I picked up 1-2 tenths doing the stat and throttle valve by pass mod.
    The V has the throttle by wire. I have not taken a good look at it yet to see if they are pumping hot coolant thru it like the LT-1
  14. #14
    03Z06Vette's Avatar
    03Z06Vette is offline Cadillac Owners Fanatic
    Automobile(s): 2015i Escalade ESV, 2016 CTS-V
    Apr 2004
    Waco, Texas, United States
    45
    220
    I just put a 160 deg stat in my Z06 and I am running around 30-35 deg F cooler in the coolant temps and only 5 degrees cooler oil temps. The only reason the LSx engines run so hot is for emissions, not for performance. All C5s also have the throttle body coolant line running through it to avoid sticking of the throttle body when it is freezing. I have heard that bypassing it doesn't do anything performance wise anyway.
  15. #15
    ttown's Avatar
    ttown is offline Cadillac Owners Member
    Apr 2004
    Oklahoma
    44
    87
    I deal with a lot of high performance motor people and they all state that the ideal engine running temp. is between 180 - 190 degrees.
    I have a 160 stat. on my Z06.
  16. Remove Advertisements
