Stealth gray 05 cts-v repaint to opulent blue thoughts. - Page 2
View Poll Results: 05 cts-v stealth gray or opulent blue
Voters
16. You may not vote on this poll
  • Stealth gray
    8 50.00%
  • Opulent blue mettallic
    8 50.00%
Multiple Choice Poll.
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
Like Tree3Likes
2004-2007 Cadillac CTS-V Appearance Mods Discussion, Stealth gray 05 cts-v repaint to opulent blue thoughts. in Cadillac CTS-V Series Forum - 2004 - 2007; How about white?...
  1. #16
    mberisha's Avatar
    mberisha is offline Cadillac Owners Connoisseur
    Automobile(s): '11 Black Escalade AWD & '06 Black CTS-V
    Aug 2009
    Aviano, Italy
    38
    1,898
    Re: Stealth gray 05 cts-v repaint to opulent blue thoughts.
    How about white?
  2. #17
    AZLS6V's Avatar
    AZLS6V is offline Cadillac Owners Member
    Automobile(s): 05 Cts-v
    Nov 2013
    10
    That white color is awsome but matte colors are expensive and really hard to paint perfect
  3. #18
    NC-V is offline Cadillac Owners Fanatic
    Automobile(s): '05 CTS-V
    Feb 2010
    Mooresville, NC
    113
    Matte colors are no more expensive than gloss. The clear or clear coat additive may add a little cost, but it would be minimal depending on paint brand, the base coat will most likely be the same regardless of gloss/matte finish. Matte finishes can be a little more tricky to get just right, but an experienced painter shouldn't have a problem, just need to be extra careful about dust/debri as the finish can't be wet sanded and buffed. Also, white is pretty much the cheapest paint color available.
    As for your color choice, I love the newer blue, but color changes get expensive and will not help re-sale value at all. Painting the door jams, under hood, trunk, back sides of hood and trunk, etc, is very costly and time consuming, especially if you want a decent job. 1.5 gallons may be enough base coat to do what you want depending on paint brand, but I have found that a lot of the newer GM colors require more than the normal 2-3 coats. These paints contain a lot more clear binder to suspend the pearls and flakes properly so it may take more base coat to cover properly.
    Just FYI
  5. #19
    H-town_V's Avatar
    H-town_V is offline Cadillac Owners Fanatic
    Automobile(s): 05 cts-v
    Feb 2013
    341
    When my car was in the shop I considering repainting it tri-coat white. It would have cost $6k+ Plus like others have said... A color Change makes future buyers very suspicious.
  6. #20
    AZLS6V's Avatar
    Nov 2013
    10
    Maybe I should have said this since the beginning but I'm a professional painter and the work will be done by me at my shop. Also matte colors base coats are the same cost but the flattend clear is about 150 a quart vs a great clear coat gallon at around 260. Also I understand that it may raise flags for resale but I have this insident fully documented and there Allways car fax.
    What I would really like to know is if any of you guys think this color would look good on this particular car.
  7. #21
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,833
    Quote Originally Posted by AZLS6V View Post
    ... What I would really like to know is if any of you guys think this color would look good on this particular car.
    Opulent blue would turn heads ... no doubt whatsoever.
    Love white. Don't know what others see in the matte look, though. That's okay for track cars, I guess. Maybe I'm just getting old.
  8. #22
    2007-V is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Oct 2013
    121
    I love the white as well, but would do the Caddy pearl metallic and not a flat/satin white. I will probably wrap my car next year with that or something very similar.
  9. #23
    kevler9oh is offline Cadillac Owners Member
    Automobile(s): none :(
    May 2012
    3
    The opulent blue with yellow calipers looks incredible, I've seen it on a few V2s.
    OP, I would also look into varying from stock Caddy colors and looking at colors from other vendors. It's cool to have a V1 with a V2-only color, but to have with a color no other Caddy has would be really cool imo. If you're going to divert from stock, divert from STOCK!
  10. #24
    AZLS6V's Avatar
    Nov 2013
    10
    I present to you opulent blue v1. More to come soon.
    barrok69 and ronss96 like this.
  11. #25
    ctsv247 is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Stealth Gray V
    Feb 2009
    Greenville sc
    45
    992
    It looks good...looks like you did a first rate job on it but would i have done that to a car that looked as good as yours did? I don't think I like it that much but it could make sense on a car that had enough damage on it.
    As far as being unique, I can't fault you there but seeing as how I've only seen 2 v1s in the last 6 months, being unique isn't a problem.
    Two stealth gray repaints in one month....my car gets rarer and rarer...keep it up boys!
    oops...just saw where you're car got keyed. that changes things up a bit but i hate changing colors...what a bitch.
  12. #26
    AZLS6V's Avatar
    Nov 2013
    10
    Yea it was keyed bad it sucked specially because the car was super clean. But I do love this new color. True I've only seen 1 other v here in phoenix stealth gray but i will be the only opulent blue world wide v1 I think lol. It is a biatch to change the color since I'm booked with other cars at work but slowly working on it to perfection.
  13. #27
    ronss96 is offline Cadillac Owners Member
    Nov 2014
    14
    Thumbs upRe: Stealth gray 05 cts-v repaint to opulent blue thoughts.
    Love that color! Good for you stepping out of the box. It's your car man. Do what you want. I think it looks awesome ! And painting your own car I know you are doing it right. Thumbs up from me man!!!
  14. #28
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,884
    What happened with more to come?
  15. #29
    06v
    06v is offline Cadillac Owners Member
    Automobile(s): CTS V
    Mar 2014
    28
    14
    yeah I actualy love that look and would love to see it completed
  16. #30
    kbraniff is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Stealth Gray stock
    Jun 2015
    Central Jersey
    371
    I was looking for black originally but when I saw the Stealth Gray I had to have it. I have the ebony interior so I don't have the rarest of the rare but rare still. Actually some people, upon looking over the color of the paint, state that it has a blue tint similar to a Gunmetal Gray color. I'd stay stock. Just my opinion.
  17. Remove Advertisements
