CTS V Problems - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
2004-2007 Cadillac CTS-V General Discussion Discussion, CTS V Problems in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by propain Not while on the brakes... only while on Gas Pedal. Light pedal... I think i might ...
  1. #16
    z06bigbird is offline Cadillac Owners Connoisseur
    Automobile(s): Sedan de Ville, CTS
    Mar 2007
    San Antonio, Tx
    4,769
    Re: CTS V Problems
    Quote Originally Posted by propain View Post
    Not while on the brakes... only while on Gas Pedal. Light pedal... I think i might have felt it while coming to a stop... so hard to diag...
    Its almost like something is sticking every once in a while... no noise...
    E-Brake... ive been told to get it adjusted because it drops to low to engage so I figured it might be that... but your right... it wouldnt vibrate the front pedal...
    Hmmmm.....
    Ill send the check when its fixed!
    I'm holding my breath.
    Ed
  2. #17
    SkullV's Avatar
    SkullV is offline Cadillac Owners Connoisseur
    Automobile(s): NONE
    Mar 2007
    Downtown Chicago
    3,844
    Re: CTS V Problems
    I haven't been having battery problems yet, but the coolant thing is definitely a problem! Thanks for the heads up about the TSB.
  3. #18
    propain is offline Cadillac Owners Member
    Nov 2004
    83
    Re: CTS V Problems
    Quote Originally Posted by SkullV View Post
    The car is in the Dealer. SARANT CADILLAC. Awesome dealership. 1/2 hour car in shop, paper work done, on the road with a rental.
    So far....
    ECM Recall- Done
    New Radiator- Done
    Everything else still pending including....
    Friction or virbation at all speeds in the pedal.
    Battery not charging message.
    Rubbing front wheels at full turn.
    I have to say Caddy has good service, but for a vehicle with less than 24k miles on it, its got alot of problems.
  4. #19
    slothV is offline Cadillac Owners Fanatic
    Dec 2006
    195
    Re: CTS V Problems
    No suprise here...
    The #1 warranty item on the V is 'battery replace'.
    This occurs roughly three times more frequently than the #2 warranty item, which is rear diff replace.
    #3 and #4 are tire balance and alignment
    #5 is radiator replace
  5. #20
    Nov 2004
    83
    Re: CTS V Problems
    Quote Originally Posted by slothV View Post
    No suprise here...
    Yeah, but it sure sucks to have 4 out of the 5 of the problems
  6. #21
    Dec 2006
    195
    Re: CTS V Problems
    True. I calculate the chances as 1 out of about 230,000 vehicles to have those specific 4 out of 5 problems! And considering the number of V's that have been produced....yeah that does suck.
  7. #22
    gergreg is offline Cadillac Owners Fanatic
    Automobile(s): 2005 RedLine Cadillac CTS-V
    Oct 2006
    Penns
    457
    Re: CTS V Problems
    The fact that these problems are so damn common and GM has done nothing to fix them is worse.
  8. #23
    lunarx's Avatar
    lunarx is offline Cadillac Owners Connoisseur
    Automobile(s): 12 CTS Coupe Premium/Touring, 16 Volt, 13 911s
    Aug 2006
    SoCal
    1,730
    Re: CTS V Problems
    Except for the rear end, those are not major problems.
    I can see those bieng issues on just about any car.
    Batterey, Radiator, Tire Balancing, Alignment are normal maintenance items.
    GM really should not even cover those.
    Be glad you have a Bumper to Bumper warranty that covers little things like that.
  9. #24
    G--'s Avatar
    G--
    G-- is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V Black;08 Yukon Denali
    Jul 2006
    DFW area, TX
    276
    Re: CTS V Problems
    Well I checked the volts on the battery while the car was running....
    13.2 The battery is fine... Its the Alt.
    So... I guess the Alt is going bad and thats probably the binding, friction im feeling every once in a while.
    Thanks all for the help...
    What about peeling interior buttons? Covered?
    Got my car back from the dealer today, ordered a new NAV system due to peeling/flaking interior buttons...covered under warranty, no questions asked. They cannot replace just the buttons, only the entire NAV system.
    FYI had my radiator replaced at 7K under warranty, no issues since then.
  10. #25
    crypto_coyle79 is offline Cadillac Owners Member
    Automobile(s): 2005 redline V
    Feb 2006
    Washington DC
    37
    68
    Re: CTS V Problems
    Hey all, I’ve been away for a while...
    Still loving the V... No problems until now...
    Im getting a slight vibration in the pedal every once in a while. Hard to describe... Its not a rattle... its more like a hum... feels like the front end maybe... Maybe a wheel bearing... maybe the emergency brake rubbing. Maybe the breaks.. I really don’t notice a slowdown when it happens... and it only seems to happen when im light on the pedal..
    The second problem is I seem to be losing coolant. I don’t know where as there is no leaks. Maybe im just burning it up... maybe the sensor is to sensitive.. but I top it off during my oil changes and about 2.5k miles later im getting the message to add coolant.
    The third is "Battery Not Charging" Im getting this every once in a while also... volts drop to about 11.5 to 12. This is probably just the battery going bad.
    Either way... the top two are causing me to
    Anyone with the same symptoms please clue me in. Im bringing it into the dealer on 4/4/07 and it would be nice to tell them whats wrong.
    I had the batt not charging one. the problem for me was the cable from the Alt. cracks after getting to close too a hot part. It wasn't the batt. it was a cable.
  11. #26
    Nov 2004
    83
    Re: CTS V Problems
    Quote Originally Posted by crypto_coyle79 View Post
    so the car is back in the shop since last Wednesday. Lucky this dealer has good service and I get a car. Nice DTS btw... ride is smooth.
    So they changed the Alt. and the mechanic said it didnt fix the problem and that they were at a loss and havent seen this problem yet.
    Good to know on the NAV and it being covered under warranty.
    Radiator replace- No more leak
    ECM Flash- /shrug
    Wheel well molding loose- Fixed the rubbing problem.
    Battery not charging-
    Peeling Buttons-
    Ill update when completed... if ever...
  12. Remove Advertisements
