Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 - 2007 > 2004-2007 Cadillac CTS-V Appearance Mods
2004-2007 Cadillac CTS-V Appearance Mods Discuss all Cadillac CTS-V appearance modifications here. Spoilers, tint, wheels, tires, lighting and more.
Cadillac Forums: Homemade clear fog lights.......
Old 07-01-06, 06:59 PM
Got5onit's Avatar
Cadillac(s): LS6 V
View Got5onit's Photo Album
Casino Cash: $1565
Just finished up the clear fog light mod. Loosened up the glue on the lenses by heating them up in the oven. Finished up with a heat gun. Purchased Two 11x14 sheets of lexan and traced a pattern with one of the removed lenses. Cut shapes out, sanded the edges, and glued with Silicone adhesive. The fog light housing is curved so I had to tape the lenses down with electrical tape overnight. Glued down pretty rock solid. Washed the car and sprayed the lenses, no leaks.
A couple of shots came out slightly blurry.
Opinions?
  #2 (permalink)
Old 07-01-06, 07:18 PM
Black Ops's Avatar
Cadillac(s): 06 CTS Black Raven
View Black Ops's Photo Album
Casino Cash: $475
Re: Homemade clear fog lights.......
WOW..it looks HOT!!! How about making some for us??
I was going to buy the STS-V ones but they want $200+ for them...what would you charge if you decided to make some for the CTS/CTS-V crew??
  #3 (permalink)
Staxxin's Avatar
V-LOVIN
Cadillac(s): 2005 CTS-V
View Staxxin's Photo Album
Casino Cash: $4347
LOOKS GREAT!!! On a side note, so do your rims. What did you do? Do you have a side photo?
  #4 (permalink)
Old 07-01-06, 07:40 PM
v-ape's Avatar
Cadillac Owners Enthusiast
Cadillac(s): (did) CTS-V
View v-ape's Photo Album
Casino Cash: $405
how much do you charge
  #5 (permalink)
Old 07-01-06, 07:44 PM
Got5onit's Avatar
Cadillac(s): LS6 V
Casino Cash: $1565
That was the main reason I did this. The ridiculous cost of the STS fog lights and the fact I prefer the clear look. You have to remove the fog light anyway, so I figured with a little elbow grease,making my own set wouldn't be hard to do.
Cost break down:
11x14 Lexan sheets from Home Depot - $5 each
Silicone Adhesive from Autozone - $5
Sandpaper - $??? Can't remember, it was some I had left over from another home project. Stuff is cheap.
If you have a dremel tool there is an attachment you can purchase to cut the lexan. I found this out by researching the web. I don't have a dremel tool, but my place of employment has a band saw and that's what I used. The lexan is not very thick, and I'm certain can be cut with any type of cheapo handsaw.
Also, there is a metal divider(I'm certain it's aluminum) inside the housing that separates the driving lights from the fog lights. This has to be removed and cut down just a bit. It pulls out with a firm tug. It's a very light piece of metal and is easily cut with a hacksaw.
The thought of making them and selling never crossed my mind. However, I am willing to help anyone who wants to do this and has any questions on this procedure.
  #6 (permalink)
Old 07-01-06, 08:04 PM
my name is Tiffany
Cadillac(s): 05 CTS-V
View urbanski's Photo Album
Casino Cash: $1133630
paging WW
  #7 (permalink)
Old 07-01-06, 08:13 PM
2004CTS's Avatar
Cadillac(s): CTS 3.6L - Every Option Except Nav
View 2004CTS's Photo Album
Casino Cash: $340
Looks Awesome! Here are my questions:
1. What oven temperature did you use?
2. Did you set the oven on bake or broil (or something else)?
3. How long did you leave them in the oven?
4. Do you feel the lenses could have been cut off using a Dremel or similar type of tool?
  #8 (permalink)
Old 07-01-06, 08:17 PM
wildwhl's Avatar
Cadillac Owners Master
View wildwhl's Photo Album
Casino Cash: $415
I'm on it
Guess I'll pull the fogs when I pull the bumper Monday to finish the MethInjection install...and make up a template.
