Help - tires
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V General Discussion Discussion, Help - tires in Cadillac CTS-V Series Forum - 2004 - 2007; A few days back I read a post here by someone who had driven a GM demo CTS-V on a ...
    TNT V's Avatar
    TNT V is offline Cadillac Owners Fanatic
    Mar 2004
    175
    Help - tires
    A few days back I read a post here by someone who had driven a GM demo CTS-V on a race track and they commented that the wheel sizes were slightly different on the car he drove. I can't find that post and I need those tire sizes. Is the poster still out there or does anyone remember the sizes? Thanks!
  2. #2
    miscreant's Avatar
    miscreant is offline GM Connection
    Feb 2004
    Norman, OK
    44
    1,286
    Re: Help - tires
    Hey, that would be me. I actually didn't get to drive the ones with the stagger, but here you go:
    Fronts were the standard 245/45R18s
    Rears were 275/40R18.
    All wheels were aftermarket customs. Front's were something like 8-8.5" wide and rears were 9-9.5" wide. The 275/40s won't fit well on the stock 8.5" wide rim.
    PS- I believe they were Bridgeston Potenza SO-3s.
    2004 Cadillac CTS (**SOLD** ): http://www.ctsowners.com
    2004 Pontiac GTO: http://www.myyellowgto.com
  3. #3
    TNT V's Avatar
    Mar 2004
    175
    Re: Help - tires
    Thanks, Miscreant! That's what I am looking for. I've been talking with HRE for my wheel order and no one has any experience with these cars and are afraid to make solid recommendations beyond stock sizes just yet. I'm looking at the HRE 840R's and would like to get a 9" in the rear. They think that will work but feel certain the 9.5" won't. I'm going 19" all around - the 20" just seems like too much wheel. Once they pin down the final fitment and tire sizes I'll post here.
  4. #4
    CTSV OWNER is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTSV
    Mar 2004
    174
    Re: Help - tires
    I noticed on the race version that they have wheel flairs. If you go with that large of a wheel/tire combination will they stick past the fenders and dirtyup the body. I drove thru a puddle just after washing my car and then turned the wheel and the water that was still in the treads sprayed onto the windsheild. Had to rewash the car again.
    miscreant did you notice if the car had wheel flairs?
  5. #5
    miscreant's Avatar
    Feb 2004
    Norman, OK
    44
    1,286
    Re: Help - tires
    Quote Originally Posted by CTSV OWNER
    This isn't an issue if you get the right offsets. The stock CTS-V wheel is a 8.5" wheel with a 42mm offset, which sticks the wheel out 2.60" from the hub mounting surface. If you move to a 9" wide wheel in the back, you'd need about a 48mm offset to match that, which would push the wheel only 1/2" farther into the wheel well. In the rear of the CTS (reg or V), there is ALOT of room because of the IRS. On the V (as with the regular CTS) you also have a little more rear fender overhang than in the front, and could actually stand to stick a little more tire out on the back (not much). I *honestly* think you could run a 9.5" wheel in the rear, ***as long as the tire is not too wide***. my guess, but NOT a recommendation since I don't know, but a 9.5" wheel with a 45mm offset would stick the wheel out .3" farther, and .6" farther in, which would be *to mee* perfect...
    In 19" wheels, I'd go 245/40 up front and 275/35 in the rear...I'm running 245/40 up front right now with no problems, and the V's suspension is even stiffer than mine. Make sure your 245/40 tire is not any taller than 26.6". Mine is 26.4", but I've heard that if you get close to 26.9" like the Falkens run, you rub (atleast on a regular CTS)...
    PS: cars did not have flares. And the water splash thing happens even with my car. In this scenario, the fronts stay the same size anyway, only the rears change...
  6. Remove Advertisements
