engine oil cooler
Results 1 to 6 of 6
2004-2007 Cadillac CTS-V General Discussion Discussion, engine oil cooler in Cadillac CTS-V Series Forum - 2004 - 2007; has anyone installed an engine oil cooler with headers? I have every adaptor and have not found one yet? I ...
    c5racr1 is offline Cadillac Owners Enthusiast
    Automobile(s): 04 cts v
    Sep 2004
    Baton Rouge
    49
    531
    engine oil cooler
    has anyone installed an engine oil cooler with headers? I have every adaptor and have not found one yet? I want to go to one of the driving schools and would like this bit of insurance.
  2. #2
    V-Max Guest
    Re: engine oil cooler
    I'd try a lower temp thermostat first. When I drove the C5 through snow this winter, cringe if you like, the radiator got clogged and froze up acrossed. Even with the fans cycling on at 225F the oil temps were right behind in the 220s. Normal cruise is 192-194F for coolant and 185 for oil. Could save you about $950!
    Norm
  3. #3
    Dennisscars's Avatar
    Dennisscars is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-VM 51 track days in Maggied V & 82 in Atom 2 in Volt
    Mar 2005
    SoCal
    1,690
    no problems here... Mine only gets hot when I stay too high in the revs. Grab another gear and drive like push rod motor and not like DOHC buzz box. even mo' cheap..
    you want the oil to get hot enough (in normal driving) to burn condensate off..
  4. #4
    Feffman's Avatar
    Feffman is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    Nov 2006
    St. Louis, Mo.
    672
    Quote Originally Posted by c5racr1 View Post
    C5RACR1:
    One thing to make sure is the computer has been reprogrammed by a dealer for the "Engine Oil Temperature Gauge Warning". My oil temps were reading off the chart at Heartland Park last month (about 105 degrees hotter then the water). Scared the crap out of me until (thanks to the gang out here) I found out about this:
    The Caddy bulletin is:
    ASI Resolution - Engine Oil Temperature Gauge Warning
    #04-08-49-017A
    (August 3, 2004)
    This only shows up with sustained high speed or aggressive driving. If this corrects the issue, my oil temps at the track should be only slightly higher then the wate temps which at the track rarely climbed over 200 degrees.
    Make sure when you do the oil change, you use Mobil-1!!!
    Mark "Feff" Pfeffer
    www.MVPTrackTime.com
  5. #5
    OldRoadDawg's Avatar
    OldRoadDawg is offline Cadillac Owners Connoisseur
    Automobile(s): 2009 CTS-V
    Aug 2004
    NV
    1,905
    Sorry I don't have any ideas for you, but on a side note, I've been curious... c5racr1: How's that beast has been behaving?
    Quote Originally Posted by Feffman View Post
    C5RACR1:
    mm-m-m ... kinda doubt c5racr1 will be going to the dealer anytime soon.. with that LS7 engine stuffed in there.
  6. #6
    Sep 2004
    Baton Rouge
    49
    531
    Thanks but I allready have a 170 stat, and the LS7 likes the high RPMs so swiching gears is nice but when all the power is between 5k and 7k aint tom much gear left to grab. rad is fine, and I have the re-flash my temps are not high, 230 range. I just dont want the temps to be high.
    It has been quite good actually, drives like stock till you step on it. latest et at the drag strip was a 12.6 at 119.2 babying it off the line.
  7. Remove Advertisements
