ebay wheel center caps
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V Appearance Mods Discussion, ebay wheel center caps in Cadillac CTS-V Series Forum - 2004 - 2007; http://www.ebay.com/itm/04-09-Cadill...ad1df5&vxp=mtr I guess we can start with the cheapest ones and work our way through my wallet if need be.... ...
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    Anybody tried these??
    Feb 2009
    Greenville sc
    45
    992
    Re: ebay wheel center caps
    Recieved in the mail today and for 49 bucks, I'm happy.
    PJGross is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V
    Apr 2008
    168
    FYI, I've bought similar to these twice. In my experience, eventually water/junk will work in between the clear plastic top and base and erode the adhesive, causing cosmetic deterioration and eventually separation. On my latest round of caps, I used a flexible sealant and "buttered" it around the outside edge joint after taping the clear cover with painters tape. To avoid a cosmetic issue, I would tape the edge of the clear cover, around its circumference, not just the top surface, to avoid seeing the sealant through the plastic.
    Personally, I used a flexible urethane in b/c that's what I had at work. However, a neutral cure silicone should be fine as well. I don't think I would use an acetoxy silicone (smells vinegarish) because it could corrode the metal foil under the emblem as it gives off acid during cure. Other sealants may be solvented to the point where they could effect the decorative foil as well, so use caution.
    So far, I have 2 winters on my winter caps here in Michigan and they have held up just fine, no separation/corrosion.
    Without sealing, one of my last sets did not last a full year without showing some pitting under the plastic cover.
    -PJ
    Feb 2009
    Greenville sc
    45
    992
    Quote Originally Posted by PJGross View Post
    -PJ
    Nice tip!
    Wingsfan4life's Avatar
    Wingsfan4life is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V Black Raven
    Aug 2011
    Brooklyn Center, Mn
    46
    232
    I bought 2 sets of those, and they seem to be an awesome deal-i-o..the ones I put on last year are still great, and I wash my car daily sometimes twice...lmao
  8. Remove Advertisements
