Free performance 'mods'
Results 1 to 9 of 9
2004-2007 Cadillac CTS-V General Discussion Discussion, Free performance 'mods' in Cadillac CTS-V Series Forum - 2004 - 2007; Here are some no-cost things that you can do to increase performance (or at least responsiveness): Turn off your A/C ...
    teros1's Avatar
    teros1 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Santa Clara, CA
    101
    LightbulbFree performance 'mods'
    • Turn off your A/C - Modern compressors sap only a few HP? Maybe, but they decrease throttle response big-time, even when runing a Maggie. With the A/C off, the throttle response goes from 'superb' to 'amazing.'
    • Run the right tire pressure - 37-40 PSI hot works very well for my 19" PS-2's. I don't know what the difference in rolling resistance is between 35 PSI hot and 38 PSI hot, but our cars are heavy and there's a big reduction in responsiveness at the lower temp. I can feel no reduction in traction. Note: If you live in a '4-season' climate, you'll have to adjust pressures several times a year to make this happen.
    • Reduce exterior noise in the cockpit - Earplugs are commonly used by motorcyclists, maostly to preserve hearing. However, a lesser-known effect is riding faster! Why? Humans naturally avoid loud noise, even noise that they like (rock music, engines, etc) - esp over longer durations. Humans also tend to perform better in calmer environments. So noise and other 'calamity' often causes an avoidance response, and we come out of the throttle (even if just a bit). I don't wear earplugs in the V, but I have sound-reduced it a bunch with Dynamat Extreme ($$$/weight). But even play jazz loud helps me stay in a lower gear longer (free)....
    For many out there, these are 'duh' material. But I hope that they help some folks get more pleasure from these fine machines...at no cost!
    Bob
    Maggie, K&N, Corsa, StealthTune, FG2, Sways, etc.
  2. #2
    04CTSVFLA is offline Cadillac Owners Connoisseur
    Aug 2005
    1,643
    Re: Free performance 'mods'
    lol, throttle body bypass goes on that list as well, as does removing the cats both which are free mods as well.
  3. #3
    wildwhl's Avatar
    wildwhl is offline Cadillac Owners Master
    Mar 2004
    Reno, NV
    5,496
    A good tune takes care of the A/C issue - trust me. Just changing the on/off points...
    WW
  4. #4
    Dennisscars's Avatar
    Dennisscars is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-VM 51 track days in Maggied V & 82 in Atom 2 in Volt
    Mar 2005
    SoCal
    1,690
    But B&B X-pipe sure sounds like music to me.. maybe not to my neighbors first thing in the morning...
    I know the sound of maggie screaming in bimmer boy's window as I pull past him sounds even better to me...
    Best free mod, remove golf clubs and DB's from trunk..
  5. #5
    wildwhl's Avatar
    Mar 2004
    Reno, NV
    5,496
    Actually - the best free mod for a V?
    Keep her.
    WW
  6. #6
    teros1's Avatar
    Santa Clara, CA
    101
    Quote Originally Posted by wildwhl View Post
    Good point. I have a StealthV tune and love it.
    But tunes cost $$$. Also, they typically don't disengage the compressor at partial throttle, which is how we drive most of the time (on the street) and where we feel and judge 'throttle response.'
    Maybe I should have qualified this point -- with pedal down above 4000 RPM, I doubt that I'd feel 10 compressors coming off/on. In that mode, the Ms Maggie will not be denied!
    The weight reduction comments hit the mark too...our seats, for example, are HEAVY. Folks remove the rear seats on the track....
    Bob
  7. #7
    wildwhl's Avatar
    Mar 2004
    Reno, NV
    5,496
    Bob -
    I'm right there with you.
    I've played with the points on the tune, and Stealth's are acutally pretty spot on. I don't recall the on/off points - but they're low enough and done intelligently enough so that part throttle response...well...in response to the M boys, I call it V mode
    WW
  8. #8
    Aug 2005
    1,643
    my rear seat felt like it weighed 4-5 lbs max.
  9. #9
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    Quote Originally Posted by 04CTSVFLA View Post
    Ditto on that. I was going to take mine out for a track day, but I figured why bother.
    -Chris
    2005 CTS-V:No Roof|T2+Eibachs|Corsa|UUC:Shifter, 2pc rotors, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hotchkis Sways|Kooks 1.75 Coated LTs+cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588+Dual Springs|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow OP|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Katech LS9X Clutch Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
    2012 CTS-V:No Roof|Wagon|M6|Recaros|<-- SOLD
    2014 ATS: 2.0T-M6
  10. Remove Advertisements
