| 2004-2007 Cadillac CTS-V General Discussion Discuss everything about the first generation Cadillac CTS-V that does NOT fall into either the Performance or Appearance Modification category. | Cadillac Forums: Fix a Flat Bad for TPS????
05-02-07, 06:36 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2006 INFRARED CTS-V - BADCADY | | Join Date: Jan 2007 Location: Michigan Age: 30 | | | Fix a Flat Bad for TPS???? Going for gas at lunch today and had my first blow out.
RunFlats did their job.
I made it to the Gas Station, pulled out my trusty can of Fix-A-Flat (which I learned about carrying from the Toolkit thread) used it and continued back to work.
After work I made it to one of two Goodyear stores that can work on Runflats and too my comfort there is a Black CTS-V in the parkling lot on 20"s.
I'm comforted by the thought that they may be able to get the tire on and off with out scratching up my wheels.
After trying to sale me the same set of wheels, and plugging my hole in the tire, they told me that I'm not supposed to use Fix a flat on these tires because it burns out the TPS. IS THIS TRUE?
If so why would Fix a flat be a must have in the spare tire wheel?
Now I'm going through the tire threads trying to find the best Tires to buy.
I'm seriously leaning towards runflats again. That was so cool not having to jump out in the rain and deal with a flat, just keep on drivin!
05-02-07, 06:43 PM
|  | Moon Parasite Cadillac(s): 2006 STS-V BlackonBlack / 2005 CTS-V Redline (traded in) | | Join Date: Dec 2005 Location: D/FW Tejas | | | Re: Fix a Flat Bad for TPS???? Fix a Flat , Bad for TPS.
If it's a run flat, why would you need to use fix a flat ?
Run Flats are "supposed" to be able to be patched, but I wouldn't feel comfortable running at speed with one. (personal opinion)
I have run flats but carry a spare tire in the spare tire hole incase the runflat and/or wheel becomes so damaged it's no longer useable.
__________________ |
05-02-07, 06:59 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2006 INFRARED CTS-V - BADCADY | | Join Date: Jan 2007 Location: Michigan Age: 30 | | | Re: Fix a Flat Bad for TPS???? Thanks
I guess the thread I read about carrying the Fix a Flat was for the Non-Runflat folks.
I agree, I won't be getting much speed on the V until I get some new tires.
So you actually bought runflats again? |
05-02-07, 07:02 PM
|  | Moon Parasite Cadillac(s): 2006 STS-V BlackonBlack / 2005 CTS-V Redline (traded in) | | Join Date: Dec 2005 Location: D/FW Tejas | | | Re: Fix a Flat Bad for TPS???? Yes and no, swapped out the original F1s for RSAs and have about 23K on these. Haven't fully decided what I'll replace them with, possibly RSAs again. |
05-02-07, 07:14 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2006 INFRARED CTS-V - BADCADY | | Join Date: Jan 2007 Location: Michigan Age: 30 | | | Re: Fix a Flat Bad for TPS???? RSAs came on mines, Just under 11k and a simple tire rotation made the world of difference. Then I get a hole in tire.
TireRack doesn't show the RSA, where can I get them online? |
05-02-07, 07:18 PM
|  | Moon Parasite Cadillac(s): 2006 STS-V BlackonBlack / 2005 CTS-V Redline (traded in) | | Join Date: Dec 2005 Location: D/FW Tejas | | | Re: Fix a Flat Bad for TPS???? Quote:
Originally Posted by GMBOUND TireRack doesn't show the RSA, | RS-A EMT ? http://www.tirerack.com/tires/Compar...nly&x=115&y=16 |
05-02-07, 07:34 PM
|  | Cadillac Owners Enthusiast Cadillac(s): 2007 CTS-V (Thunder Grey) | | Join Date: Dec 2005 Location: Sacramento Kalifornia Age: 59 | | | Re: Fix a Flat Bad for TPS???? Quote:
So you actually bought runflats again? | I am running non runflats (Michelin PS2) and would use fix-a-flat only as a last resort because there is a chance it will ruin the TPS. I have heard of people using it and having no problem with the TPS, others used it and lost the TPS. F1 run flats are supposed to be good for 100 miles at legal highway speeds with no air pressure, without ruining the tire.
As to the speed question, if the tire was patched you will lose 1 letter in speed rating. F1 Supercar EMT's with a speed rating of "W", or 168 MPH, will drop to a speed rating on "V", or 149 MPH. I would not dragrace with any tire that has been patched because the heat could melt the glue. However I have used my patched tires for track days since 2003 with no problems. I returned from a track day with the Corvette last week and found a screw in one of my Kuhno slicks. I had it patched and will use it next week at another track day.  |
05-02-07, 08:14 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 2006 INFRARED CTS-V - BADCADY | | Join Date: Jan 2007 Location: Michigan Age: 30 | | | Re: Fix a Flat Bad for TPS???? Thank You! |
05-03-07, 01:12 PM
| | Cadillac Owners Connoisseur | | | | | Re: Fix a Flat Bad for TPS???? The TPS in a run-flat system has a opening to expose the pressure sensor to the internal pressure. Fix-a-flat or other similar "squirt in the tire" concoctions can close off this hole, rendering the TPS inoperable. There is no "burn out" of the TPS.
And, as CIWS asked, with run-flats why would you need anything else? In any case, run-flats are the way of the future. In a few more years, that is all that will be available. |
05-03-07, 01:41 PM
Originally Posted by tedcmiller ...
In any case, run-flats are the way of the future. In a few more years, that is all that will be available. | I disagree with that statement. Runflats will come standars in all new cars with the pending legislation, but non runflats will be available for a long time. There is a huge market out there for non runflats and the tire companies will not turn their back on this large customer base.  |
05-03-07, 02:06 PM
|  | How YOU doin? Cadillac(s): 2007 SRX (Previously 04 CTS-V) | | Join Date: Dec 2004 Location: Over here. No, not there. | | | Re: Fix a Flat Bad for TPS???? Quote:
Originally Posted by 50 4Ever I would not dragrace with any tire that has been patched because the heat could melt the glue.  | I had a patched GS-D3 that couldn't even take prolonged highway speeds (75-80mph) without developing a small leak.
05-03-07, 02:20 PM
Originally Posted by The Tony Show I had a patched GS-D3 that couldn't even take prolonged highway speeds (75-80mph) without developing a small leak. | I have never had any problems with any of my patched tires. One of my front tires on the corvette was patched twice and that tire went cross country, came through Phoenix when it was 123 outside, cruised at 120+ for about an hour... no problems at all. Sounds like it wasn't patched properly.  | | Cadillac Discussion Tools | | |
Censor is OFF | | | |
