CTS-V switched Accessory power
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
2004-2007 Cadillac CTS-V General Discussion Discussion, CTS-V switched Accessory power in Cadillac CTS-V Series Forum - 2004 - 2007; On the V, Does anyone know where in the cabin I can find a switched 12 volt accessory power source? ...
    ctsvett's Avatar
    ctsvett is offline FAQ is your Friend
    Automobile(s): CTS-V
    Feb 2003
    California
    3,987
    On the V,
    Does anyone know where in the cabin I can find a switched 12 volt accessory power source? Switched means that when I turn on the key, the power comes on, but also goes off when I turn off the car. Something under the seats, or under the dash is great cause I dont want to have to take anything serious apart.
    I have a car kit for my phone, and dont want to keep pluging it in and unplugging it when I get in/out of the car. I dont leave it plugged in cause I dont want the battery to die.
    Any thought would be appreciated.
    Reed
    CTSVETT
  2. #2
    benjet's Avatar
    benjet is offline Cadillac Owners Connoisseur
    Dec 2003
    Bay Area, CA
    1,372
    Re: CTS-V switched Accessory power
    It would take a LONG (like weeks) time for a cell fone to drain a car battery.
  3. #3
    Mbai2's Avatar
    Mbai2 is offline Cadillac Owners Connoisseur
    Automobile(s): '08 CTS DI 6 Speed Manual Black/Black w/ FE3 Fully Loaded
    Aug 2003
    1,653
    Quote Originally Posted by mrbadss
    On the V,
    Reed
    CTSVETT
    I tapped into the harness that connects to the climate control panel. It's really easy to remove. Just open the ashtray and remove the felt tray. You'll see a screw recessed behind the tray. Loosen this screw. I had to use a magnetic driver so that the screw would stay attached to the driver when it came loose (as opposed to falling somewhere into the center console). Then you just grab the ashtray and pull straight out to loosen the clips. You'll see the harness in the back and a wire for you cigarette lighter. The harness is easy to undo but I still haven't figured out the lighter. I just let the whole thing dangle over the passenger foot well while I worked with the harness.
    Looking at the harness with the wires facing away from you, the first wire in the SECOND row should be a switched 12V. If that doesn't work, it may be the 8th wire in the FIRST row. One of them is a ground and the other is hot. Use a multimeter to confirm before doing any wiring. If you find that both are ground, don't forget to start your car :-P
  4. #4
    skides1's Avatar
    skides1 is offline Cadillac Owners Enthusiast
    Mar 2004
    Seattle
    508
    This guy gots skills! Mbai2, impressive. I know of people probing for days-not finding retained acc power due to redundancy.
  5. #5
    Innocent Bystander is offline Cadillac Owners Member
    Automobile(s): None
    Nov 2003
    50
    Each of the interior outlets can be changed from a battery feed to a switched ignition feed. (One is the cigar lighter in the ashtray, the other is the auxiliary outlet in the rear of the center console.
    To do that, go to the underhood fuse center and look for a bright yellow 20A fuse and a bright green 30A fuse that are in "wide" spaces (sorry, don't have a picture). Looking from the front of the car, they're kinda to the right of center and slightly above, between some relays. Anyway, these are the only fuses that you can move from side to side. The center contact is the one that eventually feeds the outlets. The contact on either side come from either the battery or the "cigar relay" (the switched feed). You use the fuse to bridge the appropriate gap:
    If you want the cigar outlet to be on a switched supply, move the yellow fuse one position over in the same space. If you want the rear outlet to be switched, move the green fuse one position over. The factory fuse positions bridge the gap between the battery and the center contact.
    Hope that's understandable.
    Good luck.
    IB
  6. #6
    ctsvett's Avatar
    Feb 2003
    California
    3,987
    added to CTS-V FAQ with picture...
    Reed
  7. #7
    BUILDINGCTSAMG is offline Cadillac Owners Connoisseur
    Mar 2003
    Atlanta Ga/Mclean Va
    32
    1,754
    the cigarette lighter goes off ten minutes after the key is removed, your battery wont die from ten minutes!
  8. #8
    ctsvett's Avatar
    Feb 2003
    California
    3,987
    CTSAMG,
    My power in the V does not go off after 10 minutes in the back seat.
    IB,
    That modification did not work on the 30 AMP fuse in my V. the outlet would not work when I moved the one that said "outlet I/B". I did not try it on the front outlet.
    Is this a regular CTS only thing?
    Reed
    CTSVETT
  9. #9
    Mar 2003
    32
    1,754
    Are u sure about the ten minutes, i know the cts turns it off after 10 minutes....could you look in your owners manual
  10. #10
    ctsvett's Avatar
    Feb 2003
    California
    3,987
    that part of the owners manual is the same.. The V-supplement says:
    "Your CTS-V comes equipped with two Accessory Power outles. The front outlet is in the storage compartment below the climate control center. The rear outlet is on the back of the center console. These outlets can be set to be powered while your CTS-V is running and for 10 minutes after vehicle shutdown, or they can be set so that they are powerede at all times even when the engine is off, for cell phone charging..."
    How do you "set" this "option"?
    Reed
    CTSVETT
  11. #11
    darrelld's Avatar
    darrelld is offline Cadillac Owners Enthusiast
    Jul 2003
    Dallas, Texas
    61
    543
    Reed
    CTSVETT
    <<This is a cut and paste from the CTS owners manual>>
    The accessory power outlet will only operate when the
    ignition is in ACCESSORY or ON and for 10 minutes
    after turning the ignition to OFF. If you would like
    the accessory power outlet to operate regardless of
    ignition position, and for extended periods of time,
    you can do the following:
    1. Open the hood and locate the underhood fuse block.
    2. Find the I/P OUTLET and OUTLET fuses and
    move them over a space, to the open cavity
    next to each fuse.
    <<I/P=Instrument Panel>>
  12. #12
    ctsvett's Avatar
    Feb 2003
    California
    3,987
    thanks... My dumb fault for not reading... (funny and my name is Reed)
    I was only looking at the CTS-V cd addition.
    Reed
    CTSVETT
  13. #13
    darrelld's Avatar
    Jul 2003
    Dallas, Texas
    61
    543
    Reed
    CTSVETT
    Glad to help, I found it much easier to download the pdf version of the CTS manual and use Adobe search functions to find info.
    https://www.mygmlink.com/main/US/en/...ac/2k04cts.pdf
  14. #14
    ctsvett's Avatar
    Feb 2003
    California
    3,987
    oops... that method does not work on my V. When I move the fuses, both outlets go dead (no power)...
    Is this method only for the regular CTS? Is the wiring different on the V?
    Reed
    CTSVETT
  15. #15
    darrelld's Avatar
    Jul 2003
    Dallas, Texas
    61
    543
    Reed
    CTSVETT
    The V supplement should make a reference if the systems are different. I have sucessfully reprogrammed my console outlet to not timeout for recharging my cell phone. I left the I/P outlet to time out.
  16. Remove Advertisements
