what system works best for bleeding brakes
Results 1 to 13 of 13
2004-2007 Cadillac CTS-V General Discussion Discussion, what system works best for bleeding brakes in Cadillac CTS-V Series Forum - 2004 - 2007; I am searching for the best/cost effective system to change/bleed the V's brakes...what feedback from others works best?...
    VelodromeRacer's Avatar
    VelodromeRacer is offline Cadillac Owners Member
    Automobile(s): 2005 Redline CTS-V
    May 2005
    Bloomington-Indiana
    53
  2. #2
    Dennisscars's Avatar
    Dennisscars is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-VM 51 track days in Maggied V & 82 in Atom 2 in Volt
    Mar 2005
    SoCal
    1,690
    Re: what system works best for bleeding brakes
    I've had good luck with this one
    http://www.motiveproducts.com/
    urb, remove if it's not suppose to be posted..
  3. #3
    nikon's Avatar
    nikon is offline Cadillac Owners Connoisseur
    Automobile(s): 05' CTS-V
    Feb 2006
    Palm Beach Gardens, FL
    31
    3,718
    ^^if your by yourself they're ok...but if can have a buddy help...just the good ole' pump pump hold method worked fine for me..especially since I wasn't the one pumping the brakes
  4. #4
    Mar 2005
    SoCal
    1,690
    actually leave it alone and let it gravity drain and have a beer works the best, but I get impatient and like to focus on having a beer..
  5. #5
    rgd
    rgd is offline Cadillac Owners Enthusiast
    Automobile(s): 04' CTS-V, 04' Escalade EXT
    Aug 2005
    SF Bay Area
    623
    I Like speed bleeders and find they work gr8 for me.
    Attach a clear hose to the bleeder valve, Open it up about 1/4 turn, pump brake pedal 3-4 times, close valve move to the next one.
    If you buy a good set the work well. I never get any air bubbles.
    That's how I do mine anyway.
    Good luck...
    rgd
  6. #6
    lunarx's Avatar
    lunarx is offline Cadillac Owners Connoisseur
    Automobile(s): 12 CTS Coupe Premium/Touring, 16 Volt, 13 911s
    Aug 2006
    SoCal
    1,730
    I have used both Motive and SpeedBleeders.
    For a complete flush, Motive is best.
    For a quick purge of each caliper, SpeedBleeders are best.
    SpeedBleeders don't flow very well, so they will always make it harder to do a complete flush.
    However, they rock for quick purges.
    Therefore unless you are a track guy who has to purge often go for the Motive.
    For either method it helps immensley to have the the Motive Bleeder Bottles to catch your fluid in.
    http://www.motiveproducts.com/02bleeders.html
  7. #7
    Feffman's Avatar
    Feffman is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    Nov 2006
    St. Louis, Mo.
    672
    Quote Originally Posted by Dennisscars View Post
    Doug:
    I'll second this. My neighbor uses the Motive and suggested I try it. Pretty much tossed my little hand pump in the trash. Quick, effective and relatively clean operation.
    It's imperative you follow Caddy's sequence of flushing/bleeding which is a bit different then I've done with other cars.
    Passenger Rear
    Passenger Front
    Driver's Rear
    Driver's Front
    Feff
  8. #8
    nikon's Avatar
    Feb 2006
    31
    3,718
    ^^I forgot already, was it inners first? or outers first? I wanna say inners.
  9. #9
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    Quote Originally Posted by rgd View Post
    Good luck...
    rgd
    RGD,
    I've been procrastinating on this, but it needs to be done. What part number SpeedBleeder works for us? http://www.speedbleeder.com/automobile_applications.htm of course does not list and Caddy's, or any Brembo calipers. Can you point me in the right direction?
    Additionally, what model/make SS brake lines do you use and/or recommend? I figure I might as well do them at the same time, since I'll have to completely flush/refill for both installs.
    Finally, to the guys that have the motive pump, what model did you go with? (PN please)
    Thanks,
    Chris
    2005 CTS-V:No Roof|T2+Eibachs|Corsa|UUC:Shifter, 2pc rotors, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hotchkis Sways|Kooks 1.75 Coated LTs+cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588+Dual Springs|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow OP|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Katech LS9X Clutch Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
    2012 CTS-V:No Roof|Wagon|M6|Recaros|<-- SOLD
    2014 ATS: 2.0T-M6
  10. #10
    50 4Ever's Avatar
    50 4Ever is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V (Thunder Grey)
    Dec 2005
    Sacramento Kalifornia
    67
    1,667
    Good luck...
    rgd
    This is how I do mine, clear plastic bottle with a hose to attach to the bleeder.
  11. #11
    nikon's Avatar
    Feb 2006
    31
    3,718
    Do you leave the speed bleeders on all the time...replace stock bleeders? and what are some good ones? I never knew these existed.....
  12. #12
    May 2005
    Bloomington-Indiana
    53
    I knew this was going to be good...that's why I had asked about it. I like the idea of the speedbleeders, but I want to do a complete flush and had want a system that makes that job easier...esp. for 1 person.
    I had some sessions last year where the pedal was squishy and when FFeffman is closing on you and you begin to puch it, squishy wont cut it. I hope that finding an easy to use tool will be more reason to flush the system more often.
  13. #13
    Feffman's Avatar
    Nov 2006
    St. Louis, Mo.
    672
    Doug:
    The Motive is a one person operation. You scew the cap onto the master cylinder, drop in two bottles of Motul (my choice) and pressurize the canister with the hand pump. Go back, loosen the inside bleed screw of brake caliper until the clean fluid comes through. Pump the canister (if necessary) up some more and go back to do the outside bleeder on the caliper waiting for clean fluid. It's that simple!
    Feff
  14. Remove Advertisements
