Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V Appearance Mods
2004-2007 Cadillac CTS-V Appearance Mods Discuss all Cadillac CTS-V appearance modifications here. Spoilers, tint, wheels, tires, lighting and more.
Cadillac Forums: Shifter Knobs
  #31 (permalink)
Old 02-22-07, 01:40 PM
RockinV's Avatar
Cadillac(s): 2005 Cadillac Redline CTS-V
View RockinV's Photo Album
Casino Cash: $750
Re: Shifter Knobs
I just checked my Paypal account...It was $80 US (with shipping) Not $98...In case any one cares.
  #32 (permalink)
Old 02-22-07, 06:25 PM
Cadillac(s): 2005 CTS-V/408ci/ 503 rwhp
View ochaole's Photo Album
Casino Cash: $705
Re: Shifter Knobs
TWM performance... its real heavy and feels great in my hand
  #33 (permalink)
Old 02-22-07, 07:22 PM
BadCad's Avatar
V Driver
View BadCad's Photo Album
Casino Cash: $457
Re: Shifter Knobs
Looks like it could be real popular with the ladies...
  #34 (permalink)
Old 02-23-07, 04:22 PM
RockinV's Avatar
Casino Cash: $750
Talking Re: Shifter Knobs
Originally Posted by TrazzNJ View Post
Waitin on you Rock!! I am definatly getting on just want to know how difficult the install was.
Good Luck !!
Done! Easy Breezy!
I installed my UUC Shifter, UUC Bushings and GTO Shift Knob/Boot yesterday. All went well no problems at all. A few notes:
UUC Shifter: Put the car on ramps, removed center console, drilled out rivets from top removed cross-bolt from bottom. Install was reverse of removal.
Replaced the rivets with bolts and lock nuts from kit. The shift assembly dropped down enough that I could get a wrench on the nut and tighten the bolt… all from the top.
UUC Bushings: While the shifter was out I slid the bracket forward and removed the old bushings and installed the UUC Bushings. Before I put in the new bushings I took the advice of others and beveled the leading edge just a bit and lubed up the outside of the bushings well… the rest was just leverage. I found it better to pry the bracket over the new bushings from underneath the car.
GTO/Morano Shift Boot/Knob: As I said before the GTO set up came with a metal shifter attached. It did take a little strength to pull the knob off of it …
…The hole in the GTO knob gets gradually smaller and the diameter is smaller than the shifter end. So the inside of the knob needs to be widen a just a bit it to accommodate the V shifter. I used a rasp bit with my drill and only took a little off. The knob still needs to be pushed on with a lot of force to get it all the way on. I used a small amount of silicon inside the knob before installing it but I don’t know if it needed anything. It is a very tight fit and on extremely securely.
As for the boot I just cut the bottom using the old boot as a guide and put it in the V frame and glued the ends down. It looks factory… well actually better than factory IMO!
(note the way the white stitching matches the seats )
Over all it was a relatively easy mod. And well worth the effort.
It feels like a different car…shifts like a dream!
  #35 (permalink)
Old 02-23-07, 05:00 PM
TrazzNJ's Avatar
Cadillac(s): 04 CTS-V Light Platinum ...8800 Mi.
View TrazzNJ's Photo Album
Casino Cash: $305
Re: Shifter Knobs
Looks Great !!! I can't wait to get mine!!
  #36 (permalink)
Old 02-23-07, 07:37 PM
heavypedal's Avatar
Shake n Bake! Yeah..that just happened.
Cadillac(s): '04 Raven CTS-V
View heavypedal's Photo Album
Casino Cash: $310
Re: Shifter Knobs
HAHAHAHAHAHA
  #37 (permalink)
Old 02-23-07, 07:38 PM
heavypedal's Avatar
Casino Cash: $310
Re: Shifter Knobs
Dammit you guys....I told myself I wasn't going to do the Manaro mod... and you are not making it any easier.
T
  #38 (permalink)
Old 02-23-07, 07:39 PM
heavypedal's Avatar
Casino Cash: $310
Re: Shifter Knobs
RockinV...that picture is sweet. Pedals, new knob....dayhm.
T
  #39 (permalink)
Old 02-23-07, 09:16 PM
OldRoadDawg's Avatar
"gotta get a Wait4Me tune"
Cadillac(s): 2009 CTS-V
View OldRoadDawg's Photo Album
Casino Cash: $6096
Re: Shifter Knobs
T
Definitely looks good! Waitin' for mine to be delivered any day now. No hurry though. Too cold in my garage right now to do any work. Thanks in advance RockinV for the install tips.
  #40 (permalink)
Old 02-24-07, 03:43 AM
RockinV's Avatar
Casino Cash: $750
Re: Shifter Knobs
T
Yea I just got the AutoVation Pedals for Valentines Day...( I love my wife)...
...I can't wait for Father's Day!
  #41 (permalink)
Old 02-27-07, 06:22 PM
RockinV's Avatar
Casino Cash: $750
Exclamation Re: Shifter Knobs
Good Luck !!
Hey TrazzNJ I just emailed you a copy of the UUC Install notes and the Monaro Install notes that I complied from the forum. Hope it helps
  #42 (permalink)
Old 04-06-07, 05:42 PM
Pegasus04's Avatar
Cadillac(s): Cadillac CTS-V
View Pegasus04's Photo Album
Casino Cash: $1087
Red face Re: Shifter Knobs
Did any of you remove the plastic sleeve from the inside of the shifter knob before you bored it out? The only thing left for me to do before I install the shift knob is to bore it out and I want to do it right. Thank you for all of your input.
  #43 (permalink)
Old 04-06-07, 08:39 PM
RockinV's Avatar
Casino Cash: $750
Re: Shifter Knobs
NO... don't remove the plastic sleeve !
Although I am not sure how you would do that short of boring it completely out.
I am guessing you got the short metal shift rod out of the new GTO knob?!...(mine took maximum effort to remove) You really don't need to remove very much of the plastic material from the inside of the knob to get it to fit (you want it tight...real tight!)
The hole in the GTO knob gets gradually smaller from the opening so most of the material removal is towards the bottom of the hole (top op the knob) The inside of the knob only needs to be widened just a bit it to accommodate the V shifter.
I used a rasp bit with my drill and only took off a little at a time and then tried it ...but be careful… if you put it on too far it is hard to get back off. You just want to be sure to have it widened deep enough inside because it needs to go all the way down onto the shifter.
Keep in mind that you want it to require a lot of force to get it all the way on so you will be sure it is secure. I used a little bit of silicon (RTV) inside the knob before installing it. I ever you need to take it off it might be hard but it will still be possible and it won't mess up your shift rod.
Good luck... post a pic when you are done
  #44 (permalink)
Old 04-07-07, 08:00 AM
Pegasus04's Avatar
Casino Cash: $1087
Re: Shifter Knobs
Thanks for the quick response Rock. Yes, I did remove the shaft that was inside the shifter knob and you are right about it being had to remove. I struggled with it until I tried twisting the knob and it came right off. Hopefully, I'll get it installed today and post a picture.
Tags: ,
knobs, shifter
Censor is OFF
