"Audio" circuit parasitic drain on battery.....HELP!
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
2004-2007 Cadillac CTS-V Appearance Mods Discussion, "Audio" circuit parasitic drain on battery.....HELP! in Cadillac CTS-V Series Forum - 2004 - 2007; I have been searching for a couple of hours and have found some similar issues to the one I'm having. ...
    Rez Rider's Avatar
    Rez Rider is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Sep 2013
    Oregon
    46
    I have been searching for a couple of hours and have found some similar issues to the one I'm having. I have owned my 2005 CTS-V for only a couple months and one day I go to start it up and nothing. Naturally I assume bad battery (or I left a light on) put in on a trickle charger and reinstalled the battery. the next morning it was dead again. hooked up a ammeter in series with the battery and there was a 2.3A draw. I began pulling fuses to locate the issue. I found that in the L.REAR fuse box when I pulled the fuse labeled "Audio" the amp draw dropped to ~1.7, then after about 30 seconds it dropped to normal level (~30mA). Well I left the "audio" fuse out and the next morning the car started up like normal. But now I don't have any power to the radio head unit. I don't have any information on that circuit for troubleshooting. I have read in other posts that the head unit is causing the draw, but I have also read that the amp in the left rear of the trunk is the culprit. I am ok with basic troubleshooting but have no idea how to go about figuring this one out. I am hoping somebody has dealt with this (or at least heard of it). I would appreciate ANY & ALL suggestions from all the experts on here. Thanks in advance!
    Rez Rider's Avatar
    Sep 2013
    Oregon
    46
    Re: "Audio" circuit parasitic drain on battery.....HELP!
    I was really hoping someone would know something about this issue. I guess it's not as common as I thought!
    69stangscj's Avatar
    69stangscj is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V sedan, 69 Mustang Mach I
    Jul 2013
    Dayton Ohio
    331
    Can you put the Audio fuse back in and disconnect the amp in the trunk and see what happens?
    Rez Rider's Avatar
    Sep 2013
    Oregon
    46
    First of all thanks for your reply. I did try that recently and no luck. I completely removed the amp and the car was still pulling 2.3A when off. Would you happen to know what else is on this circuit? I figure the head unit would be on the circuit, and was thinking of removing it and performing the same test as I did with amp, but I figured i would ask to see if someone would have encountered this problem and knew what the issue was. I am guessing that I will need a new stereo/nav head unit. I tried to find one on GMpartsdirect.com but they only showed the head unit "w/o nav". Can't seem to find a new head unit anywhere. thanks again for your input, I really appreciate it!!
    Rez Rider's Avatar
    Sep 2013
    Oregon
    46
    planning on taking the head unit out tomorrow to see if I still get the same draw from the battery. I honestly just want to find the darn issue so I know WHAT to fix, after that I'll worry about the cost of the new part.
    Rez Rider's Avatar
    Sep 2013
    Oregon
    46
    ok removed the head unit and the amp draw went to acceptable levels. So I think I am in the market for a new head unit, but then when I put the old unit back in (don't want a hole in the dash until I get the new unit) so I begin plugging in the connections and decided to check the draw after each thing I plug in. Each time the amp draw dropped to where it should be. Then I plug everything in and the darn thing went to normal draw from the battery! I am happy that I don't have to buy a new unit, but am a little frustrated because I didn't change anything, which means it could happen again. But I'm happy for now, and hopefully it doesn't return!!!!!!
    Jakaround is offline Cadillac Owners Member
    Automobile(s): 2007 CTS V, 1 7/8" Kooks, Magnaflow Exhaust w/ X pipe
    Mar 2010
    36
    3
    This is what I call jiggleshooting. Its possible one of your connectors was dirty and/or corroded and allowing a path to ground for current flow. Sometimes just pulling connectors and reconnecting them fixes the problem with no apparent culprit.
    s6k9s is offline Cadillac Owners Member
    Automobile(s): 2007 cts 3.6
    Jan 2013
    29
    17
    here goes a long shot in the dark so im experiencing this same problem right now with all fuses in i get a draw of 2.00 amps for 30 seconds then it drop to .50 for 30 seconds then right back to 2.0 amps over and over. so when i remove the 10 amp audio fuse from the rear, then do a test, i get 1.5 -1.9 amps for 30 seconds then it drops to .05-.07 amps and stays there no matter how much longer i test for. Is this the head unit? My other question is why do i see a draw after i remove the 10 amp fuse??? It would seem like i wouldnt see anything? right?
    Jan 2013
    29
    17
    bump
    heavymetals's Avatar
    heavymetals is offline Cadillac Owners Master
    Automobile(s): 05 maggied CTS-V, 03 maggied Z06
    Nov 2004
    8,790
    Sounds like the display isn't shutting off.
    There is a circuit that keeps the display active for info even if you aren't listening to anything.
    It should shut off, and it sounds like yours isn't.
    Jan 2013
    29
    17
    Thanks for replying the display does turn off but today removed the radio and cleaned the connectors. Put it all back together all fuses in and checked for draw I got 2.5 for 25 seconds then it dropped to nothing amd stayed there sounds great but battery was showing 11 volts and still wouldn't turn over the car. On another note last night I removed the ground terminal and hooked up trickle charger at 2 amps all night. So I would have a full battery in the morning for pulling fuses and doing a draw test. When I woke up would you believe that the battery wouldn't turn the car over....it's a brand new battery nit even 4 months old ac delco from the dealer.
    Jan 2013
    29
    17
    Next is to go to the dealer for a battery replacement and see what they have to say I guess I'm kinda at a loss
    Jan 2013
    29
    17
    I know repetive draining if a battery is not good and we're going on about 3 weeks of this jumping it off and draining
  16. #14
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,213
    There are some attachments that may be useful within the following thread-
    http://www.cadillacforums.com/forums...elp-radio.html
  17. #15
    Nov 2004
    8,790
    Quote Originally Posted by s6k9s View Post
    Just because the display doesn't show anything means nothing.
    The power supply for the display can still be "on" and if there is no info to display it won't.
    It may still be drawing power.
    If you unplug the HU and the problem goes away, chances are that is it.
  18. Remove Advertisements