How many do we need?
What was the thickness of the Lexan?
WW
  #9 (permalink)
Old 07-01-06, 09:02 PM
Seattle CTS-V's Avatar
Cadillac(s): Temporarily None
View Seattle CTS-V's Photo Album
Casino Cash: $4749
Looks awesome. I did the oven trick on the main headlights of my Acura. Worked very well to give me that clean look. Takes alot of time and patience though. Soak a towel first and set the lenses on that in the oven...just in case the metal bars get hot and decide to start melting the plastic.
  #10 (permalink)
Old 07-01-06, 09:08 PM
Got5onit's Avatar
Cadillac(s): LS6 V
Casino Cash: $1565
Set the oven to Bake and PREHEAT at 350 (~6minutes).
When fully heated, turn OFF the oven. Place the fog light units on a baking pan, lens side down(damaging the lens is no big deal) and place in the oven for 10 minutes. Again, make sure the oven is OFF before doing this. You do not want to melt or warp the housing!!
Use a screw driver and slowly pry the lens out. Heat the edges with a heat gun or hair dryer when you feel it cooling off. USE GLOVES!! THEY WILL BE HOT! Don't ask me how I know.
The lexan is pretty flexible and seems pretty easy to cut. I read somewhere that it's 100 times stronger than glass and heat resistant up to 200deg(F). A cutting disk for a dremel or drill will certainly be sufficient.
Don't forget to pull the aluminum divider and cut it down. It sticks out and will get in the way when trying to place the new lens on.
The thickness of the 11x14 sheets at Home Depot were .93mm(1/8"). That's the only thickness I could find.
Also, my lens cut out was far from perfect. A few jagged edges, and not exactly round at the corners. But it was big enough to go to the edges of the housing, which is very important. Tape down the lexan to the housing and allow it to dry/cure overnight. The Adhesive sealant I bought had a 12hr curing time. Be sure to fill the entire outer gap with silicone adhesive. You don't want water leaks!
  #11 (permalink)
Old 07-01-06, 09:19 PM
Chef's Avatar
View Chef's Photo Album
Casino Cash: $405
When fully heated, turn OFF the oven. Place the fog light units on a baking pan lens side down(damaging the lens is no big deal) and place in the oven for 10 minutes.
The thickness was .93mm(1/8").
Also, my lens cut out was far from perfect. A few jagged edges, and not exactly round at the corners. But it was big enough to go to the edges of the housing, which is very important. be sure to fill the entire outer gap with silicone adhesive. You don't want water leaks!
Ah, finally something a chef can relate to Nice recipe!! Your tires and wheels look like mine GS-D3's 275/40/18 rear, 245/45/18 front and powder coated black stock wheels?
chef out...
  #12 (permalink)
Old 07-01-06, 10:01 PM
wildwhl's Avatar
Casino Cash: $415
Wouldn't everyone prefer a gray tinted material as opposed to clear? Just a thought...that's what I'll try with mine this weekend.
Also - how about a difraction(sp?) pattern engraved on the inside?
WW
  #13 (permalink)
Old 07-01-06, 11:20 PM
View Gordy Petrovski's Photo Album
Casino Cash: $4752
Man that looks kick ass Congrat's
  #14 (permalink)
Old 07-02-06, 09:00 AM
rand49er's Avatar
Mods on hold till diff gets fixed.
View rand49er's Photo Album
Casino Cash: $47869
Well, if there're any bad cooks out there, I just got my STS fogs from Lindsay on Thursday. When I install them, my stockers may be available to first guy/gal who gets his/hers over done.
Snif ... snif ... do I smell anything burning?
(Kinda wished I'd waited, now ... those homemade ones look pretty nice!)
  #15 (permalink)
Old 07-02-06, 01:41 PM
Got5onit's Avatar
Cadillac(s): LS6 V
Casino Cash: $1565
I had my stock wheels customized by a local wheel shop. The outer lip is polished and the spokes are painted black.
Here's a pic I took a few months ago:
Note the side marker light is now covered with black lens tint.
Tags: , , ,
clear, fog, homemade, lights
Censor is OFF
