Coolant loss...
Results 1 to 12 of 12
2004-2007 Cadillac CTS-V General Discussion Discussion, Coolant loss... in Cadillac CTS-V Series Forum - 2004 - 2007; During the past year accumulating approximately 10k miles, the DIC has indicated "low coolant level" twice. Is this typical??? TIA, ...
    pimpcaddy's Avatar
    pimpcaddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Platinum/Ebony
    Dec 2004
    San Ramon, CA
    501
    Coolant loss...
    TIA,
    Dave
  2. #2
    1QUICKV is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V SERIES
    Jul 2006
    BROOKLYN
    30
    700
    Re: Coolant loss...
    Your rad is leaking at the bottom where the lower radiator hosed connects. Leaking from seam.
  3. #3
    50 4Ever's Avatar
    50 4Ever is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS-V (Thunder Grey)
    Dec 2005
    Sacramento Kalifornia
    67
    1,667
    Re: Coolant loss...
    Last summer I got that message, filled up the reservoir and everythings been fine since. Now watch, I'll probably get that message tomorrow. Oh, just turned over 29K.
  4. #4
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    Re: Coolant loss...
    Unfortunately, non Northstar Caddies seem to pick up this very bad habit from their N* counterparts when they are sitting together at the dealers lot. My Escalade has done this to me twice since Ive owned it as well.
    Id look into the connection mentioned above as it seems the most likely cause. I just keep mine filled.
  5. #5
    vcaddy is offline Cadillac Owners Member
    Jul 2006
    67
    Re: Coolant loss...
    I had the same thing, two "Low coolant" messages in the past 3000 miles or so. I always top off the reservoir and forget about it because I have not noticed any fluid on the ground. I think I will check the radiator seam. Thanks for the tip!!
  6. #6
    G--'s Avatar
    G--
    G-- is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V Black;08 Yukon Denali
    Jul 2006
    DFW area, TX
    276
    Re: Coolant loss...
    Quote Originally Posted by 1QUICKV View Post
    Had the exact same issue, my dealer replaced the radiator under warranty, no questions asked. I could be wrong (I did not do a search), but I believe there's a TSB out on this as well....
  7. #7
    The Hog's Avatar
    The Hog is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac CTS-V
    Mar 2007
    Spokane, WA
    37
    178
    Re: Coolant loss...
    [QUOTE=Playdrv4me;1063823]Unfortunately, non Northstar Caddies seem to pick up this very bad habit from their N* counterparts when they are sitting together at the dealers lot. My Escalade has done this to me twice since Ive owned it as well.
    QUOTE]
    Hell, just reading the word "Northstar" make me want to leak a little bit.
  8. #8
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    45
    6,063
    Re: Coolant loss...
    I had my radiator replaced once for this.
    I just recently noticed a small leak again, and have the smell of coolant sometimes when I get on it hard.
    the leak itself is pinhole in size. it would take 5+ years to leak all the coolant out I'd think, but still not acceptible.
    I'm surprised this issue re-occured. I thought I had it fixed with the 'new' radiator.
    -Chris
    2005 CTS-V:No Roof|T2+Eibachs|Corsa|UUC:Shifter, 2pc rotors, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hotchkis Sways|Kooks 1.75 Coated LTs+cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588+Dual Springs|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow OP|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Katech LS9X Clutch Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
    2012 CTS-V:No Roof|Wagon|M6|Recaros|<-- SOLD
    2014 ATS: 2.0T-M6
  9. #9
    kgoch is offline Cadillac Owners Fanatic
    Automobile(s): 04 CTS-V
    Jul 2005
    Mountville, PA
    70
    209
    Re: Coolant loss...
    I had my radiator replaced twice under warrenty. It seems they had a batch of bad radiators. When you rev to over 6,000 rpm it would create to much pressure on the radiator and start leaking at the bottom seam. Since the last radiator i have not had any problems.
  10. #10
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    Re: Coolant loss...
    I don't mind going to the radiator shop. It is a good place to take a leak.
  11. #11
    Seattle CTS-V's Avatar
    Seattle CTS-V is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V (sold)
    Jun 2005
    WA
    1,475
    Re: Coolant loss...
    I've had a few 'low coolant' messages over the past few months. I just top it off and forget about it. I haven't seen any evidence of a leak though.
  12. #12
    DmaxSierra's Avatar
    DmaxSierra is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    May 2007
    26
    Re: Coolant loss...
    I also had the same problem...began around the first 100 miles. Initial problem was a faulty hose clamp which just cracked Replaced that myself. Then had the leaky radiator. Didn't actually see it dripping but had loss of coolant. Dealer re-crimped the lower radiator and she's been good for the last 5000 miles. They said that if it leaked again, then they would replace the radiator. Like stated previously...lots of faulty V radiators out there. As well as "faulty" differentials..but we won't go there
  13. Remove Advertisements
