Test Method: Model Year 1996 and newer vehicles will be subject to On-board Diagnostic (OBD) testing and Model Year 1995 and older vehicles will be subject to Two Speed Idle (TSI) testing.
Heck, they probably use the same equipment we use.
If they look under the car and see something that looks like a catalytic converter you should be good.
If you don't have converters at all you might just fail.
We have to do a visual on the converter, then do the OBD test.
As I said, if you don't have a CEL on you will probably pass an OBD test.
(it has to work... it just can't be on with codes)
