Power Steering Fluid Change... - Page 2
Results 16 to 30 of 32
2004-2007 Cadillac CTS-V General Discussion Discussion, Power Steering Fluid Change... in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by ewill3rd Some places you'd be better of not having them do it (if you know what I ...
  1. #16
    MescalVto is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Dec 2005
    Michigan
    288
    Re: Power Steering Fluid Change...
    Quote Originally Posted by ewill3rd View Post
    Some places you'd be better of not having them do it (if you know what I mean)
    Well, I do know exactly what you mean as while this dealer does generally provide good service; I saw smoke coming from under my hood periodically for two days after the flush, likely due to the mess left
  2. #17
    ewill3rd is offline Cadillac Technician
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    James might be better suited to answer as to what our policy would be.
    As a tech I can see GM not wanting me to flush it with anything but GM fluid, cold climate or the regular stuff.
    I wouldn't have a problem doing it but GM would probably want me to charge you to do something like that.
    Again, James is the real policy maker around here
  3. #18
    heavypedal's Avatar
    heavypedal is offline Cadillac Owners Fanatic
    Automobile(s): '04 Raven CTS-V
    Oct 2005
    Raleigh, North Cackalacky
    415
    roger Roger. Had to ask for convenience sake.
    T
  4. #19
    calicadi's Avatar
    calicadi is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    Aug 2004
    797
    Hey, thanks, e! Reed...You snoopin' out there? Could be an FAQ entry.
  5. #20
    Automobile(s): none
    Nov 2005
    WOODBRIDGE, VA
    48
    11,051
    We have a "flushing machine" but it is kind of weird.
    It has two nozzles, one above the other. One puts fluid into the reservoir and the other sucks it out. You are supposed to have an assistant turn the wheel with the engine running while you hold it in the reservoir and use a lever to control the flow rate to keep fluid in the system. It does an okay job but the reservoir on the V is too small for it to work effectively.
    The method I listed above is the best one I have found.
    It is how we bleed systems before we start them up after power steering system service and it actually works quite well.
  6. #21
    alpicone's Avatar
    alpicone is offline Cadillac Owners Member
    Automobile(s): 2005 Black Raven CTS-V
    Jul 2013
    Long Island, NY
    43
    So after doing some searching seems like this is a common issue once the cold temps hit. Got off the train last night with the temp at around 35F... started my car and was not happy. Little bit of reading here tells me the first thing to do is flush the power steering fluid.
    Since I won't have time until the weekend I am going to try the turkey baster method tonight and see if that helps. Does anyone know how much fluid I need for the TB method? What about for a complete flush?
  7. #22
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    I think just 1 1 liter bottle...
  8. #23
    alpicone's Avatar
    Jul 2013
    Long Island, NY
    43
    Quote Originally Posted by thebigjimsho
    Bought one bottle of power steering fluid and swapped old the old fluid using the turkey baster method. Swapped the whole bottle and I didn't get all the old fluid out. Must be a lot more that 1 liter.
    The old fluid was pretty dirty. Going to drive around a few more days and do a proper flush over the weekend.
  9. #24
    Automobile(s): ZIP
    51,885
    With that method you'll never get it all out. But it should serve you almost as well as a flush. You've done some good already, anyway...
  10. #25
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    I disconnected the return hose on the cooler and flushed a gallon through. Re connected hose and then topped off with another quart. You will need a helper for this process to start and shut the car off as to not let the pump run dry. It took all of thirty minutes and cleans the cooler as well
  11. #26
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,357
    So if i was going to flush it how many quarts should i have? Need to order some up today if possible.
    Thanks
  12. #27
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,155
    Two quarts should cover a flush, although I like to have 3 on hand in case I knock one over or something.
  13. #28
    odla's Avatar
    Nov 2006
    miami ,Fl
    2,357
    Ok thanks.
    Good to see you back.
  14. #29
    fweasel's Avatar
    fweasel is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Aug 2013
    Chicago
    256
    Quote Originally Posted by darkman View Post
    been there
  15. #30
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Wait a minute....people drive their V's in the winter?
  16. Remove Advertisements
